    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 34.7k Views 26 Watching
    • I Offline
      Ihnen42
      Hi, the region bottom bar has four elements. The bottom bar, the bottom left, the bottom center and the bottom right. Since they are in a grid with thirds, one always get pushed to the next row. Since I only use the bottom bar and not the left/center/right I changed the grid-template-columns: 100% 0% 0% 0%; So the bar is 100% and the rest each 0%.
      • E Offline
        earlman
        HI GUYS,
        Sorry I’ve been MIA. Recently moved to a new condo, so I’ve been busy with that. Finally have some time to take a look at this, so expect some updates in the near future.
        Thank you all for the interest ☺
        • E Offline
          earlman @dbinott
          @dbinott @jcmd13 @RuKeBo @Mykle1
          Add
          .top.bar > .container {
              grid-column: 1 / -1;
          to your main.css.
          I think that’ll do the trick. I don’t have any modules with notifications installed atm, so if somebody could post a screenshot of how that looks (after adding the above CSS), it would be a big help
          • E Offline
            earlman
            @aarish could you post some screenshots?
            I’ve updated the main.css file here:
            https://github.com/foundations-design/WhiteLight/blob/master/css/main.css
            I think the part that’s relevant to your issue is from “Layout Stuff” down (line 144 in the main.css file)
              BravoOscar @earlman
              @earlman
              As you can see, the top_bar and bottom_bar dosent work.
              The calender should be in the bottom_bar and the stock should be in the top_bar
              • E Offline
                earlman
                @bravooscar
                thanks for the screenshot. try using this css for your main.css
                :root {
                    /**** COLOR ****/
                    --color-text: #fff;
                    --color-background: black;
                    /**** TYPOGRAPHY ****/
                    --font-primary: "Roboto Condensed";
                    --font-secondary: "Roboto";
                    --base: 20px;
                    --text-scale: 1.5;
                    --text-xs: calc(var(--base) / var(--text-scale));
                    --text-sm: var(--base);
                    --text-md: calc(var(--text-sm) * var(--text-scale));
                    --text-lg: calc(var(--text-md) * var(--text-scale));
                    --text-xl: calc(var(--text-lg) * var(--text-scale));
                    --text-2xl: calc(var(--text-xl) * var(--text-scale));
                    --text-3xl: calc(var(--text-2xl) * var(--text-scale));
                    /**** SPACING ****/
                    --grid-gap: 1rem;
                    --outside-margin: 4rem;
                html {
                  cursor: none;
                  overflow: hidden;
                  background: var(--color-background);
                  user-select: none;
                  font-size: var(--base);
                ::-webkit-scrollbar {
                  display: none;
                body {
                  color: var(--color-text);
                  font-family: var(--font-primary), sans-serif;
                  font-weight: 400;
                  line-height: 1.5;
                  margin: 0;
                  -webkit-font-smoothing: antialiased;
                 * Default styles.
                .dimmed {
                  opacity: 0.4;
                .normal {
                  opacity: 0.7;
                .bright {
                  opacity: 1;
                .xsmall {
                  font-size: var(--text-xs);
                  line-height: 1.4;
                .small {
                  font-size: var(--text-sm);
                  line-height: 1.4;
                .medium {
                  font-size: calc(var(--text-md));
                  line-height: 1.4;
                .large {
                  font-size: calc(var(--text-lg));
                  line-height: 1;
                .xlarge {
                  font-size: calc(var(--text-xl));
                  line-height: 1;
                  letter-spacing: -3px;
                .thin {
                  font-family: var(--font-secondary), sans-serif;
                  font-weight: 100;
                .light {
                  font-weight: 300;
                .regular {
                  font-weight: 400;
                .bold {
                  font-weight: 700;
                .align-right {
                  text-align: right;
                .align-left {
                  text-align: left;
                header {
                  text-transform: uppercase;
                  font-size: 1rem;
                  font-family: var(--font-primary), Arial, Helvetica, sans-serif;
                  font-weight: 400;
                  border-bottom: 1px solid #666;
                  line-height: 15px;
                  padding-bottom: 5px;
                  margin-bottom: 10px;
                  color: #999;
                sup {
                  font-size: 50%;
                  line-height: 50%;
                 * Module styles.
                .module {
                  margin-bottom: 30px;
                .region.bottom .module {
                  margin-top: 30px;
                  margin-bottom: 0;
                .no-wrap {
                  white-space: nowrap;
                  overflow: hidden;
                  text-overflow: ellipsis;
                .pre-line {
                  white-space: pre-line;
                 * LAYOUT STUFF
                .region {
                  width: 100%;
                .region.fullscreen {
                  position: absolute;
                  height: 100vh;
                  width: 100vw;
                  top: 0;
                  left: 0;
                  right: 0;
                  bottom: 0;
                  z-index: -1;
                  pointer-events: none;
                .region.fullscreen * {
                  pointer-events: auto;
                .region table {
                  width: 100%;
                  border-spacing: 0;
                  border-collapse: separate;
                body {
                  display: grid;
                  grid-gap: var(--grid-gap);
                  grid-template-rows: repeat(5, minmax(0, max-content));
                  padding: var(--outside-margin);
                  place-items: stretch;
                  height: 100vh;
                .top.bar {
                  display: grid;
                  grid-template-columns: repeat(3, 1fr);
                .bottom.bar {
                  display: grid;
                .bottom.bar > .container {
                .left {
                  grid-column: 1 / 2;
                .right {
                  grid-column: -1 / -2;
                .region {
                  /* for testing */
                  /* border: 1px solid white;  */
                  BravoOscar @earlman
                  @earlman
                  Tryed the new main.css
                  Stock i working, it should be “top_bar”.
                  Calender should be position: “bottom_bar”, under travle time, but bottom_bar is over bottom_left, bottom_center and bottom_right
                  • E Offline
                    earlman @BravoOscar
                    @bravooscar
                    try this:
                    :root {
                      /**** COLOR ****/
                      --color-text: #fff;
                      --base: 20px;
                      --text-scale: 1.5;
                      /**** SPACING ****/
                      --grid-gap: 1rem;
                    html {
                      cursor: none;
                      overflow: hidden;
                      user-select: none;
                      display: none;
                    body {
                      font-weight: 400;
                      line-height: 1.5;
                      margin: 0;
                     * Default styles.
                    .dimmed {
                      opacity: 0.4;
                    .normal {
                      opacity: 0.7;
                    .bright {
                      opacity: 1;
                    .xsmall {
                      line-height: 1.4;
                    .small {
                      line-height: 1.4;
                    .medium {
                      line-height: 1.4;
                    .large {
                      line-height: 1;
                    .xlarge {
                      line-height: 1;
                    .thin {
                      font-weight: 100;
                    .light {
                      font-weight: 300;
                    .regular {
                      font-weight: 400;
                    .bold {
                      font-weight: 700;
                    .align-right {
                      text-align: right;
                    .align-left {
                      text-align: left;
                    header {
                      font-size: 1rem;
                      font-weight: 400;
                      line-height: 15px;
                      color: #999;
                    sup {
                      font-size: 50%;
                      line-height: 50%;
                     * Module styles.
                    .module {
                      margin-top: 30px;
                      margin-bottom: 0;
                    .no-wrap {
                      overflow: hidden;
                    .pre-line {
                     * LAYOUT STUFF
                    .region {
                      width: 100%;
                      position: absolute;
                      height: 100vh;
                      width: 100vw;
                      top: 0;
                      left: 0;
                      right: 0;
                      bottom: 0;
                      z-index: -1;
                    .region table {
                      width: 100%;
                      border-spacing: 0;
                    body {
                      display: grid;
                      height: 100vh;
                    .top.bar {
                      display: grid;
                    .bottom.bar {
                      display: grid;
                      grid-row: 2;
                    .bottom.bar > .bottom {
                        grid-row: 1;
                    .left {
                      grid-column: 1 / 2;
                    .right {
                    /* for testing */
                    .region {
                      aarish
                      This post is deleted!
                        aarish
                        @earlman The redesign looks really cool and I love the concept you are going for. I wanted to try it on my mirror however I could not access the notion page with the set up instructions as it says I don’t have access. Is their another place with the instruction?
                        • 4 / 5
