Navigation
    • Search
    MagicMirror² v2.15.0 is available! For more information about this release, check out this topic.
    Problems with Electron and IFrame and Microphone
    Troubleshooting
      A Former User last edited by
      I have MagicMirror setup and running however I have run into two problems. One being that when running the Mirror through Electron, the microphone does not seem to activate. If running the page within Chromium as it should, it works fine. This is the same issue with Iframe, as I am attempting to display a web camera and it fails through Electron (Error loading player: No playable sources found) however when running in Chromium the web cam displays fine.
      Any ideas will be helpful. Thanks
      Sean 1 Reply Last reply Reply Quote 0
      • Sean
        Sean Module Developer @Guest last edited by
        @thisonecountz
        some modules need electron-rebuild to run on Electron. Electron has it’s own nodeJS envrionment, so it could not be compatible with your system-level nodeJS. so some of your modules need to be rebuilt.
