    Mirror not working after upgrading to v2.7.0
    6 Posts 2 Posters 2.2k Views 2 Watching
    • I Offline
      icripps
      after i upgraded to v2.7.0 i get the following errors after i start the mirror using “npm start”
      and then black screen.
      npm start
      magicmirror@2.7.1 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.7.1
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      Module helper loaded: MMM-ModuleScheduler
      Module helper loaded: MMM-PIR-Sensor
      Module helper loaded: MMM-NOAA3
      Module helper loaded: MMM-SystemStats
      Module helper loaded: MMM-AssistantMk2
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘./snowboy/lib/node/index.js’
      App threw an error during load
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:11:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:234:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
      at Module.load (internal/modules/cjs/loader.js:620:32)
      Whoops! There was an uncaught exception…
      { Error: Cannot find module ‘./snowboy/lib/node/index.js’
      at Module.load (internal/modules/cjs/loader.js:620:32) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
      Shutting down server…
      Stopping module helper: updatenotification
      Stopping module helper: calendar
      Stopping module helper: MMM-ModuleScheduler
      Stopping module helper: MMM-PIR-Sensor
      Stopping module helper: MMM-NOAA3
      Stopping module helper: MMM-SystemStats
      Stopping module helper: MMM-AssistantMk2
        sdetweil @icripps
        @icripps u need to run npm install.
        And again in every module folder that has a package.json file
        • I Offline
          icripps @sdetweil
          @sdetweil after i did npm install i get the following:
          npm install
          magicmirror@2.7.1 install /home/pi/MagicMirror
          cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“arm”})
          audited 219 packages in 15.167s
          found 5 vulnerabilities (4 low, 1 high)
          run npm audit fix to fix them, or npm audit for details
          magicmirror@2.7.1 postinstall /home/pi/MagicMirror
          sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          magicmirror@2.7.1 install-fonts /home/pi/MagicMirror
          cd fonts && npm install
          audited 1 package in 3.223s
          found 0 vulnerabilities
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          audited 2440 packages in 76.299s
          found 13 vulnerabilities (6 low, 6 moderate, 1 high)
          pi@raspberrypi:~/MagicMirror $ ^C
          pi@raspberrypi:~/MagicMirror $ npm audit fix
          updated 1 package in 48.461s
          fixed 1 of 13 vulnerabilities in 2440 scanned packages
          2 package updates for 12 vulns involved breaking changes
          (use npm audit fix --force to install breaking changes; or refer to npm audit for steps to fix these manually)
          pi@raspberrypi:~/MagicMirror $ npm install
          audited 219 packages in 15.816s
          audited 1 package in 2.231s
          audited 2440 packages in 78.438s
          found 12 vulnerabilities (6 low, 5 moderate, 1 high)
            sdetweil @icripps
            @icripps yeh, wish they hadn’t added the vulnerability checking.
            So, move on to each module folder that gas a package.json and do it again.
            Repeat
            • I Offline
              icripps @sdetweil
              @sdetweil i tried npm install in each of the moudules directory but i get the same error about snowboy and AMK2 . i removed those modules from my config.js files and the mirror started without a problem.
              do i have to remove the MMM-hotword and Amk2 and reinstall them?
                sdetweil @icripps
                @icripps for hotword there is a set of instructions in it’s readme about working thru this kind of problem.
                Will work for amk2 as well.
