    config,js beginner
    20 Posts 6 Posters 8.0k Views 6 Watching
      berne
      i am new to this, dont have a problem…(yet)
      but i just install a modul and now i have some text that i need to get in config.
      but i dont understand whear i can paste it. It contains so much ()()( on all strange thing, i just have the standard config,
      sholde i use a some program, thaht will make it alot easyer.
      Regard
          module: "MMM-NowPlayingOnSpotify",
              showCoverArt: false,
              clientID: "<YOUR_CLIENT_ID>",
              clientSecret: "<YOUR_CLIENT_SECRET>",
              accessToken: "<YOUR_ACCESS_TOKEN>",
              refreshToken: "<YOUR_REFRESH_TOKEN>"
      idoodlerI 1 Reply Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @berne
        Hi @berne welcome on board!
        You are editing a Javascript file. You can basically use any decent text editor to edit this file, however some will mallform the file. Thats why I recogmend you something like Notepad++, or Visual Studio Code.
        You just have to add this somewhere in the modules array (An array is a list of things)
        For example:
                module: "alert",
                    clientID: "",
                    clientSecret: "",
                    accessToken: "",
                    refreshToken: ""
                module: "updatenotification",
                position: "top_bar"
        Note, there must be a , character after the last } if this isn’t the last module. You can easily validate your changes by using a Javascript Linter.
          berne
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
                  showCoverArt: true,
                  clientID: "",
                  clientSecret: "",
                  accessToken: "",
                  refreshToken: ""
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "2665018",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "YOUR_OPENWEATHER_API_KEY"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "Aftonbladet",
          						url: "http://www.aftonbladet.se/nyheter/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
          i have download the visual Studio code, i have done this, donw know if its right or not. Well see what javascipt linter is telling me…cross you finger:D
          i did something wrong, i think, i have edit the code, looks good?
          regard
          • idoodlerI Offline
            @berne You have one extra } before the updatenotification module.
            Here is the corrected config:
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            			module: "alert",
            				showCoverArt: true,
                            		clientID: "",
            				clientSecret: "",
            				accessToken: "",
            				refreshToken: ""
            			position: "top_bar"
            			module: "clock",
            			module: "newsfeed",
            				feeds: [
              berne
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			position: "bottom_right",
              				showCoverArt: true,
                              		clientID: "c162a50685084953913d4fc247758a9e",
              				clientSecret: "d464b761e3c849a3846d087a96739d0c",
              				accessToken: "BQCJP0CGFThDfAv6p8my-fkZJQjPUoQN3nBYnV4Q-jtdVRtjcx3mCaDnX9QpSKD4YfXgSVAWh3vU_Mpij_9NpyrN1KK_6lv93Ffz3IkJqUiX31WQmJXzsIatawIhTbbqx0KLdP0qK-qFQx_MKuvSrUSB",
              				refreshToken: "AQCJi17nSbRBpLbfjH6M2t-6x2FIrBlqiHC4cctLslmIj1STMwj1pTH7JJ8TUvHIonlEnogyKqltqD3KxfYzOml4PUiW-fyFHcaPhLeRTVNwyz3DtCjFblIggtYwUkF6wk0QJw"
              			position: "top_bar"
              			module: "clock",
              			header: "Kalender",
              						url: "https://calendar.google.com/calendar/ical/berntsson88%40gmail.com/public/basic.ics"					}
              				appid: "cb3ba3fb9618b6f6de3fbbb9ee78284e"
              				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
              			module: "newsfeed",
              				feeds: [
              					        title: "Macworld",
                                                              url: "http://feeds.idg.se/idg/FPjt",
              i got Spotify to work, the weather is not working and not the RSS feed, i tyde to add one more to newfeed, but it sems like i mess up my config.
              i toke a code and paste in to: jslint.com thats @idoodler did fix for me, got lots of error.
              How are u guys doing?
              if i change one thing i am messing somting up, i just what something to contoll the code, before i use in config.
              idoodlerI S 2 Replies Last reply Reply Quote 0
              • idoodlerI Offline
                @berne You do have one error remove the lonley ] but keep the ],.
                In addition, the linter you is way to sensitive, try the one I posted, or simply use Visual Studio codes Intelisense, it will automatically show you errors…
                Linter: https://jshint.com/
                  sdetweil @berne
                  @berne
                  every module looks lie this
                     module:"name",
                     position: " pos",
                     header: "????",
                  try to make sure the [ and { line up
                  inside the config the same [, { and comma pattern
                  one tricky thin is onside arrays (lists of things), when the things are groups like calendar and rss feed
                  there needs to be a comma after the LAST entry too
                  			header: "Kalender",
                  					}    // < ----- missing comma
                  using jslint is a pain… you need to check a bunch of things on the bottom of the page,
                  else get lots of useless errors,… single quotes, whitespace,
                  • idoodlerI Offline
                    idoodler Module Developer @sdetweil
                    @sdetweil There is no comma needed after the last entry, a comma is only needed if an object is followed by another object, a comma after a last object is not mandatory.
                      berne
                      102 Expected ‘}’ to match ‘{’ from line 90 and instead saw ‘]’.
                      108 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
                      109 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘]’.
                      109 Missing semicolon.
                      109 Unrecoverable syntax error. (94% scanned).
                      okej, igot this,
                      we can take 102 dose that mean i just need to swap to }?
                      109 i have no ide what that translate :S
                      S idoodlerI 2 Replies Last reply Reply Quote 0
                        sdetweil @idoodler
                        @idoodler yeh, i can never tell… some modules use the extra comma , some don’t … looked thru my config and it has one everyplace… doesn’t hurt…
                          sdetweil @berne
                          @berne on 101 u have ] and then on 102 u have another ]
                          use a good editor Notepad++ on windows… it will show you the matching ( { and [ with ], } and )
                          • idoodlerI Offline
                            @berne
                            • Expected '}' to match '{' from line 90 and instead saw ']'.
                              • Remove the ] in the line above (Line 101) This will validate your config you can ignore the other warnings.
                              berne @sdetweil
                              @sdetweil but can i trust https://jshint.com/
                              and do what it saying to get it right, like 102
                              just swap ] to }’ on 102
                              i what to learn… but is really hard, i Appreciate you time and @idoodler too
                              mumblebajM evroomE 2 Replies Last reply Reply Quote 0
                              • idoodlerI Offline
                                @berne I recomend you to to checkout the structure of the existing config.js file.
                                You may also check out the W3Schools documentation: https://www.w3schools.com/js/js_objects.asp
                                • mumblebajM Offline
                                  mumblebaj Module Developer @berne
                                  @berne Can you paste your config.js? We can then have a look to see if it is correct and point to where you may have to make the changes.
                                  As @sdetweil pointed out, a good text editor like notepad++ would show you the matching “{” and “}” etc.
                                  • evroomE Online
                                    evroom @berne
                                    @berne
                                    I wrote a small post on this topic.
                                    JSON is supposed to be easy and straightforward, but when there is nested data it can get quite complex.
                                    https://forum.magicmirror.builders/topic/9712/cannot-add-modules/14
                                    MagicMirror version: 2.35.0
                                    Test environment:
                                    MagicMirror version: 2.36.0-develop
                                      sdetweil @evroom
                                      @evroom and each module gets to customize the config to their needs, so no two look alike… (to the beginners)
                                      • O Offline
                                        otto
                                        I am thinking about install this
                                        https://github.com/dolanmiu/MMM-awesome-alexa/blob/master/README.md
                                        But I don’t have a pi button, do I really need that?
                                        Can’t I jut lay say -Alexa light the magic mirror
                                          berne
                                          @mumblebaj
                                          This is my config now, is it looking right? i havet dare to past in to the config,js berfore some one can tell me its right
                                           * MIT Licensed.
                                          var config = {
                                          	port: 8080,
                                          	language: "en",
                                          	timeFormat: 24,
                                          	units: "metric",
                                          			module: "alert",
                                          				showCoverArt: true,
                                                          		clientID: "XXXXXXXX",
                                          				clientSecret: "XXXXXXXX",
                                          				accessToken: "XXXXXXXXX",
                                          				refreshToken: "XXXXXXXX"
                                          			  module: 'MMM-awesome-alexa',
                                          			position: 'bottom_bar',
                                          			  wakeWord: 'Smart Mirror',
                                          			        clientId: 'XXXXXXX',
                                          			    clientSecret: 'XXXXXX',
                                          			    deviceId: 'Magic_Mirror',
                                          			    refreshToken: 'XXXXXXX',
                                          			    lite: false,
                                          			    isSpeechVisualizationEnabled: true
                                          			position: "top_bar"
                                          			module: "clock",
                                          			header: "Kalender",
                                          			module: "newsfeed",
                                          				feeds: [
                                          					        title: "Macworld",
                                            @berne You are missing a comma after the closing bracket of MMM-awesome-alexa. It should be },
