    xml processing
    2 Posts 2 Posters 1.1k Views 2 Watching
    • Y Offline
      yuyuyu
      I want to show you the scheduled time for bus arrival in Magic Mirror.
      To do that, I got a bus api.
      I entered the api URL and it was in xml format.
      I don’t know how to process the xml format in the magic mirror.
      can you tell me solution
      please
        sdetweil @yuyuyu
        @yuyuyu easiest is to use the xlm2json conversion, then work with the json objects
        see https://stackoverflow.com/questions/52281389/convert-xml-to-json-with-nodejs
        also, check on the api, it might accept some header to return json instead of xml
