    new update/upgrade script, ready for testing
    328 Posts 27 Posters 655.1k Views 24 Watching
    • evroomE Offline
      evroom @sdetweil
      @sdetweil said in new update/upgrade script, ready for testing:
      I decided to forget about alias altogether…
      Of course, your script, your call.
      Just keep it somewhere in the back of your head, should you stumble over it again in any way or form.
      As I minimum I learned something new, including using alias in a script at all.
      Thanks for the scripts and the help you provide to all users with fresh install and / or upgrade issues, including myself.
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
        sdetweil @evroom
        @evroom thanks for your help… I had learned about the shell options to expand aliases about 10 yrs ago, and forgot… my systems all run with it on.
        • spitzlbergerjS Offline
          spitzlbergerj Project Sponsor Module Developer @sdetweil
          now it worked, my MagicMirror is on the current version :smiling_face_with_open_mouth_smiling_eyes: :thumbs_up: .
          Many, many thanks for your patient help. It was a somewhat more difficult birth. But the end is good and so everything
          I have a lot of respect for you, who created such a complex script and patiently provides support. Thank you very much!
          One last question:
          During the update there was another message:
          npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
          Is there anything else I should do?
          Regards
          Josef
          http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
            sdetweil @spitzlbergerj
            @spitzlbergerj said in new update/upgrade script, ready for testing:
            yes, sadly we tested for a few months and this didn’t happen… weird…
            on the warnings… really nothing u can do as a user… the code author should update
            but hasn’t…
            spitzlbergerjS 1 Reply Last reply Reply Quote 0
              @sdetweil thank you very much again!
              Regards
              Josef
              • H Offline
                hoogveld
                After wrecking my MM installation after the second last update I used this script. It worked fine for me!!!
                Thanks for all your work!
                  Pi4 - 4Gb = Worked flawlessly. January 12, 2020 @ 2020 hours. NYC - USA
                  • T Offline
                    Tigershroffr
                    kindly also mention on which part and module you have update the script
                      sdetweil @Tigershroffr
                      @Tigershroffr sorry. Not quite sure what u are asking
                      • BKeyportB Online
                        BKeyport Module Developer
                        Update script not working for MMM-CalendarExt2 update. Is it me or you?
                        Test run using:
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                        seems to walk through modules correctly. Live run
                        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                        does not.
                        Upgrade started - Tue Jan 28 14:25:31 PST 2020
                        system is Linux pihole 4.19.75-v7l+ #1270 SMP Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux
                        the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                        doing test run = true
                        saving custom.css
                        remote name = origin
                        upgrading from version 2.10.1 to 2.10.1
                        fetching latest revisions
                        git fetch rc=0
                        current branch = master
                        On branch master
                        Your branch is up to date with 'origin/master'.
                        Changes not staged for commit:
                          (use "git add <file>..." to update what will be committed)
                          (use "git checkout -- <file>..." to discard changes in working directory)
                        	modified:   package-lock.json
                        Untracked files:
                          (use "git add <file>..." to include in what will be committed)
                        	css/save_custom.css
                        no changes added to commit (use "git add" and/or "git commit -a")
                        there are 1 local files that are different than the master repo
                           package-lock.json
                        save/restore files selection = n
                        restoring package-lock.json from repo
                        skipping restore for package-lock.json, doing test run
                        test merge result rc='' , if empty, no conflicts
                        skipping merge, only test run
                        processing dependency changes for active modules with package.json files
                        processing for module MMM-CalendarExt2 please wait
                        skipped processing for MMM-CalendarExt2, doing test run
                        processing complete for module MMM-CalendarExt2
                        processing for module MMM-DarkSkyForecast please wait
                        skipped processing for MMM-DarkSkyForecast, doing test run
                        processing complete for module MMM-DarkSkyForecast
                        processing for module MMM-DHT-Sensor please wait
                        skipped processing for MMM-DHT-Sensor, doing test run
                        processing complete for module MMM-DHT-Sensor
                        processing for module MMM-RTSPStream please wait
                        skipped processing for MMM-RTSPStream, doing test run
                        processing complete for module MMM-RTSPStream
                        processing for module MMM-Remote-Control please wait
                        skipped processing for MMM-Remote-Control, doing test run
                        processing complete for module MMM-Remote-Control
                        restoring custom.css
                        removing git alias
                        Upgrade ended - Tue Jan 28 14:25:40 PST 2020
                        Upgrade started - Tue Jan 28 14:25:46 PST 2020
                        user requested to apply changes
                        doing test run = false
                        saving custom.css
                        local version 2.10.1 already same as master 2.10.1
                        removing git alias
                        Upgrade ended - Tue Jan 28 14:25:47 PST 2020
                        screen on live run is:
                        the log will be /home/pi/MagicMirror/installers/upgrade.log
                        No LSB modules are available.
                        update log will be in /home/pi/MagicMirror/installers/upgrade.log
                        saving custom.css
                        • 25
                        • 26
                        • 27
                        • 28
                        • 29
                        • 32
                        • 33
                        • 27 / 33
