new update/upgrade script, ready for testing
328 Posts 27 Posters 606.6k Views 24 Watching
    sdetweil
    i fixed the upgrade script… if u wanted to force use it again, use “force” instead of “apply”
    let me know how it goes
    • C Offline
      chrisparker @sdetweil
      @sdetweil Get well soon!
      • E Offline
        ember1205
        A couple of quick questions…
        • The “UpdateNotification” module is able to detect that there is a new version of MM available. Is this logged somewhere or easily accessible from the command line? I’m interested in writing a script that can assess the new version, possibly run a ‘test upgrade’ and then send me a IFTTT or pushover notification that a new version is available and an upgrade test succeeded (or failed).
        • Is the new upgrade script bundled with MM yet? I thought that was the intent, but did not see it up through 2.10.x
        S 1 Reply Last reply Oct 2, 2020, 5:47 PM Reply Quote 0
          sdetweil @ember1205
          @ember1205 the scripts were removed from the mm base. I maintain them on my github page https://github.com/sdetweil/MagicMirror_scripts
          the update cycle is 90days, 1st of the month
          if u look at my upgrade-script I check the versions using curl, line 173
          E 1 Reply Last reply Oct 2, 2020, 7:44 PM Reply Quote 0
          • E Offline
            ember1205 @sdetweil
            @sdetweil said in new update/upgrade script, ready for testing:
            Where’s a good place to discuss the scripts? I’m wondering how feasible and useful it might be to add to the upgrade-script.sh one.
            S 1 Reply Last reply Oct 2, 2020, 7:45 PM Reply Quote 0
              sdetweil @ember1205
              @ember1205 you could create an issue on the repo
                ashishtank Module Developer
                @sdetweil : Thank you for the great installer script ! it worked well on Raspberry Pi Zero W. I had issue with electron and dependencies but it did the job :)
                • N Nneuland referenced this topic on Apr 28, 2023, 1:10 PM
                • G Offline
                  gonzonia
                  Running the upgrade script to install v2.25.0 and I get the following result. The last time I hit a roadblock I screwed things up enough that I did a fresh install. What are the proper steps to correct this?
                   bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
                  Reading package lists... Done
                  Building dependency tree... Done
                  Reading state information... Done
                  The following packages were automatically installed and are no longer required:
                    libc-ares2 libjs-highlight.js libnode72 nodejs-doc
                  Use 'sudo apt autoremove' to remove them.
                  The following packages will be REMOVED:
                    nodejs*
                  0 upgraded, 0 newly installed, 1 to remove and 20 not upgraded.
                  After this operation, 919 kB disk space will be freed.
                  (Reading database ... 106969 files and directories currently installed.)
                  Removing nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                  ca-certificates is already the newest version (20210119).
                  curl is already the newest version (7.74.0-1.3+deb11u7).
                  gnupg is already the newest version (2.2.27-2+deb11u2).
                  0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
                  deb [arch=arm64  signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_20.x nodistro main
                  Get:1 https://deb.nodesource.com/node_20.x nodistro InRelease [12.1 kB]
                  Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                  Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                  Get:4 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages [3,264 B]
                  Fetched 15.4 kB in 1s (15.7 kB/s)
                  Suggested packages:
                    npm
                  The following NEW packages will be installed:
                    nodejs
                  0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
                  Need to get 0 B/148 kB of archives.
                  After this operation, 919 kB of additional disk space will be used.
                  Selecting previously unselected package nodejs.
                  (Reading database ... 106907 files and directories currently installed.)
                  Preparing to unpack .../nodejs_12.22.12~dfsg-1~deb11u4_armhf.deb ...
                  Unpacking nodejs (12.22.12~dfsg-1~deb11u4) ...
                  Setting up nodejs (12.22.12~dfsg-1~deb11u4) ...
                  update-alternatives: using /usr/bin/nodejs to provide /usr/bin/js (js) in auto mode
                  doing test run = false
                  update log will be in /home/pi/MagicMirror/installers/upgrade.log
                  Check current Node installation ...
                  Node currently installed. Checking version number.
                  Minimum Node version: v20.8.0
                  Installed Node version: v12.22.12
                  Node should be upgraded.
                  A Node process is currently running. Can't upgrade.
                  Please quit all Node processes and restart the update.
                  running process(s) are
                  pi 934 932 0 Sep14 ? 00:00:00 node ./node_modules/.bin/electron js/electron.js
                  G S 2 Replies Last reply Oct 5, 2023, 3:27 PM Reply Quote 0
                  • G Offline
                    gonzonia @gonzonia
                    I rebooted, and for some reason, MM didn’t restart right away, so I ran the script . It got further but then has an issue upgrading npm
                      sdetweil @gonzonia
                      @gonzonia sheesh, SO much fun… nodejs says is works and use this process…
                      we asked for node 20 and got something which turned into node 12…
                      (but then it doesn’t)
                      I JUST tested this on the latest raspian 64bit… (june this year)
                      can you post output of these two commands
                      uname -a
                      lsb_release -a
                      G 1 Reply Last reply Oct 5, 2023, 3:36 PM Reply Quote 0
                      • 28
                      • 29
                      • 30
                      • 31
                      • 32
                      • 33
                      • 30 / 33
