MMM-network-signal module ALWAYS displays message text
5 Posts 3 Posters 1.0k Views 3 Watching
    MMush
    Hello,
    I’m having an issue with the MMM-network-signal module from here:
    https://github.com/PoOwAa/MMM-network-signal
    Everything displays and works properly but I would like to remove the message text and only have the WiFi network icon.
    The relevant area of my config.js file reads:
    	module: "MMM-network-signal",
    	position: "bottom_left",
    	showMessage: false
    No matter what I enter for the showMessage line (e.g. false, ‘false’, “FALSE”, etc.) the text for the connection strength is ALWAYS displayed. I’d like it not to be…
    Can anyone help with what else to try here…?
    Thank you in advance,
    Mike
    S 1 Reply Last reply Aug 2, 2019, 4:50 PM Reply Quote 0
    • S Away
      sdetweil @MMush
      @MMush that needs to be in the config block
      module:
      position:
        config:{
            showMessage: false
      M 1 Reply Last reply Aug 2, 2019, 5:56 PM Reply Quote 2
        MMush @sdetweil
        @sdetweil OK, thank you! I will give that a try tonight and report back…
          MMush
          OK, that worked perfectly! Thank you for the fast response. The WiFi icon looks great (all by itself :)
            str3pto
            no worries! happy to help :D
