    PM2 MM2 Not starting on start up
    37 Posts 12 Posters 40.8k Views 12 Watching
    • E
      eugekiller
      Ok so i also tryed to do pm2 lists and there is nothing in the list. Does that mean anything?
      • E
        eugekiller
        Ok so i started doing some more digging. First i have a question PM2 does it actually load MM from a full reboot? meaning power off to RPI and a full start.
        The reason i ask is because
        When i open terminal in RPI and type npm start from MM directory it loads MM without any problems. Then i hit Ctrl Q it quits.
        Then i do PM2 list and gives me 0 apps running.
        Then I do pm2 start mm.sh again loads MM without a problem. Then i hit Ctrl Q it exits MM for about 10sec and then loads it back. During the 10sec I did pm2 list again and it said MM is running.
        So I dont think PM2 is actually loading MM from a full reboot.
        • E
          eugekiller
          BINGO Got it to work. Not sure if others had a problem with this or its something new. but here it is.
          However, there is a bug on the generated startup script that prevents PM2 from automatically run at startup. You will need to edit /etc/init.d/pm2-init.sh and
          replace: export PM2_HOME=“/root/.pm2”
          with: export PM2_HOME=“/home/pi/.pm2”
          Got this from here: https://bekti.io/automatically-start-a-node-js-application-on-raspberry-pi/
          Reply Quote 2
            sebzx10r @eugekiller
            @eugekiller
            Hey,I’m having this exact same issue. I’m trying to follow your steps but I can’t locate the pm2-init.sh file. I have the pm2 installed. I go follow the same directory paths as stated but that one file isn’t there. Any ideas about where the file is? It has to exist somewhere since I’m able to use it.
            E 3 Replies Last reply
            • E
              eugekiller @sebzx10r
              @sebzx10r Its directory is /etc/init.d/pm2-init.sh
              • E
                @sebzx10r The way i did it also is used WinSCP to shh in to raspberry.
                • E
                  @sebzx10r Can you load MM with pm2 start mm.sh?
                    sebzx10r
                    Hey,yes, I go to that same exact directory,but the file isn’t there. And yes I can load MM with pm2 start mm.sh. That’s what so weird about the whole thing. It’s as if the file doesn’t exist but yet the program is working somehow.
                      sebzx10r
                      Hey,I kind of did a work around. I found this on another forum:
                      I also searched for days without success but then, I got it to work quite simply.
                      In Raspian click Menu,Preferences,Main Menu Editor
                      Click Preferences and check Default applications for LXSession
                      Click OK and close main menu editor
                      Now click Menu and Under Preferences click on Default applications for LXSession
                      LXSession configuration opens
                      Click Autostart
                      Under Manual autostarted applications paste in your java command line
                      click add
                      close the LXSession configuration application and reboot your pi
                      your java app should run after reboot
                      N 1 Reply Last reply
                      • N
                        nuckinfutz @sebzx10r
                        @sebzx10r What line did you put in the field? I can’t get it to work.
                        D 1 Reply Last reply
                          Desertswing @nuckinfutz
                          @nuckinfutz
                          pm2 start mm.sh
                            shbatm Module Developer
                            I solved the same issue by using the command:
                            sudo pm2 startup systemd -u pi --hp /home/pi
                            And then using pm2 save to save the state.
                            D D 2 Replies Last reply
                            Reply Quote 2
                              Desertswing @shbatm
                              @shbatm
                              will note that down thanks!
                              R 1 Reply Last reply
                                raymate @Desertswing
                                @Desertswing No idea what that did but it worked, just need to make it show the weather as that seems to have gone away
                                Pi zero W and Pi 3
                                • N
                                  nuckinfutz
                                  Try here as an alternative
                                  https://forum.magicmirror.builders/topic/2716/pm2-alternative
                                    daikaiju @shbatm
                                    @shbatm said in PM2 MM2 Not starting on start up:
                                    Can also confirm this worked for me, too.
                                    Thank you @shbatm
                                      pum
                                      @shbatm I’ve tried the following steps but it still doesn’t work, can you help me?
                                      • sudo pm2 startup systemd -u pi --hp /home/pi
                                      • nano mm.sh
                                      • cd ~/MagicMirror
                                        DISPLAY=:0 npm start
                                      • CTRL-O
                                      • Enter
                                      • CTRL-X
                                      • chmod +x mm.sh
                                      • pm2 start mm.sh
                                      • pm2 save
                                      • sudo reboot
                                      Thanks in advance.
                                        shbatm Module Developer @pum
                                        @pum there is an existing script provided by MagicMirror now, please try deleting everything on your ~/.pm2 directory, then using:
                                        sudo su -c "env PATH=$PATH:/usr/bin pm2 startup linux -u pi --hp /home/pi"
                                            pm2 start ~/MagicMirror/installers/pm2_MagicMirror.json
                                            pm2 save
                                        You may have to use systemd instead of linux in the first line if you get an error.
                                        M 1 Reply Last reply
                                          MarvellousMili @shbatm
                                          @shbatm I did all I should follow but it still doesn’t work for me, I’m using Rpi4b. It warning me:
                                          PM2 is not managing any process, skipping save…
                                          Plz help me my boyfriend’s birthday is under eyes!!
                                          Thanks a lot!
                                            sdetweil @MarvellousMili
                                            @MarvellousMili run the fixuppm2.sh script from here
