    Error : cannot find module "rrule"
    13 Posts 3 Posters 3.7k Views 3 Watching
      JohnB7777
      Hello,
      I have a big problem with the calendar default module.
      Since the last magic mirror update, the module blocks the launch of the mirror.
      > magicmirror@2.9.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'rrule'
      App threw an error during load
          at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
          at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
          at Function.Module._load (internal/modules/cjs/loader.js:528:25)
          at Module.require (internal/modules/cjs/loader.js:658:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:27:13)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:68:3)
          at Module._compile (internal/modules/cjs/loader.js:711:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          at Module.load (internal/modules/cjs/loader.js:620:32)
      { Error: Cannot find module 'rrule'
          at Module.load (internal/modules/cjs/loader.js:620:32) code: 'MODULE_NOT_FOUND' }
      Launching application.
      I don’t understand what is wrong.
      I removed the module and I reinstall it but the problem still there.
      Thanks for your help ! :)
        sdetweil @JohnB7777
        @JohnB7777 said in Error : cannot find module "rrule":
        removed what module?
        do this
        cd ~MagicMirror
        npm install rrule@2.6.2
          JohnB7777 @sdetweil
          @sdetweil I removed the calendar module, the one you help me to reinstall :)
          And this command didn’t work, but I have the same errors when I do “npm install” on the MagicMirror folder :
          pi@raspberrypi:~/MagicMirror $ npm install rrule@2.6.2
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/aproba
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/isarray
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/process-nextick-args
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/string_decoder
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/are-we-there-yet/node_modules/readable-stream
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/chownr
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cli-spinners
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-regex
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/ansi-styles
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/is-fullwidth-code-point
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/strip-ansi
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/clone
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/console-control-strings
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/defaults
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/delegates
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/detect-libc
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/colors
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/jsonfile
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/fs-extra
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/ms
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/electron-rebuild/node_modules/debug
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/emoji-regex
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/string-width
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/cliui/node_modules/wrap-ansi
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/has-unicode
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/mem/node_modules/mimic-fn
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minipass/node_modules/safe-buffer
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-abi
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/node-gyp/node_modules/semver
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-regex
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/ansi-styles
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/has-flag
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/strip-ansi
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/supports-color
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/chalk
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/ora/node_modules/log-symbols
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-homedir
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/invert-kv
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/os-locale/node_modules/lcid
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/osenv
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-defer
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/map-age-cleaner
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-finally
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-is-promise
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/p-try
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npm-run-path
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/pump
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/get-stream
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/spawn-rx
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/strip-eof
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/tar/node_modules/safe-buffer
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wcwidth
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/execa
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/which-module
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/wide-align
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/gauge
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/npmlog
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yallist
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/fs-minipass
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/minizlib
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs-parser/node_modules/camelcase
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/ansi-regex
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/get-caller-file
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/is-fullwidth-code-point
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-limit
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/p-locate
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/path-exists
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/locate-path
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/find-up
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/require-main-filename
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/strip-ansi
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/string-width
          npm WARN checkPermissions Missing write access to /home/pi/MagicMirror/node_modules/yargs/node_modules/y18n
          npm WARN grunt-yamllint@0.3.0 requires a peer of grunt@>=1.0.1 but none is installed. You must install peer dependencies yourself.
          npm ERR! path /home/pi/MagicMirror/node_modules/aproba
          npm ERR! code EACCES
          npm ERR! errno -13
          npm ERR! syscall access
          npm ERR! Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba'
          npm ERR!  { [Error: EACCES: permission denied, access '/home/pi/MagicMirror/node_modules/aproba']
          npm ERR!   stack:
          npm ERR!    'Error: EACCES: permission denied, access \'/home/pi/MagicMirror/node_modules/aproba\'',
          npm ERR!   errno: -13,
          npm ERR!   code: 'EACCES',
          npm ERR!   syscall: 'access',
          npm ERR!   path: '/home/pi/MagicMirror/node_modules/aproba' }
          npm ERR!
          npm ERR! The operation was rejected by your operating system.
          npm ERR! It is likely you do not have the permissions to access this file as the current user
          npm ERR!
          npm ERR! If you believe this might be a permissions issue, please double-check the
          npm ERR! permissions of the file and its containing directories, or try running
          npm ERR! the command again as root/Administrator (though this is not recommended).
          npm
          ``` ERR!     /home/pi/.npm/_logs/2019-10-08T13_03_57_910Z-debug.log
            sdetweil @JohnB7777
            @JohnB7777 yeh, you used sudo somehwere… NEVER use sudo (except when told, for specific things)
            do this
            cd ~
            sudo chown -R pi MagicMirror
            then redo the command above.
            why would you delete a module?
              JohnB7777 @sdetweil
              @sdetweil I deleted this module because I though it was the cause of the error.
              I tried what you said and it worked but when I start the mirror, there is another error :
              > sh run-start.sh
              Loading config ...
              No helper found for module: MMM-AirQuality.
              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:9:13)
                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Tools/node_helper.js:239:3)
              { Error: Cannot find module 'async'
              ^Z
              [2]+  Stoppé                 npm start
                sdetweil @JohnB7777
                MMM-Tools
                do this
                cd MagicMirror
                npm install async
                then restart mirror
                  JohnB7777 @sdetweil
                  @sdetweil Ok, it works but I have another error that doesn’t prevent the start of the mirror.
                  { Error: listen EADDRINUSE 127.0.0.1:8080
                      at Server.setupListenHandle [as _listen2] (net.js:1330:14)
                      at listenInCluster (net.js:1378:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1492:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:55:10)
                    errno: 'EADDRINUSE',
                    code: 'EADDRINUSE',
                    syscall: 'listen',
                    address: '127.0.0.1',
                    port: 8080 }
                    sdetweil @JohnB7777
                    @JohnB7777
                    already have MagicMirror running
                    pm2 stop 0
                    pm2 start 0
                      JohnB7777 @sdetweil
                      @sdetweil Yes, I use pm2 to start and stop the mirror but I use npm start to see the errors.
                        sdetweil @JohnB7777
                        @JohnB7777
                        you have two instances running…
                        npm start is what pm2 does for you under the covers
                        J lavolp3L 2 Replies Last reply Reply Quote 0
                          JohnB7777 @sdetweil
                          @sdetweil Oh, yes, I understand what you wanted to say.
                          That was the cause of the error.
                          Now, the problem is solved, and thank you very much for your (very quick) help ! :D
                            sdetweil @JohnB7777
                            @JohnB7777 cool… can u mark this solved now… 3 dots next to the message that u think resolves it
                            • lavolp3L Offline
                              lavolp3 Module Developer @sdetweil
                              This post is deleted!
