    I have these two files config.js and MMM-GooglePhotos.js
    3 Posts 2 Posters 992 Views 2 Watching
    • K
      KalboDave
      I am wondering why I have a config.js and MMM_GooglePhotos.js - which takes priority, or which one can I delete? I am trying to tweak my refresh rate and scan rate. And also tweak my show Height/Width and original Height/Width, but I have the similar info in both files. I did some research and found a recommendation to remove the module config from the config.js file . . . . but the album key is in the config.js files.
      I would prefer a little advice/guidance before deleting the module config from the config.js
        sdetweil @KalboDave
        @KalboDave MMM_GooglePhotos.js is the browser side code for the module.
        config.js is the MagicMirror configuration file, where u tell mm to include a module (found in a directory under MagicMirror/modules)
        U should never change the module js file. The system design takes what u specify in the config.js module definition, and updates the module values at runtime
        K 1 Reply Last reply
        • K
          KalboDave @sdetweil
          @sdetweil I will stop messing with it then. Thanks for the info.
