    PM2 MM2 Not starting on start up
    37 Posts 12 Posters 40.6k Views 12 Watching
      sebzx10r @eugekiller
      @eugekiller
      Hey,I’m having this exact same issue. I’m trying to follow your steps but I can’t locate the pm2-init.sh file. I have the pm2 installed. I go follow the same directory paths as stated but that one file isn’t there. Any ideas about where the file is? It has to exist somewhere since I’m able to use it.
      E 3 Replies Last reply
      • E
        eugekiller @sebzx10r
        @sebzx10r Its directory is /etc/init.d/pm2-init.sh
        • E
          @sebzx10r The way i did it also is used WinSCP to shh in to raspberry.
          • E
            @sebzx10r Can you load MM with pm2 start mm.sh?
              sebzx10r
              Hey,yes, I go to that same exact directory,but the file isn’t there. And yes I can load MM with pm2 start mm.sh. That’s what so weird about the whole thing. It’s as if the file doesn’t exist but yet the program is working somehow.
                sebzx10r
                Hey,I kind of did a work around. I found this on another forum:
                I also searched for days without success but then, I got it to work quite simply.
                In Raspian click Menu,Preferences,Main Menu Editor
                Click Preferences and check Default applications for LXSession
                Click OK and close main menu editor
                Now click Menu and Under Preferences click on Default applications for LXSession
                LXSession configuration opens
                Click Autostart
                Under Manual autostarted applications paste in your java command line
                click add
                close the LXSession configuration application and reboot your pi
                your java app should run after reboot
                N 1 Reply Last reply
                • N
                  nuckinfutz @sebzx10r
                  @sebzx10r What line did you put in the field? I can’t get it to work.
                  D 1 Reply Last reply
                    Desertswing @nuckinfutz
                    @nuckinfutz
                    pm2 start mm.sh
                      shbatm Module Developer
                      I solved the same issue by using the command:
                      sudo pm2 startup systemd -u pi --hp /home/pi
                      And then using pm2 save to save the state.
                      D D 2 Replies Last reply
                      Reply Quote 2
                        Desertswing @shbatm
                        @shbatm
                        will note that down thanks!
                        R 1 Reply Last reply
                          raymate @Desertswing
                          @Desertswing No idea what that did but it worked, just need to make it show the weather as that seems to have gone away
                          Pi zero W and Pi 3
                          • N
                            nuckinfutz
                            Try here as an alternative
                            https://forum.magicmirror.builders/topic/2716/pm2-alternative
                              daikaiju @shbatm
                              @shbatm said in PM2 MM2 Not starting on start up:
                              Can also confirm this worked for me, too.
                              Thank you @shbatm
                                pum
                                @shbatm I’ve tried the following steps but it still doesn’t work, can you help me?
                                • sudo pm2 startup systemd -u pi --hp /home/pi
                                • nano mm.sh
                                • cd ~/MagicMirror
                                  DISPLAY=:0 npm start
                                • CTRL-O
                                • Enter
                                • CTRL-X
                                • chmod +x mm.sh
                                • pm2 start mm.sh
                                • pm2 save
                                • sudo reboot
                                Thanks in advance.
                                  shbatm Module Developer @pum
                                  @pum there is an existing script provided by MagicMirror now, please try deleting everything on your ~/.pm2 directory, then using:
                                  sudo su -c "env PATH=$PATH:/usr/bin pm2 startup linux -u pi --hp /home/pi"
                                      pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
                                      pm2 save
                                  You may have to use systemd instead of linux in the first line if you get an error.
                                  M 1 Reply Last reply
                                    MarvellousMili @shbatm
                                    @shbatm I did all I should follow but it still doesn’t work for me, I’m using Rpi4b. It warning me:
                                    PM2 is not managing any process, skipping save…
                                    Plz help me my boyfriend’s birthday is under eyes!!
                                    Thanks a lot!
                                      sdetweil @MarvellousMili
                                      @MarvellousMili run the fixuppm2.sh script from here
                                        MarvellousMili @sdetweil
                                        @sdetweil sorry that reply late, I save the pm2 status after reboot again and again then work. I don’t know where’s the problem even now lol
                                          @MarvellousMili sorry. not sure what u said
                                          is working ok
                                          or
                                          is NOT working ok
                                            Seregeth @sdetweil
                                            Even this tread is old, but i have an issue with the starting of mm:
                                            Everything worked well, then i installed MMM-CECControl.
                                            I saved my config.js file bevor i entered the module line in there. But not as usual mm didn´t restart. Not even after a reboot of my raspberry.
                                            Also when i start mm with
                                            pm2 start mm
                                            and
                                            pm2 start MagicMirror
                                            nothing happened.
                                            i don´t know what i should do to start my mm as bevore…
                                            S 2 Replies Last reply
