    Error with Dependencies. ( Newbie)..
    1 Posts 1 Posters 386 Views 1 Watching
      dearco
      Installing dependencies …
      (node:20440) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN engine grunt-markdownlint@2.6.0: wanted: {“node”:“>=6”,“npm”:“>=3”} (current: {“node”:“8.11.1”,“npm”:“1.4.21”})
      npm ERR! Error: Method Not Allowed
      npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR! at /usr/share/npm/lib/cache/add-named.js:120:12
      npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this entire log,
      npm ERR! including the npm and node versions, at:
      npm ERR! http://github.com/npm/npm/issues
      npm ERR! System Linux 4.19.42-v7+
      npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      node ./download-chromedriver.js
      successfully dowloaded and extracted!
      npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx’
      npm ERR! error rolling back stylelint@10.1.0 { Error: ENOTEMPTY: directory not empty, rmdir ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx’
      npm ERR! error rolling back errno: -39,
      npm ERR! error rolling back code: ‘ENOTEMPTY’,
      npm ERR! error rolling back syscall: ‘rmdir’,
      npm ERR! error rolling back path: ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-jsx’ }
      npm ERR! tar.unpack untar error /home/pi/.npm/postcss-syntax/0.36.2/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/supports-color/5.5.0/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/ansi-styles/3.2.1/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/autoprefixer/9.6.1/package.tgz
      npm ERR! tar.unpack untar error /home/pi/.npm/remark-stringify/6.0.4/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib’
      npm ERR! error rolling back remark@10.0.1 { Error: ENOTEMPTY: directory not empty, rmdir ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib’
      npm ERR! error rolling back path: ‘/home/pi/MagicMirror/node_modules/stylelint/node_modules/postcss-markdown/node_modules/remark/node_modules/remark-parse/lib’ }
      npm ERR! tar.unpack untar error /home/pi/.npm/remark-parse/6.0.3/package.tgz
      core-js@2.6.9 postinstall /home/pi/MagicMirror/node_modules/spectron/node_modules/webdriverio/node_modules/babel-runtime/node_modules/core-js
      node scripts/postinstall || echo “ignore”
      npm ERR!
      npm ERR! /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
