    Raspian buster & MM 2.8
    6 Posts 3 Posters 1.9k Views 3 Watching
      shgmongohh
      Hi folks,
      I tried to install MM 2.8 on a fresh raspian buster Pi3 system with the tutorial from KirAsh4 .
      Everything is looking good during the installation. During the installation I also can see the MM2 screen. But after a restart, MM2 will not start automaticly .
      Can anybody help me?
      Sebastian
        shgmongohh @sdetweil
        Thanks! I don´t know what you have done, but your script works fine.
        • buzzkcB Offline
          buzzkc
          Here are the docs on setting up PM2, though I thought the install asked if you wanted it to autostart. You might type in :
          pm2 list
          Should show if pm2 is installed or if the autostart is setup.
          https://github.com/MichMich/MagicMirror/wiki/auto-starting-magicmirror
          Darren
          My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
            sdetweil @buzzkc
            @buzzkc Use my new scripts. Search for fixuppm2
            buzzkcB S 2 Replies Last reply Reply Quote 2
            • buzzkcB Offline
              buzzkc @sdetweil
              @sdetweil Cool, I hadn’t seen this.
              @shgmongohh https://forum.magicmirror.builders/topic/10907/new-script-to-install-fix-pm2-config-for-start-on-boot
              Darren
                  sdetweil @shgmongohh
                  @shgmongohh took the pm2 setup from the new installer script
                  https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer
                  and made it usable separately
                  thanks for the feedback
