    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @spitzlbergerj
      @spitzlbergerj well, thats a new one…
      i try to find the upstream git repo this installation came from, and then get the changes from there,
      cause I want to be able to test the application of the changes without breaking the local system.
      can u do
      git remote
      and
      git remote -v
      thanks… it should be one word, but it looks like two on your system
        @spitzlbergerj could u try this little script to see if I got it right?
        curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
        it will check the status of the 3 lang settings,
        LANG=
        LANGUAGE=
        and LC_ALL=
        • spitzlbergerjS
          spitzlbergerj Project Sponsor Module Developer
          @sdetweil thanks for your Help. Here are the results
          git remote
          github-desktop-darkniki
          origin
          git remote -v
          github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (fetch)
          github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (push)
          origin  https://github.com/MichMich/MagicMirror.git (fetch)
          origin  https://github.com/MichMich/MagicMirror.git (push)
          and for the second post:
          not english or locale not set, set git alias
          alias git='LC_ALL=en_US.UTF-8 git'
          Auf Branch master
          Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
            (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
          Unversionierte Dateien:
            (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                  core
                  installers/dumpactivemodules.js
          nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
          I hope this helps
          Regards
          Sepp
            @spitzlbergerj thx. Can u try the last command again
            • spitzlbergerjS
              Good Morning @sdetweil
              Here are the results from the just newly started command:
              alias git='LANG=en_US.UTF-8 git'
              Auf Branch master
                      core
              The result is the same as last night, right?
              Regards
              Sepp
              evroomE S 2 Replies Last reply
              • evroomE
                evroom @spitzlbergerj
                @spitzlbergerj
                Hi there, I do not want to interfere, as Sam is most capable, but can you give the output of this command?
                locale -a
                And tell if you see English or German output for those 2 commands?
                LC_ALL=C git status
                LC_MESSAGES=C git status
                MagicMirror version: 2.37.0
                S spitzlbergerjS 2 Replies Last reply
                  sdetweil @evroom
                  @evroom i remove the alias so, the output will not tell us anything…
                  I was hoping there was some priority of the settings…
                  LC_ALL doers override LANGUAGE…
                  but LANG doesn’t appear to be dynamically changeable per command
                  try the testlang script again, the locale doc says this should work…
                  evroomE 1 Reply Last reply
                  • evroomE
                    evroom @sdetweil
                    @sdetweil said in new update/upgrade script, ready for testing:
                    It will tell you if you get English as output, despite any language & variable settings.
                    I temporary changed the locale to de_DE.utf8 for testing and git status gave me German output.
                    Then I did LC_ALL=C git status and it replied in English.
                    LC_MESSAGES=C git status continued to reply in German.
                    Just FYI, perhaps it will help you, perhaps not :-)
                      sdetweil @evroom
                      @evroom said in new update/upgrade script, ready for testing:
                      cool… thats what the test script does… sets alias for git to ‘LC_ALL=C git’
                      I think I will just force alias
                        @spitzlbergerj great, thanks… u can run the update script again now…
                        if it says already at 2.10, the change the parm from apply to force
                        • evroomE
                          evroom @sdetweil
                          Sam,
                          for some reason your testlang.sh script, using alias, is still responding in German, whereas the plain command responses in English:
                          pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                          Auf Branch master
                          Ihr Branch ist auf demselben Stand wie 'origin/master'.
                          pi@raspberrypi:~/MagicMirror $ LC_ALL=C git status
                          On branch master
                          Your branch is up to date with 'origin/master'.
                          pi@raspberrypi:~/MagicMirror $ git status
                          Auf Branch master
                          Also interesting; using sh iso bash:
                          pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | sh
                          On branch master
                          EDIT - recommendations / friendly advice:
                          1/ Use #!/bin/bash in your script, not ~/bin/bash
                          2/ Do not alias the git command, just plain LC_ALL=C git status
                          I am on 2.10.0, but can try your testlang.sh script when needed.
                          Will keep the language settings on German for a while.
                            sdetweil @evroom
                            @evroom thanks… I have multiple commands to issue, and wanted to use alias for it…
                            thanks for the catch on #~…
                            can u try the test script again?
                            u can also look at the alias list , to make sure the one for git is set
                            alias
                            spitzlbergerjS 1 Reply Last reply
                            • spitzlbergerjS
                              spitzlbergerj Project Sponsor Module Developer @evroom
                              locale -a
                              the output is:
                              C
                              C.UTF-8
                              de_DE.utf8
                              POSIX
                              • spitzlbergerjS
                                spitzlbergerj Project Sponsor Module Developer @sdetweil
                                @sdetweil Hi, I run the script just now again. The output is the same I guess:
                                Auf Branch master
                                        core
                                  @spitzlbergerj don’t yah love it… what is supposed to work, doesn’t…
                                  arg
                                  sop I changed test script to do it your way… try it out
                                  • spitzlbergerjS
                                    @sdetweil Sorry if I misunderstood something. Should I have corrected something on my own?
                                    OK, I started the script again. Now the output is as follows:
                                    On branch master
                                    Your branch is behind 'origin/master' by 117 commits, and can be fast-forwarded.
                                      (use "git pull" to update your local branch)
                                    Untracked files:
                                      (use "git add <file>..." to include in what will be committed)
                                            core
                                    nothing added to commit but untracked files present (use "git add" to track)
                                    And the update script returns the following output:
                                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                                    the log will be /home/pi/MagicMirror/installers/upgrade.log
                                    No LSB modules are available.
                                    doing test run = true
                                    saving custom.css
                                    upgrading from version 2.9.0 to 2.10.0
                                    fetching latest revisions
                                    processing for module MMM-Remote-Control please wait
                                    skipped processing for MMM-Remote-Control, doing test run
                                    processing complete for module MMM-Remote-Control
                                    processing for module MMM-NetworkScanner please wait
                                    skipped processing for MMM-NetworkScanner, doing test run
                                    processing complete for module MMM-NetworkScanner
                                    processing for module MMM-DWD-WarnWeather please wait
                                    skipped processing for MMM-DWD-WarnWeather, doing test run
                                    processing complete for module MMM-DWD-WarnWeather
                                    processing for module MMM-SystemStats please wait
                                    skipped processing for MMM-SystemStats, doing test run
                                    processing complete for module MMM-SystemStats
                                    restoring custom.css
                                    So it all worked out now, right?
                                    Thanks for your help @sdetweil and @evroom
                                      @spitzlbergerj said in new update/upgrade script, ready for testing:
                                      all looks good… thank you so much for your time and patience…
                                      but… the upgrader says u are still on 2.9… maybe a different folder? (as u said u were on 2.10 already)
                                      • spitzlbergerjS
                                          @spitzlbergerj no attachment… send via mail… same ID as here on gmail
                                          • evroomE
                                            evroom @sdetweil
                                            On branch master
                                            Sam. I think the issue is, that the command is git status and you alias LC_ALL=C git to the name git, not the command git.
                                            You cannot use the alias as a replacement for a part of your command, but I might be wrong.
                                            I think the only solution is to check for language en_US and then for every git command either use plain git or else by using LC_ALL=C.
                                            Or just use LC_ALL=C for every git call.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
