    Execute shell commands when AssistantMk2 starts or stops
    4 Posts 3 Posters 1.5k Views 3 Watching
      acimail01
      Hello,
      I have the modules MMM-Hotword and MMM-AssistantMk2 installed. And it works that far.
      Now I want to execute a shell command when the wizard starts to speak and execute another shell command when the wizard is quit.
      How should I proceed?
      • ? Offline
        A Former User @acimail01
        @acimail01
        There is no usable point about “Response starting”, usually "ASSISTANT_UNDERSTOOD" notification or "ASSISTANT_ACTIVATED" notification could be used for that purpose, but not exactly same time with Starting audio response
        For ending, you can use "ASSISTANT_RESPONSE_END"
        With those notifications, you can make your own module to receive those notifications and to do your own job, Or,…
        You can use MMM-NotificationTrigger which be already built for translate and chain notifications among the modules. It can execute external shell script.
        S A 2 Replies Last reply Reply Quote 0
          sdetweil @Guest
          on linux you can replace the command being executed to play audio with a shell script of the same name (and rename the old file and call it from the script) and then add your own behavior.
            acimail01 @Guest
            @Sean said in Execute shell commands when AssistantMk2 starts or stops:
            TANT_RESPONSE_END
            thank you!
            MMM-NotificationTrigger did the trick.
              module: "MMM-NotificationTrigger",
                triggers:[
                    trigger: "ASSISTANT_RESPONSE_END",
                    fires: [{ fire:"MY_COMMAND1", exec: "sleep 1; ls -al" },],
                    trigger: "ASSISTANT_UNDERSTOOD",
                    fires: [{ fire:"MY_COMMAND2", exec: "sleep 1; ls -h" },],
