MMM-Facial-Recognition-Tools - No windowing system
Hi there.
A few days ago I startet my MagicMirror Project. So far its been gooing great, but now I want to insert facial recognition to trigger modules, I dont seem to get it work.
I’ve done the training and it seemed to have worked, but when I try testing my results by
python facerecognition.py, I’ll get the following error and I have no idea, how to fix it.Using FACE_ALGORITM: 1 Loading training data... Training data loaded! No windowing system, writing face.jpg image Traceback (most recent call last): File "facerecognition.py", line 153, in <module> clean_shutdown() TypeError: clean_shutdown() takes exactly 2 arguments (0 given)I am very new to linux, so please bear with me. I will try and provide any needed information.
Setup:
raspberry pi 3 b+
RPI JT CAM P50
Raspbian Stretch with desktopI thank all of you in advance.
Kind regards.
Toexelchen -
Is there noone with an idea or a pointer in the right direction?
@toexelchen
I thinkNo windowing system, writing face.jpg imagemeans that you runing the tool in a terminal which have no window. Means he can’t open a window to show you the output of the camera, in this case he will only capture a photo and save it toface.jpg.File "facerecognition.py", line 153, in clean_shutdown() TypeError: clean_shutdown() takes exactly 2 arguments (0 given)This error looks like a problem in the module itself.
def clean_shutdown(signum, frame):They need two arguments, this looks like a function which are used as a callback and he try to run it directly without any parameters.
Do you use Phyton 3? Maybe you use the old one and that can’t handle that.
I use https://github.com/normyx/MMM-Facial-Recognition-OCV3 which include this module and another. Maybe you should try this, it has a good how to. It works well on my Mirror.
I hope i helped you.
Kind Regards,
Thierry -
Hey Thierry
I am so sorry for not replying any sooner. For some reason (I blame human error on my part), I did not realize, someone has answered my question. Ill give OCV3 a try and will let you know if it works as soon as possible.
Thank you very much for taking the time, replying to my post.
Cheers,
Carsten -
@toexelchen
Hi Carsten. You can also use my module :)https://forum.magicmirror.builders/topic/10674/mmm-face-reco-dnn-all-new-face-recognition
