    rotate_display=1 is not rotating my display?
    4 Posts 2 Posters 4.0k Views 2 Watching
    • V Offline
      valid8r
      I’ve edited my /boot/config.txt file to include the command
      display_rotate=1
      but my display isn’t rotating…
      To be clear. I have my MM booting on startup. I then am using Ctrl-Alt-F2 to get to the command line and from there logging into my pi with username: pi password: raspberry from which I get to the /boot directory where I edit config.txt… Is this correct? If so, what am I doing wrong here?
      Thanks,
      • V Offline
        valid8r
        Sorry, figured it out. My own stupidity that I prefer not to reveal and of no help to anyone to learn from.
        Please ignore.
        • G Offline
          grottenolm80
          valid8r, would you mind sharing your stupidity? Because I think I am at least as stupid as you ;)
          • G Offline
            grottenolm80 @grottenolm80
            Ok, so I found out the problem: I typed spaces around the = sign, i.e. “rotate_display = 1” instead of “rotate_display=1”. If you take out the white spaces (also for the warnings command) it should work.
