    Auto Video Player
    14 Posts 2 Posters 4.4k Views 2 Watching
    • T
      thebeatgeek
      Can someone take a look at my code I am trying to make a module that will allow you to play your videos from the SD card. If I use the node_helper.js file I get a blank screen when starting the MM software. If I do not use the node_helper.js file it starts the MM software and loads the other modules. I’m fairly new to coding so if you guys can help it would be AWESOME!!! I can upload the code I’m developing upon request.
      Thanks - Bryan
        sdetweil @thebeatgeek
        @thebeatgeek there is a sample, module in the defaults folder, helloworld, but it doesn’t use node_helper.
        I have a sample, has both, and a little communication between and adds content to the screen…
        https://github.com/sdetweil/SampleModule
        config is
               module: "SampleModule",
                      message:  "message you want displayed"
          @thebeatgeek and I would look at your code… make a github repo
          follow the instructions for loading your code into it…
          T 2 Replies Last reply Reply Quote 0
          • T
            thebeatgeek @sdetweil
            @sdetweil Setting up a repo now.
            • T
              @sdetweil https://github.com/thebeatgeek/MMM-AutoVideoPlayer
                sdetweil
                grant me permission to push to your repo
                  @thebeatgeek u should contact me via chat on discord app… same userid over there
                  then we can talk thru the things I found.
                  • T
                    @sdetweil I made the repo public you should be able to access it. I installed discord username: thebeatgeek36 #8697
                      @thebeatgeek even tho public, you must grant specific users right to push to your repo.
                      public makes it to anyone can fork, clone or pull
                        @thebeatgeek i don’t see your id in discord…
                        T 3 Replies Last reply Reply Quote 0
                        • T
                          @sdetweil OK what is your 4 digit code in discord?
                          • T
                            @sdetweil my tag is thebeatgeek36#8697
                            • T
                              @sdetweil I just sent the invite link to collaborate. Did you fine me on discord?
                                @thebeatgeek @sam #5710
