    MMM-Clap
    25 Posts 4 Posters 8.0k Views 2 Watching
    • Cr4z33C Offline
      Cr4z33 @Guest
      @Sean
      npm start
      > magicmirror@2.8.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Clap
      Module helper loaded: MMM-WatchDog
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-RTSPStream
      Module helper loaded: MMM-AssistantMk2
      Module helper loaded: MMM-Spotify
      Module helper loaded: MMM-DarkSkyForecast
      Module helper loaded: MMM-PushBulletNotifications
      Module helper loaded: MMM-Hotword
      All module helpers loaded.
      You're using a full whitelist configuration to allow for all IPs
      Server started ...
      Connecting socket for: MMM-Clap
      Connecting socket for: MMM-WatchDog
      Starting module helper: MMM-WatchDog
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-RTSPStream
      PM2: Stopping all OMXPlayer Streams...
      Starting module: newsfeed
      Connecting socket for: MMM-AssistantMk2
      Connecting socket for: MMM-Spotify
      [SPOTIFY_AUTH] Token is fresh.
      Connecting socket for: MMM-DarkSkyForecast
      ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      Connecting socket for: MMM-PushBulletNotifications
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Launching application.
      WatchDog started. Maximum timeout: 10s.
      Create new news fetcher for url: https://eur.fxexchangerate.com/usd.xml - Interval: 300000
      Create new news fetcher for url: https://www.ansa.it/sito/notizie/topnews/topnews_rss.xml - Interval: 300000
      Create new news fetcher for url: https://www.ansa.it/sito/notizie/mondo/mondo_rss.xml - Interval: 300000
      Create new news fetcher for url: https://feeds.hwupgrade.it/rss_hwup.xml - Interval: 300000
      Create new news fetcher for url: http://feeds.feedburner.com/hd-blog?format=xml - Interval: 300000
      Create new news fetcher for url: https://www.tomshw.it/feed/ - Interval: 300000
      Create new news fetcher for url: https://www.punto-informatico.it/feed/ - Interval: 300000
      Create new news fetcher for url: http://www.lecceprima.it/rss/ - Interval: 300000
      Create new news fetcher for url: http://www.galatina.it/rss.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [MMM-PushBulletNotifications][Info] 12:24:12.329 - START received
      [CLAP] Starts.
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [MMM-PushBulletNotifications][Info] 12:24:15.355 - PushBullet connected
      ^CShutting down server...
      Stopping module helper: MMM-Clap
      Stopping module helper: MMM-WatchDog
      Shutting down MMM-RTSPStream streams that were using vlc
      Stopping module helper: updatenotification
      Stopping module helper: newsfeed
      Stopping module helper: MMM-AssistantMk2
      Stopping module helper: MMM-Spotify
      Stopping module helper: MMM-DarkSkyForecast
      Stopping module helper: MMM-PushBulletNotifications
      Stopping module helper: MMM-Hotword
      [HOTWORD] Final Result: { detected: false }
      [HOTWORD] begins.
      • ? Offline
        A Former User @Cr4z33
        @Cr4z33
        You are using MMM-Clap & MMM-Hotword at a same time. Have you 2 mics?
        Or you should control taking & releasing the mic between modules. I don’t recommend.
        • Cr4z33C Offline
          Cr4z33 @Guest
          @Sean I’ve got one USB mic.
          Sorry I am not sure you gave me the solution. :smiling_face_with_open_mouth_cold_sweat:
          Say again?
          • ? Offline
            @Cr4z33
            MMM-Clap and MMM-Hotword will compete each other to take one mic. I think you’d better to use just one module. At least one module at a time. You can make juggling with CLAP_RESUME, CLAP_PAUSE, HOTWORD_RESUME, HOTWORD_PAUSE to confirm only one module uses a mic at a time. But too complex. not recommended.
              smarthome @Guest
              @Sean
              The scenario is:
              Step 1: Clap action
              Step 2: Clap sound detected, MMM Clap send output notification to MMM Page Selector while Mic still not released yet
              Step 3: MMM Page Selector receive input notification then change page
              Step 4: MMM Page Selector sends output notification CLAP_PAUSE to MMM Page Selector to release the MIC and waitting for next clap sound
              • ? Offline
                A Former User @smarthome
                @smarthome said in MMM-Clap:
                Step 1: Clap action
                In this real usage, You don’t need to release mic at all. MMM-Page-Selector doesn’t use any mic. So why do you need to release mic for changing pages? Mic Releasing is needed only when your other module wants to use the same Mic (like MMM-AssistantMk2). Unless you set restart:false, MMM-Clap will be restarted automatically after detection regardless other module’s job.
                And If you REALLY want to have a feature - sending some specific notification from specific module -, request module creator to do so. But with this case, I don’t think it needs.
                • ? Offline
                  A Former User @Guest
                  @smarthome
                  @Sean said in MMM-Clap:
                  Fortunately(???) There is already a solution about this;
                  As far as I know MMM-Page-Selector could emit PAGE_CHANGED notification.
                  All you need is to translate that notification to what you need. And MMM-NotificationTrigger module could do that job.
                  • Cr4z33C Offline
                    Cr4z33 @Guest
                    @Cr4z33
                    Oh now I got it.
                    Thanks however I will then keep using MMM-Hotwords.
                    Too precious for my voice command needs hehe. 😁
                      smarthome @Guest
                      @Sean
                      I’d already, but didn’t work
                      		  module: "MMM-NotificationTrigger",
                      		  //This module works in Background, so you don't need to describe `position`.
                      			useWebhook: false, // If you want to activate webhook as Notification emitter, set true. (eg. IFTTT)
                      			triggers:[ // Array of triggers.
                      				trigger: "PAGE_CHANGED", //REQUIRED
                      				triggerSenderFilter: (sender) => { //OPTIONAL should return true or false
                      				  if (sender == "MMM-Page-Selector") {
                      					return true
                      				  return false
                      				triggerPayloadFilter: (payload) => { //OPTIONAL should return true or false
                      				  if (typeof payload.value !== 'undefined' && payload.value > 0) {
                      					return true
                      				  return false
                      				fires: [ // Array of fires. You can enable multi-firing with one trigger.
                      					fire:"CLAP_RESUME", //REQUIRED
                      					payload: (payload) => { //OPTIONAL. transform received payload to what your target module wants.
                      					  return payload
                      		 //           delay: 1000, //OPTIONAL, if this is set, your outgoing notification will be fired after delay.
                      		 //           exec: "ls -l" //OPTIONAL, if exists, this script will be executed, and the result will be returned with "OUTGOING_NOTIFICATION_RESULT" and payload.  Can also be specified as a function which accepts the payload as an argument and returns the command to execute.
                      • ? Offline
                        @smarthome
                        Repeating again; Why do you need CLAP_RESUME/CLAP_PAUSE on page changing? Without them the module will work. I’m a little embarrassed to understand why you need it.
                        • 2 / 3
