    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    UNSOLVED MMM-GooglePhotos Update Notification
    Troubleshooting
    • T
      teedubyeah last edited by
      Good Afternoon all, I’m getting a notification stating “Update available for MMM-GooglePhotos moduls…” how to I update?
      • T
        I performed a get pull and relaunched MM and I get nothing but a blank screen.
          sdetweil @teedubyeah last edited by
          @teedubyeah after the git pull, you need to do npm install like after the original clone
          • T
            This post is deleted!
            • T
              teedubyeah @sdetweil last edited by
              This is what I’m getting when I do what you told me to do.
              git pull
              Updating 6acc084..157f007
              Fast-forward
               auth.js      | 2 +-
               package.json | 2 +-
               2 files changed, 2 insertions(+), 2 deletions(-)
              npm install
              added 1 package from 1 contributor, removed 1 package and audited 474 packages in 14.769s
              found 2 moderate severity vulnerabilities
                run `npm audit fix` to fix them, or `npm audit` for details
              sh run-start.sh
              Starting MagicMirror: v2.7.1
              Loading config ...
              Loading module helpers ...
              WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/open/index.js:29
              ...options
              SyntaxError: Unexpected token ...
                  at createScript (vm.js:53:10)
                  at Object.runInThisContext (vm.js:95:10)
                  at Module._compile (module.js:543:28)
                  at Object.Module._extensions..js (module.js:580:10)
                  at Module.load (module.js:488:32)
                  at tryModuleLoad (module.js:447:12)
                  at Function.Module._load (module.js:439:3)
                  at Module.require (module.js:498:17)
                  at require (internal/module.js:20:19)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:6:13)
              App threw an error during load
              ...options
              ...options
              Launching application.
