    Problem with sending socket notification to module
    8 Posts 3 Posters 2.4k Views 3 Watching
    • P Offline
      PerBa
      (sorry if this is a re-post, I made a post but couldn’t find it later. Admin can remove this post if needed)
      Hello,
      I’m new to MagicMirror, but I have a problem with two swedish modules:
      MMM-SL-PublicTransport
      MMM-Weather-SMHI-Hourly
      When I’m using them I get the same problem:
      Notifications from module to helper works fine
      Notifications from helper to module does not work (notifications never received).
      I don’t know how to handle this problem. I’ve spent a day with debug logs now, but I’m nowhere close to a solution.
      I would be so happy if someone with knowledge about the communication procedures could look into these two modules and see if they perhaps haven’t been updated after a “core-functionality” change.
      Thanks,
      Per Badlund, Sweden
        sdetweil @PerBa
        @PerBa can u show your code in node helper to send?
        Usually the problem is that the ‘this’ pointer is inside some API callback, and not pointing to the node_helper instance.
        ‘this’ is always troublesome.
        That is why many module save ‘this’ at start time in ‘self’ and use ‘self’ instead of ‘this’
        • P Offline
          PerBa
          Re: Problem with sending socket notification to module
          The line of code that sends the notification is:
          getDepartures: function () {
          var self = this;
          self.sendSocketNotification('DEPARTURES', CurrentDeparturesArray);
          the corresponding code in the module is:
          socketNotificationReceived: function (notification, payload) {
          	Log.info('MODULE:: received notification');
          	Log.info("Received Notification" + notification);
                  if (notification === 'DEPARTURES') {
          Thanks!
            sdetweil @PerBa
            @PerBa
            var self = this;
            Careful. getDepartures is not called by mm, so it’s very likely that ‘this’ is NOT pointing to the node_module instance.
            Save ‘this’ when u get the 1st socketnotification only. Just once.
            • P Offline
              PerBa
              Thanks for the help!
              I don’t know what happend, but I forgot to turn off the Pi during the night. This morning the Pi had crashed. I did a power-toggle and now one of the modules (the one I cleaned up regarding the “this-self”) is working.
              I must look more into this.
              Update: I now know what is behind the problem!!!
              After a power toggle everything works OK. But when I stop and restart the MagicMirror using
              pm2 stop mm
              and
              pm2 start mm
              The modules stop working.
              Does anybody know a better way of restarting the Magic Mirror?
              I must be able to do that in order to test the changes I do to the configuration…
              S D 3 Replies Last reply Reply Quote 0
                sdetweil @PerBa
                @PerBa I do this start/stop a hundred times a day without problem.
                I kill all the node processes
                I don’t use pm2
                  dazza120 @PerBa
                  @PerBa is this a Pi4 or Buster? Seems to be loads of issues with one of these. @sdetweil is the man to help though
                    sdetweil @PerBa
                    @PerBa any update?
