    config,js beginner
    20 Posts 6 Posters 7.2k Views 6 Watching
    • idoodlerI Offline
      idoodler Module Developer @berne
      @berne You do have one error remove the lonley ] but keep the ],.
      In addition, the linter you is way to sensitive, try the one I posted, or simply use Visual Studio codes Intelisense, it will automatically show you errors…
      Linter: https://jshint.com/
        sdetweil @berne
        @berne
        every module looks lie this
           module:"name",
           position: " pos",
           header: "????",
        try to make sure the [ and { line up
        inside the config the same [, { and comma pattern
        one tricky thin is onside arrays (lists of things), when the things are groups like calendar and rss feed
        there needs to be a comma after the LAST entry too
        			header: "Kalender",
        						symbol: "calendar-check",
        						url: "https://calendar.google.com/calendar/ical/berntsson88%40gmail.com/public/basic.ics"
        					}    // < ----- missing comma
        using jslint is a pain… you need to check a bunch of things on the bottom of the page,
        else get lots of useless errors,… single quotes, whitespace,
        idoodlerI 1 Reply Last reply Reply Quote 0
        • idoodlerI Offline
          idoodler Module Developer @sdetweil
          @sdetweil There is no comma needed after the last entry, a comma is only needed if an object is followed by another object, a comma after a last object is not mandatory.
            berne
            102 Expected ‘}’ to match ‘{’ from line 90 and instead saw ‘]’.
            108 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
            109 Expected ‘}’ to match ‘{’ from line 11 and instead saw ‘]’.
            109 Missing semicolon.
            109 Unrecoverable syntax error. (94% scanned).
            okej, igot this,
            we can take 102 dose that mean i just need to swap to }?
            109 i have no ide what that translate :S
            S idoodlerI 2 Replies Last reply Reply Quote 0
              sdetweil @idoodler
              @idoodler yeh, i can never tell… some modules use the extra comma , some don’t … looked thru my config and it has one everyplace… doesn’t hurt…
                sdetweil @berne
                @berne on 101 u have ] and then on 102 u have another ]
                use a good editor Notepad++ on windows… it will show you the matching ( { and [ with ], } and )
                • idoodlerI Offline
                  @berne
                  • Expected '}' to match '{' from line 90 and instead saw ']'.
                    • Remove the ] in the line above (Line 101) This will validate your config you can ignore the other warnings.
                    berne @sdetweil
                    @sdetweil but can i trust https://jshint.com/
                    and do what it saying to get it right, like 102
                    just swap ] to }’ on 102
                    i what to learn… but is really hard, i Appreciate you time and @idoodler too
                    mumblebajM evroomE 2 Replies Last reply Reply Quote 0
                    • idoodlerI Offline
                      @berne I recomend you to to checkout the structure of the existing config.js file.
                      You may also check out the W3Schools documentation: https://www.w3schools.com/js/js_objects.asp
                      • mumblebajM Offline
                        mumblebaj Module Developer @berne
                        @berne Can you paste your config.js? We can then have a look to see if it is correct and point to where you may have to make the changes.
                        As @sdetweil pointed out, a good text editor like notepad++ would show you the matching “{” and “}” etc.
