    328 Posts 27 Posters 740.6k Views 24 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @bdream
      @bdream
      Just open a new terminal and run the script. MM should not be running, I believe.
        panos
        Guys, I’m little confused.
        I currently running at v2.9 and I wish to upgrade to v2.10
        If I run the command:
        bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
        MM won’t update to v2.10
        If I try the ‘traditional’ way 'git pull && npm install’ and ignore any changes that I make I receive the error:
        The following untracked working tree files would be overwritten by merge: installers/dumpactivemodules.js
        see here:
        https://forum.magicmirror.builders/topic/11912/problem-with-updating-to-2-10-0-from-2-9-0-using-update-script/2
        Any suggestion on how to update to 2.10?
          sdetweil @panos
          @panos the official script has a bug. Erase that file and use the updated version.
          See
          https://forum.magicmirror.builders/topic/10859/new-update-upgrade-script-ready-for-testing
            bdream
            @sdetweil said in new update/upgrade script, ready for testing:
            See
            Sam, your link is looping or I’m wrong.
            Can you please provide the link to the right script again? Sorry I’m confused and not able to update the MM.
            cheers, bdream
              sdetweil @bdream
              @bdream the 1st post of this topic has the commands
                bdream
                it works :thumbs_up:
                Many thanks AGAIN Sam!
                cheers, bdream
                • spitzlbergerjS
                  spitzlbergerj Project Sponsor Module Developer
                  @sdetweil thanks for your great work. Unfortunately it does not work for me with the script.
                  When I execute the script I get the following messages:
                  bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                  the log will be /home/pi/MagicMirror/installers/upgrade.log
                  No LSB modules are available.
                  doing test run = true
                  saving custom.css
                  upgrading from version 2.9.0 to 2.10.0
                  fetching latest revisions
                  fatal: Couldn't find remote ref origin
                  MagicMirror git fetch failed
                  restoring custom.css
                  The log file also contains the following:
                  not english or locale not set, set git alias
                  alias git='LC_ALL=en_US.UTF-8 git'
                  remote name = github-desktop-darkniki origin
                  git fetch rc=128
                  Should I update manually or is there another way with the script?
                  Sepp
                  Regards
                  Josef
                  http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
                    sdetweil @spitzlbergerj
                    @spitzlbergerj well, thats a new one…
                    i try to find the upstream git repo this installation came from, and then get the changes from there,
                    cause I want to be able to test the application of the changes without breaking the local system.
                    can u do
                    git remote
                    and
                    git remote -v
                    thanks… it should be one word, but it looks like two on your system
                      @spitzlbergerj could u try this little script to see if I got it right?
                      curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                      it will check the status of the 3 lang settings,
                      LANG=
                      LANGUAGE=
                      and LC_ALL=
                      • spitzlbergerjS
                        @sdetweil thanks for your Help. Here are the results
                        git remote
                        origin
                        git remote -v
                        github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (fetch)
                        github-desktop-darkniki https://github.com/darkniki/MagicMirror.git (push)
                        origin  https://github.com/MichMich/MagicMirror.git (fetch)
                        origin  https://github.com/MichMich/MagicMirror.git (push)
                        and for the second post:
                        Auf Branch master
                        Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
                          (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                        Unversionierte Dateien:
                          (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                                core
                        nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
                        I hope this helps
                        Regards
                        Sepp
                        Regards
                        Josef
                          @spitzlbergerj thx. Can u try the last command again
                          • spitzlbergerjS
                            Good Morning @sdetweil
                            Here are the results from the just newly started command:
                            alias git='LANG=en_US.UTF-8 git'
                            Auf Branch master
                                    core
                            The result is the same as last night, right?
                            Regards
                            Sepp
                            Regards
                            Josef
                            evroomE S 2 Replies Last reply Reply Quote 0
                            • evroomE
                              evroom @spitzlbergerj
                              @spitzlbergerj
                              Hi there, I do not want to interfere, as Sam is most capable, but can you give the output of this command?
                              locale -a
                              And tell if you see English or German output for those 2 commands?
                              LC_ALL=C git status
                              LC_MESSAGES=C git status
                              MagicMirror version: 2.37.0
                              S spitzlbergerjS 2 Replies Last reply Reply Quote 0
                                sdetweil @evroom
                                @evroom i remove the alias so, the output will not tell us anything…
                                I was hoping there was some priority of the settings…
                                LC_ALL doers override LANGUAGE…
                                but LANG doesn’t appear to be dynamically changeable per command
                                try the testlang script again, the locale doc says this should work…
                                • evroomE
                                  evroom @sdetweil
                                  It will tell you if you get English as output, despite any language & variable settings.
                                  I temporary changed the locale to de_DE.utf8 for testing and git status gave me German output.
                                  Then I did LC_ALL=C git status and it replied in English.
                                  LC_MESSAGES=C git status continued to reply in German.
                                  Just FYI, perhaps it will help you, perhaps not :-)
                                    sdetweil @evroom
                                    @evroom said in new update/upgrade script, ready for testing:
                                    cool… thats what the test script does… sets alias for git to ‘LC_ALL=C git’
                                    I think I will just force alias
                                      @spitzlbergerj great, thanks… u can run the update script again now…
                                      if it says already at 2.10, the change the parm from apply to force
                                      • evroomE
                                        evroom @sdetweil
                                        Sam,
                                        for some reason your testlang.sh script, using alias, is still responding in German, whereas the plain command responses in English:
                                        pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                                        Auf Branch master
                                        Ihr Branch ist auf demselben Stand wie 'origin/master'.
                                        pi@raspberrypi:~/MagicMirror $ LC_ALL=C git status
                                        On branch master
                                        Your branch is up to date with 'origin/master'.
                                        pi@raspberrypi:~/MagicMirror $ git status
                                        Auf Branch master
                                        Also interesting; using sh iso bash:
                                        pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | sh
                                        On branch master
                                        EDIT - recommendations / friendly advice:
                                        1/ Use #!/bin/bash in your script, not ~/bin/bash
                                        2/ Do not alias the git command, just plain LC_ALL=C git status
                                        I am on 2.10.0, but can try your testlang.sh script when needed.
                                        Will keep the language settings on German for a while.
                                          sdetweil @evroom
                                          @evroom thanks… I have multiple commands to issue, and wanted to use alias for it…
                                          thanks for the catch on #~…
                                          can u try the test script again?
                                          u can also look at the alias list , to make sure the one for git is set
                                          alias
                                          spitzlbergerjS 1 Reply Last reply Reply Quote 0
                                          • spitzlbergerjS
                                            spitzlbergerj Project Sponsor Module Developer @evroom
                                            locale -a
                                            the output is:
                                            C
                                            C.UTF-8
                                            de_DE.utf8
                                            POSIX
                                            Regards
                                            Josef
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 12 / 17
