Trouble with mmm-nest-status on pi4 with 2.8.0
@michael5r im having issues with this beautyful module you created apon npm install it kills everything and leads to a black screen only way to fix it is to redownload MM. Here is the code that i get this is two different installs the first one is with the module config added and npm install done on the module after npm install the MM is always blackscreen
pi@raspberrypi:~ $ cd MagicMirror/modules pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/BenRoe/MMM-SystemStats Cloning into 'MMM-SystemStats'... remote: Enumerating objects: 22, done. remote: Counting objects: 100% (22/22), done. remote: Compressing objects: 100% (14/14), done. remote: Total 231 (delta 10), reused 16 (delta 8), pack-reused 209 Receiving objects: 100% (231/231), 88.08 KiB | 578.00 KiB/s, done. Resolving deltas: 100% (122/122), done. pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SystemStats pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ npm install npm notice created a lockfile as package-lock.json. You should commit this file. added 1 package from 1 contributor and audited 1 package in 1.265s found 0 vulnerabilities pi@raspberrypi:~/MagicMirror/modules/MMM-SystemStats $ cd pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ npm run config:check > magicmirror@2.8.0 config:check /home/pi/MagicMirror > node tests/configs/check_config.js Checking file... /home/pi/MagicMirror/config/config.js Your configuration file doesn't contain syntax errors :) pi@raspberrypi:~/MagicMirror $ cd modules pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git Cloning into 'mmm-nest-status'... remote: Enumerating objects: 135, done. remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135 Receiving objects: 100% (135/135), 65.27 KiB | 718.00 KiB/s, done. Resolving deltas: 100% (77/77), done. pi@raspberrypi:~/MagicMirror/modules $ cd mmm-nest-status pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ npm install npm WARN deprecated undefined@0.1.0: this package has been deprecated npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm notice created a lockfile as package-lock.json. You should commit this file. npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json' npm WARN modules No description npm WARN modules No repository field. npm WARN modules No README data npm WARN modules No license field. removed 1 package in 1.141s found 0 vulnerabilities pi@raspberrypi:~/MagicMirror/modules/mmm-nest-status $ cd pi@raspberrypi:~ $ pm2 restart MagicMirror Use --update-env to update environment variables [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌─────────────┬────┬──────┬────────┬───┬─────┬──────────┐ │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │ ├─────────────┼────┼──────┼────────┼───┼─────┼──────────┤ │ MagicMirror │ 0 │ fork │ online │ 2 │ 0% │ 2.5 MB │ └─────────────┴────┴──────┴────────┴───┴─────┴──────────┘ Use `pm2 show <id|name>` to get more details about an app pi@raspberrypi:~ $ npm run config:check npm ERR! path /home/pi/package.json npm ERR! code ENOENT npm ERR! errno -2 npm ERR! syscall open npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json' npm ERR! enoent This is related to npm not being able to find a file. npm ERR! enoent npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-07-13T20_08_21_703Z-debug.logpi@raspberrypi:~ $ cd MagicMirror/modules pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/michael5r/mmm-nest-status.git Cloning into 'mmm-nest-status'... remote: Enumerating objects: 135, done. remote: Total 135 (delta 0), reused 0 (delta 0), pack-reused 135 Receiving objects: 100% (135/135), 65.27 KiB | 586.00 KiB/s, done. Resolving deltas: 100% (77/77), done. pi@raspberrypi:~/MagicMirror/modules $ cd pi@raspberrypi:~ $ cd MagicMirror pi@raspberrypi:~/MagicMirror $ npm run check:config npm ERR! missing script: check:config npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-07-13T20_44_54_553Z-debug.log pi@raspberrypi:~/MagicMirror $ pm2 restart MagicMirror Use --update-env to update environment variables [PM2] Applying action restartProcessId on app [MagicMirror](ids: 0) [PM2] [MagicMirror](0) ✓ ┌─────────────┬────┬──────┬────────┬───┬─────┬──────────┐ │ Name │ id │ mode │ status │ ↺ │ cpu │ memory │ ├─────────────┼────┼──────┼────────┼───┼─────┼──────────┤ │ MagicMirror │ 0 │ fork │ online │ 3 │ 0% │ 2.4 MB │ └─────────────┴────┴──────┴────────┴───┴─────┴──────────┘ Use `pm2 show <id|name>` to get more details about an app pi@raspberrypi:~/MagicMirror $Complete file found in .npm
0 info it worked if it ends with ok 1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'run', 'config:check' ] 2 info using npm@6.10.1 3 info using node@v10.15.2 4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig) 5 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/package.json' 6 verbose cwd /home/pi 7 verbose Linux 4.19.57-v7l+ 8 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "run" "config:check" 9 verbose node v10.15.2 10 verbose npm v6.10.1 11 error path /home/pi/package.json 12 error code ENOENT 13 error errno -2 14 error syscall open 15 error enoent ENOENT: no such file or directory, open '/home/pi/package.json' 16 error enoent This is related to npm not being able to find a file. 17 verbose exit [ -2, true ] -
@michael5r no issues regarding mmm-nest-status as i was also installing NPM in that module which it doesn’t need. That was mucking it up not the module
