    new update/upgrade script, ready for testing
    328 Posts 27 Posters 724.4k Views 24 Watching
    • evroomE Online
      evroom @sdetweil
      @sdetweil said in new update/upgrade script, ready for testing:
      i remove the alias so, the output will not tell us anything…
      It will tell you if you get English as output, despite any language & variable settings.
      I temporary changed the locale to de_DE.utf8 for testing and git status gave me German output.
      Then I did LC_ALL=C git status and it replied in English.
      LC_MESSAGES=C git status continued to reply in German.
      Just FYI, perhaps it will help you, perhaps not :-)
      MagicMirror version: 2.37.0
        sdetweil @evroom
        @evroom said in new update/upgrade script, ready for testing:
        cool… thats what the test script does… sets alias for git to ‘LC_ALL=C git’
        I think I will just force alias
        evroomE 1 Reply Last reply Reply Quote 0
          sdetweil @spitzlbergerj
          @spitzlbergerj great, thanks… u can run the update script again now…
          if it says already at 2.10, the change the parm from apply to force
          • evroomE Online
            evroom @sdetweil
            Sam,
            for some reason your testlang.sh script, using alias, is still responding in German, whereas the plain command responses in English:
            pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
            Auf Branch master
            Ihr Branch ist auf demselben Stand wie 'origin/master'.
            pi@raspberrypi:~/MagicMirror $ LC_ALL=C git status
            On branch master
            Your branch is up to date with 'origin/master'.
            pi@raspberrypi:~/MagicMirror $ git status
            Auf Branch master
            Also interesting; using sh iso bash:
            pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | sh
            On branch master
            EDIT - recommendations / friendly advice:
            1/ Use #!/bin/bash in your script, not ~/bin/bash
            2/ Do not alias the git command, just plain LC_ALL=C git status
            I am on 2.10.0, but can try your testlang.sh script when needed.
            Will keep the language settings on German for a while.
              sdetweil @evroom
              @evroom thanks… I have multiple commands to issue, and wanted to use alias for it…
              thanks for the catch on #~…
              can u try the test script again?
              u can also look at the alias list , to make sure the one for git is set
              alias
              spitzlbergerjS 1 Reply Last reply Reply Quote 0
              • spitzlbergerjS Offline
                spitzlbergerj Project Sponsor Module Developer @evroom
                locale -a
                the output is:
                C
                C.UTF-8
                de_DE.utf8
                POSIX
                  spitzlbergerj Project Sponsor Module Developer @sdetweil
                  @sdetweil Hi, I run the script just now again. The output is the same I guess:
                  Auf Branch master
                  Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
                    (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                  Unversionierte Dateien:
                    (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                          core
                          installers/dumpactivemodules.js
                  nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
                    @spitzlbergerj don’t yah love it… what is supposed to work, doesn’t…
                    arg
                    sop I changed test script to do it your way… try it out
                      @sdetweil Sorry if I misunderstood something. Should I have corrected something on my own?
                      OK, I started the script again. Now the output is as follows:
                      On branch master
                      Your branch is behind 'origin/master' by 117 commits, and can be fast-forwarded.
                        (use "git pull" to update your local branch)
                      Untracked files:
                        (use "git add <file>..." to include in what will be committed)
                              core
                      nothing added to commit but untracked files present (use "git add" to track)
                      And the update script returns the following output:
                      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                      the log will be /home/pi/MagicMirror/installers/upgrade.log
                      No LSB modules are available.
                      doing test run = true
                      update log will be in /home/pi/MagicMirror/installers/upgrade.log
                      saving custom.css
                      upgrading from version 2.9.0 to 2.10.0
                      fetching latest revisions
                      processing dependency changes for active modules with package.json files
                      processing for module MMM-Remote-Control please wait
                      skipped processing for MMM-Remote-Control, doing test run
                      processing complete for module MMM-Remote-Control
                      processing for module MMM-NetworkScanner please wait
                      skipped processing for MMM-NetworkScanner, doing test run
                      processing complete for module MMM-NetworkScanner
                      processing for module MMM-DWD-WarnWeather please wait
                      skipped processing for MMM-DWD-WarnWeather, doing test run
                      processing complete for module MMM-DWD-WarnWeather
                      processing for module MMM-SystemStats please wait
                      skipped processing for MMM-SystemStats, doing test run
                      processing complete for module MMM-SystemStats
                      restoring custom.css
                      So it all worked out now, right?
                      Thanks for your help @sdetweil and @evroom
                        @spitzlbergerj said in new update/upgrade script, ready for testing:
                        all looks good… thank you so much for your time and patience…
                        but… the upgrader says u are still on 2.9… maybe a different folder? (as u said u were on 2.10 already)
                          This post is deleted!
                            @spitzlbergerj no attachment… send via mail… same ID as here on gmail
                            • evroomE Online
                              evroom @sdetweil
                              On branch master
                              Sam. I think the issue is, that the command is git status and you alias LC_ALL=C git to the name git, not the command git.
                              You cannot use the alias as a replacement for a part of your command, but I might be wrong.
                              I think the only solution is to check for language en_US and then for every git command either use plain git or else by using LC_ALL=C.
                              Or just use LC_ALL=C for every git call.
                                sdetweil @evroom
                                @evroom
                                i don’t understand this…
                                its been working fine for quite a few months, handling LC_ALL and LANGUAGE, just hs system has LANG too…
                                anyhow, alias is supposed to work on ‘commands’ issued, and replace the started command with the replacement string (once)
                                this is how the git doc suggested dealing with this issue and stackexchange posts over quite some time echoed it…
                                I changes to the ‘LC_ALL=C git’ approach anyhow
                                I don’t even check now, just do it… on english system, it doesn’t hurt
                                  no, I didn’t say I was on 2.10.
                                  i have now run the script in apply mode. The output is very long and apparently it was not updated, right?
                                  Link Text
                                  Sorry, I’ve always done the update via git. Now I am confused …
                                    @spitzlbergerj yes, please erase this file
                                    ~/MagicMirror/installers/dumpactivemodules.js
                                    it was copied early by the official updater in error
                                    • evroomE Online
                                      evroom @sdetweil
                                      It is always difficult creating something and having it run flawlessly on many different systems with their many different settings, some exotic :-)
                                      One more thing I stumbled upon when googling:
                                      shopt -s expand_aliases
                                      Add this before the alias command, or just at the top of your script.
                                      Seems to work.
                                        OK, now I have another problem :disappointed_face: . The upgrade script ran and I think it upgraded some stuff.
                                        At some point, I must have gotten my permissions mixed up. There were a number of directories that were root:root. Here there was Permission denied.
                                        I have now corrected the owners. But now the upgrade script doesn’t run anymore, because it assumes that I am already on 2.10.
                                        Can I force another upgrade?
                                          @spitzlbergerj yes, change ‘apply’ to ‘force’
                                            sdetweil @evroom
                                            @evroom I decided to forget about alias altogether…
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
