    MM Server Mode in Docker on Raspberry
    4 Posts 2 Posters 2.2k Views 2 Watching
    • SergeS
      Serge
      Good day, Ladies and Gentlemen,
      Following instructions at https://github.com/MichMich/MagicMirror and https://github.com/bastilimbach/docker-MagicMirror.
      The following steps has been done:
      1. Downloaded and flashed to SD card latest clean Raspbian Stretch with desktop (kernel version 4.14) from raspberry.org.
      2. Connected Raspberry to WiFi network.
      3. Installed Docker by executing
      curl -sSL https://get.docker.com | sh
      1. Get Docker autostart
      sudo systemctl enable docker
      1. added member to docker’s group
      sudo usermod -aG docker pi
      1. Reboot system to changes take place
      sudo reboot
      1. Downloaded container with magicmirror for raspberry
      docker pull bastilimbach/docker-magicmirror:raspberry
      1. Executed container start according to instructions at MM docker page:
      docker run  -d \
      	--publish 80:8080 \
      	--restart always \
      	--volume ~/magic_mirror/config:/opt/magic_mirror/config \
      	--volume ~/magic_mirror/modules:/opt/magic_mirror/modules \
      	--name magic_mirror \
      1. Created config.js file in “/home/pi/magic_mirror/config”
      sudo nano config.js
      1. Edited config.js in “/home/pi/magic_mirror/config” to the following lines:
            var config = {
            	address: "0.0.0.0", // Address to listen on, can be:
            	port: 8080,
            	ipWhitelist: [], // Set [] to allow all IP addresses
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            		// OTHER MODULES CONFIGURATIONS DELETED HERE FOR SIMPLICITY
      2. Reboot the system
      sudo reboot
      1. Checked IP addresses
      ifconfig
      pi@raspberrypi:/ $ ifconfig
      docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
              inet6 fe80::36c7:71e6:4c9c:d8d9  prefixlen 64  scopeid 0x20<link>
              ether 02:42:50:41:f1:09  txqueuelen 0  (Ethernet)
              RX packets 13  bytes 1775 (1.7 KiB)
              RX errors 0  dropped 0  overruns 0  frame 0
              TX packets 174  bytes 40644 (39.6 KiB)
              TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
      eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
              ether b8:27:eb:fd:40:7d  txqueuelen 1000  (Ethernet)
              RX packets 0  bytes 0 (0.0 B)
              TX packets 0  bytes 0 (0.0 B)
      lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
              inet 127.0.0.1  netmask 255.0.0.0
              inet6 ::1  prefixlen 128  scopeid 0x10<host>
              loop  txqueuelen 1000  (Local Loopback)
      veth0275d60: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 169.254.222.123  netmask 255.255.0.0  broadcast 169.254.255.255
              inet6 fe80::6069:90ff:fec9:a75a  prefixlen 64  scopeid 0x20<link>
              ether 62:69:90:c9:a7:5a  txqueuelen 0  (Ethernet)
              RX packets 13  bytes 1957 (1.9 KiB)
              TX packets 350  bytes 82319 (80.3 KiB)
      wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
              inet 192.168.43.78  netmask 255.255.255.0  broadcast 192.168.43.255
              inet6 fe80::fff4:43e5:edc6:cc9e  prefixlen 64  scopeid 0x20<link>
              ether b8:27:eb:a8:15:28  txqueuelen 1000  (Ethernet)
              RX packets 4833  bytes 3587709 (3.4 MiB)
              TX packets 4613  bytes 610563 (596.2 KiB)
      1. Tried to connect by a local Chromium to the MM server by entering the following addresses into browser’s address line:
      127.0.0.1:8080
      localhost:8080
      127.0.0.1:80
      localhost:80
      Got in browser:
      This site can’t be reached The connection was reset. ERR_CONNECTION_RESET
      1. Tried to connect from phone which is connected to the same WiFi network via browser by enetring to the Browser’s address line:
      192.168.43.78:8080
      192.168.43.78:80
      Result is the same,
      For reference, list of files and folders in home/pi/magic_mirror
      pi@raspberrypi:~/magic_mirror $ ls -R
      config  modules
      ./config:
      config.js  config.js.sample
      ./modules:
      default  node_modules  README.md
      ./modules/default:
      alert  calendar  clock  compliments  currentweather  defaultmodules.js  helloworld  newsfeed  updatenotification  weather  weatherforecast
      ./modules/default/alert:
      alert.js  classie.js  modernizr.custom.js  notificationFx.js  ns-default.css  README.md  translations
      ./modules/default/alert/translations:
      bg.json  da.json  de.json  en.json  es.json  fr.json  hu.json  nl.json  ru.json
      ./modules/default/calendar:
      calendar.css  calendarfetcher.js  calendar.js  debug.js  node_helper.js  README.md  vendor
      ./modules/default/calendar/vendor:
      ical.js
      ./modules/default/calendar/vendor/ical.js:
      example.js  ical.js  index.js  LICENSE  node-ical.js  NOTICE  package.json  readme.md  test
      ./modules/default/calendar/vendor/ical.js/test:
      test10.ics  test11.ics  test1.ics  test2.ics  test3.ics  test4.ics  test5.ics  test6.ics  test7.ics  test8.ics  test9.ics  test.js
      ./modules/default/clock:
      clock.js  clock_screenshot.png  clock_styles.css  faces  README.md
      ./modules/default/clock/faces:
      face-001.svg  face-002.svg  face-003.svg  face-004.svg  face-005.svg  face-006.svg  face-007.svg  face-008.svg  face-009.svg  face-010.svg  face-011.svg  face-012.svg
      ./modules/default/compliments:
      compliments.js  compliments_screenshot.png  README.md
      ./modules/default/currentweather:
      ./modules/default/helloworld:
      helloworld.js  helloworld.njk  README.md
      ./modules/default/newsfeed:
      fetcher.js  newsfeed.js  newsfeed_screenshot.png  node_helper.js  README.md  translations
      ./modules/default/newsfeed/translations:
      ./modules/default/updatenotification:
      node_helper.js  README.md  updatenotification.js
      ./modules/default/weather:
      current.njk  current.png  forecast.njk  forecast.png  providers  README.md  weather.css  weather.js  weatherobject.js  weatherprovider.js
      ./modules/default/weather/providers:
      darksky.js  openweathermap.js  README.md
      ./modules/default/weatherforecast:
      forecast_screenshot.png  README.md  weatherforecast.css  weatherforecast.js
      ./modules/node_modules:
      node_helper
      ./modules/node_modules/node_helper:
      index.js
      Could anyone advise what I am doing wrong here?
        sdetweil
        @Serge said in MM Server Mode in Docker on Raspberry:
        docker run -d
        –publish 80:8080 \
        is the container running?
        do
          docker ps
        because the docker run did
        docker run  -d \
        	--publish 80:8080 \
        the way to access is thru port 80 on the host machine…
        (no other app is trying to use port 80 already, right?, webserver)
        also,
        typically --volume doesn’t like relative file system links
        SergeS 1 Reply Last reply
        • SergeS
          Serge @sdetweil
          thanx. I have put into container RUN command direct links
          --volume /home/pi/magic_mirror/config
          instead of relative ones
          So the RUN command looked like:
          docker run  -d \
          --publish 80:8080 \
          --restart always \
          --volume /home/pi/magic_mirror/config:/opt/magic_mirror/config \
          --volume /home/pi/magic_mirror/modules:/opt/magic_mirror/modules \
          I also changed config, as I understood I should wrote port 80 there, so m,y config.js is the following:
          var config = {
              	port: 80,
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			position: "top_bar"
              			module: "clock",
          I have did once more all the steps
          Here is log from terminal
          pi@raspberrypi:/ $ docker run  -d \
          > --publish 80:8080 \
          > --restart always \
          37638fe6e1d0dee6b3ff9973c8ec7e2c7d6b0fa71b4c095e94738b197387074e
          pi@raspberrypi:/ $ docker ps
          CONTAINER ID        IMAGE                                       COMMAND                  CREATED             STATUS              PORTS                  NAMES
          37638fe6e1d0        bastilimbach/docker-magicmirror:raspberry   "/opt/docker-entrypo…"   11 seconds ago      Up 7 seconds        0.0.0.0:80->8080/tcp   magic_mirror
          pi@raspberrypi:/ $ cd /home/pi/magic_mirror/config
          pi@raspberrypi:~/magic_mirror/config $ sudo nano config.js
          pi@raspberrypi:~/magic_mirror/config $ cd /
                  inet6 fe80::5b8a:414d:261e:c2f3  prefixlen 64  scopeid 0x20<link>
                  ether 02:42:cf:fa:cf:16  txqueuelen 0  (Ethernet)
                  RX packets 12  bytes 1601 (1.5 KiB)
                  TX packets 170  bytes 28294 (27.6 KiB)
          veth2d3c6a7: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                  inet 169.254.32.50  netmask 255.255.0.0  broadcast 169.254.255.255
                  inet6 fe80::ef51:3415:a096:b052  prefixlen 64  scopeid 0x20<link>
                  ether 9a:4f:36:79:b3:72  txqueuelen 0  (Ethernet)
                  RX packets 4  bytes 651 (651.0 B)
                  TX packets 127  bytes 19147 (18.6 KiB)
                  RX packets 13597  bytes 14840294 (14.1 MiB)
                  TX packets 11414  bytes 1524830 (1.4 MiB)
          37638fe6e1d0        bastilimbach/docker-magicmirror:raspberry   "/opt/docker-entrypo…"   About a minute ago   Up About a minute   0.0.0.0:80->8080/tcp   magic_mirror
          pi@raspberrypi:/ $
          When I trying to reach through
          localhost:80, 127.0.0.1:80 the browser returns
          This site can’t be reached The connection was reset.Try:
          Checking the connection
          Checking the proxy and the firewall
          When I am trying to reach through the address
          localhost:8080, 127.0.0.1:8080
          This site can’t be reached 127.0.0.1 refused to connect.
          Try: Checking the connection, Checking the proxy and the firewall
          ERR_CONNECTION_REFUSED
          So the errors are different (connection is reset and refused, respectively).
          What else should I check , @sdetweil could you please advice me?
            sdetweil @Serge
            @Serge ok, so you changed the magicmirror config to use port 80 inside the container
            your run command -p should be
            -p host_port:container_port
            so
            -p 80:80
            requests to the host port 80 are forwarded to the container port 80
            to make sure that MM in the container is working
            do
            docker inspect 37638fe6e1d0 | grep -i -m 1 \"ipaddress
            and look for the ip address assigned to the container
            should be
            "IPAddress": "172.17.0.???
            ??? is most likely 2
            then use your local system browser to go to
            http://172.17.0.???:80
            skipping the port forwarding
