    328 Posts 27 Posters 696.9k Views 24 Watching
    • evroomE Offline
      evroom @spitzlbergerj
      @spitzlbergerj
      Hi there, I do not want to interfere, as Sam is most capable, but can you give the output of this command?
      locale -a
      And tell if you see English or German output for those 2 commands?
      LC_ALL=C git status
      LC_MESSAGES=C git status
      MagicMirror version: 2.35.0
      Test environment:
      MagicMirror version: 2.36.0-develop
      S spitzlbergerjS 2 Replies Last reply Reply Quote 0
        sdetweil @evroom
        @evroom i remove the alias so, the output will not tell us anything…
        I was hoping there was some priority of the settings…
        LC_ALL doers override LANGUAGE…
        but LANG doesn’t appear to be dynamically changeable per command
        try the testlang script again, the locale doc says this should work…
        • evroomE Offline
          evroom @sdetweil
          @sdetweil said in new update/upgrade script, ready for testing:
          It will tell you if you get English as output, despite any language & variable settings.
          I temporary changed the locale to de_DE.utf8 for testing and git status gave me German output.
          Then I did LC_ALL=C git status and it replied in English.
          LC_MESSAGES=C git status continued to reply in German.
          Just FYI, perhaps it will help you, perhaps not :-)
          Test environment:
            sdetweil @evroom
            @evroom said in new update/upgrade script, ready for testing:
            cool… thats what the test script does… sets alias for git to ‘LC_ALL=C git’
            I think I will just force alias
              sdetweil @spitzlbergerj
              @spitzlbergerj great, thanks… u can run the update script again now…
              if it says already at 2.10, the change the parm from apply to force
              • evroomE Offline
                evroom @sdetweil
                Sam,
                for some reason your testlang.sh script, using alias, is still responding in German, whereas the plain command responses in English:
                pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | bash
                Auf Branch master
                Ihr Branch ist auf demselben Stand wie 'origin/master'.
                pi@raspberrypi:~/MagicMirror $ LC_ALL=C git status
                On branch master
                Your branch is up to date with 'origin/master'.
                pi@raspberrypi:~/MagicMirror $ git status
                Auf Branch master
                Also interesting; using sh iso bash:
                pi@raspberrypi:~/MagicMirror $ curl -sL https://www.dropbox.com/s/80fevh39jme3iig/testlang.sh?dl=0 | sh
                On branch master
                EDIT - recommendations / friendly advice:
                1/ Use #!/bin/bash in your script, not ~/bin/bash
                2/ Do not alias the git command, just plain LC_ALL=C git status
                I am on 2.10.0, but can try your testlang.sh script when needed.
                Will keep the language settings on German for a while.
                Test environment:
                  sdetweil @evroom
                  @evroom thanks… I have multiple commands to issue, and wanted to use alias for it…
                  thanks for the catch on #~…
                  can u try the test script again?
                  u can also look at the alias list , to make sure the one for git is set
                  alias
                  spitzlbergerjS 1 Reply Last reply Reply Quote 0
                  • spitzlbergerjS Offline
                    spitzlbergerj Project Sponsor Module Developer @evroom
                    locale -a
                    the output is:
                    C
                    C.UTF-8
                    de_DE.utf8
                    POSIX
                      spitzlbergerj Project Sponsor Module Developer @sdetweil
                      @sdetweil Hi, I run the script just now again. The output is the same I guess:
                      Auf Branch master
                      Ihr Branch ist zu 'origin/master' um 117 Commits hinterher, und kann vorgespult werden.
                        (benutzen Sie "git pull", um Ihren lokalen Branch zu aktualisieren)
                      Unversionierte Dateien:
                        (benutzen Sie "git add <Datei>...", um die Änderungen zum Commit vorzumerken)
                              core
                              installers/dumpactivemodules.js
                      nichts zum Commit vorgemerkt, aber es gibt unversionierte Dateien (benutzen Sie "git add" zum Versionieren)
                        @spitzlbergerj don’t yah love it… what is supposed to work, doesn’t…
                        arg
                        sop I changed test script to do it your way… try it out
                          @sdetweil Sorry if I misunderstood something. Should I have corrected something on my own?
                          OK, I started the script again. Now the output is as follows:
                          On branch master
                          Your branch is behind 'origin/master' by 117 commits, and can be fast-forwarded.
                            (use "git pull" to update your local branch)
                          Untracked files:
                            (use "git add <file>..." to include in what will be committed)
                                  core
                          nothing added to commit but untracked files present (use "git add" to track)
                          And the update script returns the following output:
                          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
                          the log will be /home/pi/MagicMirror/installers/upgrade.log
                          No LSB modules are available.
                          doing test run = true
                          saving custom.css
                          upgrading from version 2.9.0 to 2.10.0
                          fetching latest revisions
                          processing for module MMM-Remote-Control please wait
                          skipped processing for MMM-Remote-Control, doing test run
                          processing complete for module MMM-Remote-Control
                          processing for module MMM-NetworkScanner please wait
                          skipped processing for MMM-NetworkScanner, doing test run
                          processing complete for module MMM-NetworkScanner
                          processing for module MMM-DWD-WarnWeather please wait
                          skipped processing for MMM-DWD-WarnWeather, doing test run
                          processing complete for module MMM-DWD-WarnWeather
                          processing for module MMM-SystemStats please wait
                          skipped processing for MMM-SystemStats, doing test run
                          processing complete for module MMM-SystemStats
                          restoring custom.css
                          So it all worked out now, right?
                          Thanks for your help @sdetweil and @evroom
                            @spitzlbergerj said in new update/upgrade script, ready for testing:
                            all looks good… thank you so much for your time and patience…
                            but… the upgrader says u are still on 2.9… maybe a different folder? (as u said u were on 2.10 already)
                                @spitzlbergerj no attachment… send via mail… same ID as here on gmail
                                • evroomE Offline
                                  evroom @sdetweil
                                  On branch master
                                  Sam. I think the issue is, that the command is git status and you alias LC_ALL=C git to the name git, not the command git.
                                  You cannot use the alias as a replacement for a part of your command, but I might be wrong.
                                  I think the only solution is to check for language en_US and then for every git command either use plain git or else by using LC_ALL=C.
                                  Or just use LC_ALL=C for every git call.
                                  Test environment:
                                    sdetweil @evroom
                                    @evroom
                                    i don’t understand this…
                                    its been working fine for quite a few months, handling LC_ALL and LANGUAGE, just hs system has LANG too…
                                    anyhow, alias is supposed to work on ‘commands’ issued, and replace the started command with the replacement string (once)
                                    this is how the git doc suggested dealing with this issue and stackexchange posts over quite some time echoed it…
                                    I changes to the ‘LC_ALL=C git’ approach anyhow
                                    I don’t even check now, just do it… on english system, it doesn’t hurt
                                      no, I didn’t say I was on 2.10.
                                      i have now run the script in apply mode. The output is very long and apparently it was not updated, right?
                                      Link Text
                                      Sorry, I’ve always done the update via git. Now I am confused …
                                        @spitzlbergerj yes, please erase this file
                                        ~/MagicMirror/installers/dumpactivemodules.js
                                        it was copied early by the official updater in error
                                        • evroomE Offline
                                          evroom @sdetweil
                                          It is always difficult creating something and having it run flawlessly on many different systems with their many different settings, some exotic :-)
                                          One more thing I stumbled upon when googling:
                                          shopt -s expand_aliases
                                          Add this before the alias command, or just at the top of your script.
                                          Seems to work.
                                          Test environment:
                                            OK, now I have another problem :disappointed_face: . The upgrade script ran and I think it upgraded some stuff.
                                            At some point, I must have gotten my permissions mixed up. There were a number of directories that were root:root. Here there was Permission denied.
                                            I have now corrected the owners. But now the upgrade script doesn’t run anymore, because it assumes that I am already on 2.10.
                                            Can I force another upgrade?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 13 / 17
