    Errors after python capture.py
    1 Posts 1 Posters 619 Views 1 Watching
      SdeGeata
      Re: Facial Recognition Module - Step by Step Guide
      I have followed all the directives here, but pull two errors upon trying to train:
      #1
      pi@raspberrypi:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ pip install -r requirements.txt
      Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
      Collecting future (from -r requirements.txt (line 1))
        Using cached https://www.piwheels.org/simple/future/future-0.17.1-py3-none-any.whl
      Installing collected packages: future
      ERROR: Could not install packages due to an EnvironmentError: [Errno 13] Permission denied: '/usr/local/lib/python3.5/dist-packages/libpasteurize'
      Consider using the `--user` option or check the permissions.
      #2
      pi@raspberrypi:~/MagicMirror/modules/MMM-Facial-Recognition-Tools $ python capture.py
      Traceback (most recent call last):
        File "capture.py", line 18, in <module>
          import lib.capture as capture
        File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/capture.py", line 21, in <module>
          from . import config
        File "/home/pi/MagicMirror/modules/MMM-Facial-Recognition-Tools/lib/config.py", line 15, in <module>
          (CV_MAJOR_VER, CV_MINOR_VER, mv1, mv2) = cv2.__version__.split(".")
      ValueError: need more than 3 values to unpack
      Can you help???
