    Problems with Config.js on Pi4 BlackScreen
    24 Posts 2 Posters 9.5k Views 2 Watching
    • D
      dazza120
      Hi there seems to be a problem with the config.js on the Pi 4 running MagicMirror 2.8.0 this a clean copy of both Buster and the MagicMirror. when i edit the Config file it Black Screens after Pm2 Restart MagicMirror, i can go back into config and Undo the text that i put in but it still black screens after restart, i have also copied over the sample config to replace everything in the config file and then pm2 restart MagicMirror still get a black screen. When ever i alter the config from stock it stops working. Now my saved Config file that was working on 2.7.1 is now toast where I’ve been looking for answers there it appears it is MagicMirror’s fault or Buster implementation of MM. Anyone still up and running on Buster and the New 2.8.0 MM. So kind of confirmed i saved the original config file and overwrite the altered one and its just blackscreen on restart, only one package is installed and that is mmm-nest-status and that isn’t in the config file so it shouldn’t present any issues but i think the new MM isn’t playing nice with Buster on the Pi4
        sdetweil @dazza120
        @dazza120 ok, let’s stop pm2
        pm2 list
        pm2 stop 0
        Go to the MagicMirror folder
        Then
        npm start dev
        In the developers window, select the console tab and scroll up to see any errors.
        • D
          dazza120
          Could this be the problem? Never been any issues with the pi 3 on Rasbian, and thank you sir offering to help much appreciated
          npm ERR! path /home/pi/package.json
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2019-07-13T16_51_46_205Z-debug.log
            sdetweil @dazza120
            @dazza120 must be in the MagicMirror folder for npm start
            • D
              dazza120 @sdetweil
              @sdetweil hi im getting the dev window then into console bet there is nothing at all in there just > So what do i have to run in the dev window is it cd MagicMirrior then pm2 start MagicMirrior? im lost just work dam you mirror lol
                sdetweil @dazza120
                @dazza120 pm2 runs the DEFINITION named x. It doesn’t care about folder.
                The setup typically uses the pm2_MagicMirror.json file in installers, or the mm.sh there as well.
                mm.sh has a bug, it uses ~ to mark ‘current user’, but when start on boot, the user is root, not pi. So the startup fails. My new installer fixes that.
                So, edit mm.sh and change the path to
                /home/pi/MagicMirror
                • D
                  dazza120 @sdetweil
                  @sdetweil its in that path already but it is completely empty. should it contain text?
                    sdetweil @dazza120
                    @dazza120 sorry, what is “it’s”?
                    • D
                      dazza120 @sdetweil
                      @sdetweil /home/pi/MagicMirror The mm.sh should it contain text?
                        sdetweil @dazza120
                        @dazza120 sorry… what is completely empty? mm.sh is in installers folder
                        • D
                          dazza120 @sdetweil
                          @sdetweil i unhide my files and one is in the location i said with no text and the other is in installer as you said with text
                            sdetweil @dazza120
                            @dazza120 remove the one in MagicMirror… useless
                            Fix the one in installers
                            • D
                              dazza120 @sdetweil
                              @sdetweil ok done, what to do now. ive just copied the installer one and overwrite the magic mirror path one
                                sdetweil @dazza120
                                @dazza120 which one does pm2 want to use? I am not near my computer so can’t get the list of pm2 commands.
                                pm2 – help
                                Did u edit the path in mm.sh?
                                • D
                                  dazza120 @sdetweil
                                  @sdetweil no i mearly placed it in the magicmirror folder path. its set to Cd /MagicMirror folder already and pm2 -help isnt displaying a list of pm2 commands
                                    sdetweil @dazza120
                                    @dazza120 inside needs to be
                                    cd /home/pi/MagicMirror
                                    DISPLAY=:0 npm start
                                    • D
                                      dazza120 @sdetweil
                                      @sdetweil changed it what now mate
                                        sdetweil @dazza120
                                        @dazza120 did u try pm2 now?
                                        • D
                                          dazza120 @sdetweil
                                          @sdetweil pm2 start or the dev thing?
                                            sdetweil @dazza120
                                            @dazza120
                                            Let’s get npm start dev working
