    PM2 MM2 Not starting on start up
    37 Posts 12 Posters 40.3k Views 12 Watching
      shbatm Module Developer @pum
      @pum there is an existing script provided by MagicMirror now, please try deleting everything on your ~/.pm2 directory, then using:
      sudo su -c "env PATH=$PATH:/usr/bin pm2 startup linux -u pi --hp /home/pi"
          pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
          pm2 save
      You may have to use systemd instead of linux in the first line if you get an error.
        MarvellousMili @shbatm
        @shbatm I did all I should follow but it still doesn’t work for me, I’m using Rpi4b. It warning me:
        PM2 is not managing any process, skipping save…
        Plz help me my boyfriend’s birthday is under eyes!!
        Thanks a lot!
          sdetweil @MarvellousMili
          @MarvellousMili run the fixuppm2.sh script from here
            MarvellousMili @sdetweil
            @sdetweil sorry that reply late, I save the pm2 status after reboot again and again then work. I don’t know where’s the problem even now lol
              @MarvellousMili sorry. not sure what u said
              is working ok
              or
              is NOT working ok
                Seregeth @sdetweil
                Even this tread is old, but i have an issue with the starting of mm:
                Everything worked well, then i installed MMM-CECControl.
                I saved my config.js file bevor i entered the module line in there. But not as usual mm didn´t restart. Not even after a reboot of my raspberry.
                Also when i start mm with
                pm2 start mm
                and
                pm2 start MagicMirror
                nothing happened.
                i don´t know what i should do to start my mm as bevore…
                S 2 Replies Last reply Reply Quote 1
                  sdetweil @Seregeth
                  @Seregeth
                  ok let’s start at the beginning
                  pm2 status
                  will show you the names and numbers of the managed apps. you can use either the name or number
                  now, let’s see if it’s a MagicMirror problem
                  do
                  pm2 stop all
                  npm start
                  if mm comes up but the screen is not correct, ctrl-m will minimize the mm screen
                    sdetweil @Seregeth
                    @Seregeth sorry. I hit reject on your message accidentally, please resend it
                      Seregeth @sdetweil
                      $ pm2 status
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 1 │ MagicMirror │ fork │ 78 │ online │ 0% │ 2.6mb │
                      │ 0 │ mm │ fork │ 2 │ stopped │ 0% │ 0b │
                      ~ $ ^C
                      ~ $ pm2 stop all
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0, 1 ])
                      [PM2] mm ✓
                      [PM2] MagicMirror ✓
                      │ 1 │ MagicMirror │ fork │ 117 │ stopped │ 0% │ 0b │
                      $ cd MagicMirror/
                      ~/MagicMirror $ npm start
                      magicmirror@2.23.0 start
                      sh: 1: ./node_modules/.bin/electron: not found
                        sdetweil @Seregeth
                        @Seregeth ok, try
                        npm install electron@22.3.4
                          Seregeth @sdetweil
                          that´s it, MM startet again after the installation
                            sdetweil @Seregeth
                            @Seregeth cool… thx for the feedback
