    PM2 MM2 Not starting on start up
    37 Posts 12 Posters 35.4k Views 12 Watching
      Seregeth @sdetweil
      Even this tread is old, but i have an issue with the starting of mm:
      Everything worked well, then i installed MMM-CECControl.
      I saved my config.js file bevor i entered the module line in there. But not as usual mm didn´t restart. Not even after a reboot of my raspberry.
      Also when i start mm with
      pm2 start mm
      and
      pm2 start MagicMirror
      nothing happened.
      i don´t know what i should do to start my mm as bevore…
      S 2 Replies Last reply Reply Quote 1
        sdetweil @Seregeth
        @Seregeth
        ok let’s start at the beginning
        pm2 status
        will show you the names and numbers of the managed apps. you can use either the name or number
        now, let’s see if it’s a MagicMirror problem
        do
        pm2 stop all
        cd ~/MagicMirror
        npm start
        if mm comes up but the screen is not correct, ctrl-m will minimize the mm screen
          sdetweil @Seregeth
          @Seregeth sorry. I hit reject on your message accidentally, please resend it
            Seregeth @sdetweil
            $ pm2 status
            │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
            │ 1 │ MagicMirror │ fork │ 78 │ online │ 0% │ 2.6mb │
            │ 0 │ mm │ fork │ 2 │ stopped │ 0% │ 0b │
            ~ $ ^C
            ~ $ pm2 stop all
            [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
            [PM2] mm ✓
            [PM2] MagicMirror ✓
            │ 1 │ MagicMirror │ fork │ 117 │ stopped │ 0% │ 0b │
            $ cd MagicMirror/
            ~/MagicMirror $ npm start
            magicmirror@2.23.0 start
            DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
            sh: 1: ./node_modules/.bin/electron: not found
              sdetweil @Seregeth
              @Seregeth ok, try
              cd ~/MagicMirror
              npm install electron@22.3.4
                Seregeth @sdetweil
                that´s it, MM startet again after the installation
                  sdetweil @Seregeth
                  @Seregeth cool… thx for the feedback
                  • 4 / 4
