config,js beginner
20 Posts 6 Posters 5.7k Views 6 Watching
  • S Online
    sdetweil @berne
    @berne on 101 u have ] and then on 102 u have another ]
    use a good editor Notepad++ on windows… it will show you the matching ( { and [ with ], } and )
    B 1 Reply Last reply Jul 19, 2019, 5:07 PM Reply Quote 0
    • I Offline
      idoodler Module Developer @berne
      @berne
      • Expected '}' to match '{' from line 90 and instead saw ']'.
        • Remove the ] in the line above (Line 101) This will validate your config you can ignore the other warnings.
        berne @sdetweil
        @sdetweil but can i trust https://jshint.com/
        and do what it saying to get it right, like 102
        just swap ] to }’ on 102
        i what to learn… but is really hard, i Appreciate you time and @idoodler too
        M E 2 Replies Last reply Jul 19, 2019, 5:49 PM Reply Quote 0
        • I Offline
          @berne I recomend you to to checkout the structure of the existing config.js file.
          You may also check out the W3Schools documentation: https://www.w3schools.com/js/js_objects.asp
            mumblebaj Module Developer @berne
            @berne Can you paste your config.js? We can then have a look to see if it is correct and point to where you may have to make the changes.
            As @sdetweil pointed out, a good text editor like notepad++ would show you the matching “{” and “}” etc.
            • E Offline
              evroom @berne
              @berne
              I wrote a small post on this topic.
              JSON is supposed to be easy and straightforward, but when there is nested data it can get quite complex.
              https://forum.magicmirror.builders/topic/9712/cannot-add-modules/14
              MagicMirror version: 2.30.0
              Test environment:
              MagicMirror version: v2.30.0
              S 1 Reply Last reply Jul 19, 2019, 6:30 PM Reply Quote 0
              • S Online
                sdetweil @evroom
                @evroom and each module gets to customize the config to their needs, so no two look alike… (to the beginners)
                • O Offline
                  otto
                  I am thinking about install this
                  https://github.com/dolanmiu/MMM-awesome-alexa/blob/master/README.md
                  But I don’t have a pi button, do I really need that?
                  Can’t I jut lay say -Alexa light the magic mirror
                    berne
                    @mumblebaj
                    This is my config now, is it looking right? i havet dare to past in to the config,js berfore some one can tell me its right
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    			module: "alert",
                    	           module: "MMM-NowPlayingOnSpotify",
                    			position: "bottom_right",
                    				showCoverArt: true,
                                    		clientID: "XXXXXXXX",
                    				clientSecret: "XXXXXXXX",
                    				accessToken: "XXXXXXXXX",
                    				refreshToken: "XXXXXXXX"
                    			  module: 'MMM-awesome-alexa',
                    			position: 'bottom_bar',
                    			  wakeWord: 'Smart Mirror',
                    			        clientId: 'XXXXXXX',
                    			    clientSecret: 'XXXXXX',
                    			    deviceId: 'Magic_Mirror',
                    			    refreshToken: 'XXXXXXX',
                    			    lite: false,
                    			    isSpeechVisualizationEnabled: true
                    		module: "updatenotification",
                    			position: "top_bar"
                    			module: "clock",
                    			position: "top_left"
                    			header: "Kalender",
                    						symbol: "calendar-check",
                    						url: "https://calendar.google.com/calendar/ical/berntsson88%40gmail.com/public/basic.ics"					}
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "currentweather",
                    				locationID: "2665018",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    				appid: "cb3ba3fb9618b6f6de3fbbb9ee78284e"
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "Aftonbladet",
                    						url: "http://www.aftonbladet.se/nyheter/rss.xml"
                    					        title: "Macworld",
        url: "http://feeds.idg.se/idg/FPjt",
                    				showSourceTitle: true,
                    				showPublishDate: true,
                    				broadcastNewsFeeds: true,
                    				broadcastNewsUpdates: true
                    M 1 Reply Last reply Aug 13, 2019, 4:38 PM Reply Quote 0
                      @berne You are missing a comma after the closing bracket of MMM-awesome-alexa. It should be },
