    PM2 MM2 Not starting on start up
    37 Posts 12 Posters 35.9k Views 12 Watching
      Desertswing @shbatm
      @shbatm
      will note that down thanks!
        raymate @Desertswing
        @Desertswing No idea what that did but it worked, just need to make it show the weather as that seems to have gone away
        Pi zero W and Pi 3
        • N Offline
          nuckinfutz
          Try here as an alternative
          https://forum.magicmirror.builders/topic/2716/pm2-alternative
            daikaiju @shbatm
            @shbatm said in PM2 MM2 Not starting on start up:
            sudo pm2 startup systemd -u pi --hp /home/pi
            Can also confirm this worked for me, too.
            Thank you @shbatm
            • P Offline
              pum
              @shbatm I’ve tried the following steps but it still doesn’t work, can you help me?
              • sudo pm2 startup systemd -u pi --hp /home/pi
              • nano mm.sh
              • cd ~/MagicMirror
                DISPLAY=:0 npm start
              • CTRL-O
              • Enter
              • CTRL-X
              • chmod +x mm.sh
              • pm2 start mm.sh
              • pm2 save
              • sudo reboot
              Thanks in advance.
                shbatm Module Developer @pum
                @pum there is an existing script provided by MagicMirror now, please try deleting everything on your ~/.pm2 directory, then using:
                sudo su -c "env PATH=$PATH:/usr/bin pm2 startup linux -u pi --hp /home/pi"
                    pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
                    pm2 save
                You may have to use systemd instead of linux in the first line if you get an error.
                  MarvellousMili @shbatm
                  @shbatm I did all I should follow but it still doesn’t work for me, I’m using Rpi4b. It warning me:
                  PM2 is not managing any process, skipping save…
                  Plz help me my boyfriend’s birthday is under eyes!!
                  Thanks a lot!
                    sdetweil @MarvellousMili
                    @MarvellousMili run the fixuppm2.sh script from here
                      MarvellousMili @sdetweil
                      @sdetweil sorry that reply late, I save the pm2 status after reboot again and again then work. I don’t know where’s the problem even now lol
                        @MarvellousMili sorry. not sure what u said
                        is working ok
                        or
                        is NOT working ok
                          Seregeth @sdetweil
                          Even this tread is old, but i have an issue with the starting of mm:
                          Everything worked well, then i installed MMM-CECControl.
                          I saved my config.js file bevor i entered the module line in there. But not as usual mm didn´t restart. Not even after a reboot of my raspberry.
                          Also when i start mm with
                          pm2 start mm
                          and
                          pm2 start MagicMirror
                          nothing happened.
                          i don´t know what i should do to start my mm as bevore…
                          S 2 Replies Last reply Reply Quote 1
                            sdetweil @Seregeth
                            @Seregeth
                            ok let’s start at the beginning
                            pm2 status
                            will show you the names and numbers of the managed apps. you can use either the name or number
                            now, let’s see if it’s a MagicMirror problem
                            do
                            pm2 stop all
                            cd ~/MagicMirror
                            npm start
                            if mm comes up but the screen is not correct, ctrl-m will minimize the mm screen
                              sdetweil @Seregeth
                              @Seregeth sorry. I hit reject on your message accidentally, please resend it
                                Seregeth @sdetweil
                                $ pm2 status
                                │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                                │ 1 │ MagicMirror │ fork │ 78 │ online │ 0% │ 2.6mb │
                                │ 0 │ mm │ fork │ 2 │ stopped │ 0% │ 0b │
                                ~ $ ^C
                                ~ $ pm2 stop all
                                [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
                                [PM2] mm ✓
                                [PM2] MagicMirror ✓
                                │ 1 │ MagicMirror │ fork │ 117 │ stopped │ 0% │ 0b │
                                $ cd MagicMirror/
                                ~/MagicMirror $ npm start
                                magicmirror@2.23.0 start
                                DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
                                sh: 1: ./node_modules/.bin/electron: not found
                                  sdetweil @Seregeth
                                  @Seregeth ok, try
                                  cd ~/MagicMirror
                                  npm install electron@22.3.4
                                    Seregeth @sdetweil
                                    that´s it, MM startet again after the installation
                                      sdetweil @Seregeth
                                      @Seregeth cool… thx for the feedback
