    328 Posts 27 Posters 716.6k Views 24 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer
      @sdetweil thanks for your great work. Unfortunately it does not work for me with the script.
      When I execute the script I get the following messages:
      bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      the log will be /home/pi/MagicMirror/installers/upgrade.log
      No LSB modules are available.
      doing test run = true
      saving custom.css
      upgrading from version 2.9.0 to 2.10.0
      fetching latest revisions
      fatal: Couldn't find remote ref origin
      MagicMirror git fetch failed
      restoring custom.css
      The log file also contains the following:
      not english or locale not set, set git alias
      alias git='LC_ALL=en_US.UTF-8 git'
      remote name = github-desktop-darkniki origin
      git fetch rc=128
      Should I update manually or is there another way with the script?
      Sepp
        sdetweil @spitzlbergerj
        @spitzlbergerj well, thats a new one…
        i try to find the upstream git repo this installation came from, and then get the changes from there,
        cause I want to be able to test the application of the changes without breaking the local system.
        can u do
        git remote
        and
        git remote -v
        thanks… it should be one word, but it looks like two on your system
          @spitzlbergerj could u try this little script to see if I got it right?
          curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
          it will check the status of the 3 lang settings,
          LANG=
          LANGUAGE=
          and LC_ALL=
            @sdetweil thanks for your Help. Here are the results
            git remote
            origin
            git remote -v
            github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (fetch)
            github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (push)
            origin  https://github.com/MichMich/MagicMirror.git (fetch)
            origin  https://github.com/MichMich/MagicMirror.git (push)
            and for the second post:
            Auf Branch master
            Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
              (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
            Unversionierte Dateien:
              (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                    core
                    installers/dumpactivemodules.js
            nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
            I hope this helps
            Regards
            Sepp
              @spitzlbergerj thx. Can u try the last command again
                Good Morning @sdetweil
                Here are the results from the just newly started command:
                alias git='LANG=en_US.UTF-8 git'
                Auf Branch master
                        core
                The result is the same as last night, right?
                Regards
                Sepp
                evroomE S 2 Replies Last reply Reply Quote 0
                • evroomE Offline
                  evroom @spitzlbergerj
                  @spitzlbergerj
                  Hi there, I do not want to interfere, as Sam is most capable, but can you give the output of this command?
                  locale -a
                  And tell if you see English or German output for those 2 commands?
                  LC_ALL=C git status
                  LC_MESSAGES=C git status
                  MagicMirror version: 2.37.0
                  S spitzlbergerjS 2 Replies Last reply Reply Quote 0
                    sdetweil @evroom
                    @evroom i remove the alias so, the output will not tell us anything…
                    I was hoping there was some priority of the settings…
                    LC_ALL doers override LANGUAGE…
                    but LANG doesn’t appear to be dynamically changeable per command
                    try the testlang script again, the locale doc says this should work…
                    • evroomE Offline
                      evroom @sdetweil
                      @sdetweil said in new update/upgrade script, ready for testing:
                      It will tell you if you get English as output, despite any language & variable settings.
                      I temporary changed the locale to de_DE.utf8 for testing and git status gave me German output.
                      Then I did LC_ALL=C git status and it replied in English.
                      LC_MESSAGES=C git status continued to reply in German.
                      Just FYI, perhaps it will help you, perhaps not :-)
                        sdetweil @evroom
                        @evroom said in new update/upgrade script, ready for testing:
                        cool… thats what the test script does… sets alias for git to ‘LC_ALL=C git’
                        I think I will just force alias
                          @spitzlbergerj great, thanks… u can run the update script again now…
                          if it says already at 2.10, the change the parm from apply to force
                          • evroomE Offline
                            evroom @sdetweil
                            Sam,
                            for some reason your testlang.sh script, using alias, is still responding in German, whereas the plain command responses in English:
                            pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                            Auf Branch master
                            Ihr Branch ist auf demselben Stand wie 'origin/master'.
                            pi@raspberrypi:~/MagicMirror $ LC_ALL=C git status
                            On branch master
                            Your branch is up to date with 'origin/master'.
                            pi@raspberrypi:~/MagicMirror $ git status
                            Auf Branch master
                            Also interesting; using sh iso bash:
                            pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | sh
                            On branch master
                            EDIT - recommendations / friendly advice:
                            1/ Use #!/bin/bash in your script, not ~/bin/bash
                            2/ Do not alias the git command, just plain LC_ALL=C git status
                            I am on 2.10.0, but can try your testlang.sh script when needed.
                            Will keep the language settings on German for a while.
                              sdetweil @evroom
                              @evroom thanks… I have multiple commands to issue, and wanted to use alias for it…
                              thanks for the catch on #~…
                              can u try the test script again?
                              u can also look at the alias list , to make sure the one for git is set
                              alias
                              spitzlbergerjS 1 Reply Last reply Reply Quote 0
                                spitzlbergerj Project Sponsor Module Developer @evroom
                                locale -a
                                the output is:
                                C
                                C.UTF-8
                                de_DE.utf8
                                POSIX
                                  spitzlbergerj Project Sponsor Module Developer @sdetweil
                                  @sdetweil Hi, I run the script just now again. The output is the same I guess:
                                  Auf Branch master
                                          core
                                    @spitzlbergerj don’t yah love it… what is supposed to work, doesn’t…
                                    arg
                                    sop I changed test script to do it your way… try it out
                                      @sdetweil Sorry if I misunderstood something. Should I have corrected something on my own?
                                      OK, I started the script again. Now the output is as follows:
                                      On branch master
                                      Your branch is behind 'origin/master' by 117 commits, and can be fast-forwarded.
                                        (use "git pull" to update your local branch)
                                      Untracked files:
                                        (use "git add <file>..." to include in what will be committed)
                                              core
                                      nothing added to commit but untracked files present (use "git add" to track)
                                      And the update script returns the following output:
                                      saving custom.css
                                      processing for module MMM-Remote-Control please wait
                                      skipped processing for MMM-Remote-Control, doing test run
                                      processing complete for module MMM-Remote-Control
                                      processing for module MMM-NetworkScanner please wait
                                      skipped processing for MMM-NetworkScanner, doing test run
                                      processing complete for module MMM-NetworkScanner
                                      processing for module MMM-DWD-WarnWeather please wait
                                      skipped processing for MMM-DWD-WarnWeather, doing test run
                                      processing complete for module MMM-DWD-WarnWeather
                                      processing for module MMM-SystemStats please wait
                                      skipped processing for MMM-SystemStats, doing test run
                                      processing complete for module MMM-SystemStats
                                      So it all worked out now, right?
                                      Thanks for your help @sdetweil and @evroom
                                        @spitzlbergerj said in new update/upgrade script, ready for testing:
                                        all looks good… thank you so much for your time and patience…
                                        but… the upgrader says u are still on 2.9… maybe a different folder? (as u said u were on 2.10 already)
                                            @spitzlbergerj no attachment… send via mail… same ID as here on gmail
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
