    I Make a mistake
    1 Posts 1 Posters 806 Views 1 Watching
    • F
      Fonfon
      hi,
      i’ll make a mistake :
      i have MMM-iframe reload installed for googlemaps traffics
      works great
      i have installed MMM- remote-controle works great but now MMM-iframe reload don’t load i think is because module works both on port : 8080 but how change that ?
      so i’ll try to install MMM-GoogleMapsTraffic but when i install node dependencie in the folder i have error message:
      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-recommended@2.2.0 requires a peer of stylelint@^8.3.0 || ^9.0.0 || ^10.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN stylelint-config-standard@18.3.0 requires a peer of stylelint@^8.3.0 || ^9.0.0 || ^10.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN MMM-GoogleMapsTraffic@1.0.0 No repository field.
      so the module starting but i can see it only the border.
      Thanks for your help !
