    Flashing and green lines after couple of minutes
    flashing screen issue
    4 Posts 3 Posters 1.8k Views 2 Watching
    • Q Offline
      qistoph
      Hi all,
      Finally got to building my own MagicMirror and am quite pleased with the result. I am however running into an issue I can’t get fixed on my own. I’m hoping someone out here might have a good suggestion that will fix the issue.
      When my mirror’s been on for a couple of minutes the screen starts flashing and shows green lines about every other line on the display.
      I have been searching for solutions and tried some stuff to fix it, including:
      • replacing the power supply to rule out low voltage issues,
      • replace the hdmi cable, to rule out issues with that,
      • configure hdmi_boost=6 in config.txt, seems to have helped people with similar issues,
      • simplyfy MagicMirror config, to rule out issue is due to my modules
      The weird this is, if I disable MagicMirror (pm2 stop mm) before it starts flashing, it won’t flash even after an hour. If it has started flashing nothing seems to help, except turning off and on power or a full reboot of the pi.
      I’m using a Raspberry pi 3B+
      Edit: here’s a short video of what I see:
      https://youtu.be/_qaLOZ1Pj7E
        bhepler Module Developer
        That looks a lot like what I had a few months ago. You can read more about it in this post.
        My solution was to go away from the “fake” OpenGL driver and to set the desktop resolution to “monitor default” instead of the monitor resolution. I don’t know which of those two fixed it.
        Q 1 Reply Last reply Reply Quote 1
          sdetweil @qistoph
          @qistoph try disabling the GPU.
          Stop pm2 instance, try this from terminal window
          npm --disable-gpu start
            • Q Offline
              qistoph @bhepler
              @bhepler Thanks! Switching away from the fake driver seems to fix it.
