    new update/upgrade script, ready for testing
    328 Posts 27 Posters 729.7k Views 24 Watching
    • G Offline
      gonzonia @sdetweil
      Thanks for trying. I appreciate all the support you provide the MM community.
      pi@MagicMirror2:~ $ sudo apt-get update
      sudo apt-get install nodejs -y
      Hit:1 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Reading package lists... Done
      Building dependency tree... Done
      Reading state information... Done
      nodejs is already the newest version (12.22.12~dfsg-1~deb11u4).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      pi@MagicMirror2:~ $
        sdetweil @gonzonia
        @gonzonia can u also do
        ls /etc/apt/sources.list.d
        thats where the other sources are
        and cat each file it mentions
        nodesource.list  raspi.list
        is what I see on the 64bit os
        • G Offline
          gonzonia @sdetweil
          pi@MagicMirror2:~ $ ls /etc/apt/sources.list.d
          pi@MagicMirror2:~ $ sudo cat /etc/apt/sources.list.d/nodesource.list
          deb [arch=arm64 Pin-Priority=600 signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
          pi@MagicMirror2:~ $ sudo cat /etc/apt/sources.list.d/raspi.list
          deb http://archive.raspberrypi.org/debian/ bullseye main
          # Uncomment line below then 'apt-get update' to enable 'apt-get source'
          #deb-src http://archive.raspberrypi.org/debian/ bullseye main
            sdetweil @gonzonia
            @gonzonia thanks… same as I see…
            • G Offline
              gonzonia @sdetweil
              I’m just going to rebuild. I’ll let you know if I hit any snags. Thanks again.
                Socrates
                Sorry to revive this old thread, but I used this script to update all my modules at once, and they worked perfectly after upgrading Node.js and npm.
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)”
                I have a question: Will this script automatically check for and apply module upgrades periodically? Or is it better to add it to a nightly crontab?
                  sdetweil @Socrates
                  @Socrates no… this script is only for the base.
                    sdetweil @Socrates
                    @Socrates note that without adding a parameter
                    The script does nothing. It only tests the ability to update the base MagicMirror
                    Update is two pass process
                    Test. Make no changes
                    Do. Apply the changes (with the parameter apply)
                    Many users have modified MagicMirror base code not knowing about the config and css file design. These changes block the ability to update normally
                    Over time they forget that they changed the files and what they actually changed. The force way to install is to wipe all changes, but now the result doesn’t work like it used to. Adding a lot of frustration.
                    • 13
                    • 14
                    • 15
                    • 16
                    • 17
                    • 17 / 17
