    Creating Module with API Key/Secret
    15 Posts 4 Posters 6.2k Views 4 Watching
      sdetweil @lilpkstud
      @lilpkstud said in Creating Module with API Key/Secret:
      JSON.stringify()
      correct… u converted the object to a string… don’t need to do that
      just pass the object from helper up to module …
      then it will use the this.data.name
      • strawberry 3.141S Offline
        @lilpkstud next to what sdetweil said you should also not save your result into this.data as it is an instance property which already contains data, see https://github.com/MichMich/MagicMirror/tree/master/modules#available-module-instance-properties for reference
        S 1 Reply Last reply Reply Quote 2
          sdetweil @strawberry 3.141
          @strawberry-3-141 should call it api_data maybe!
          • L Offline
            lilpkstud Module Developer
            @sdetwell @strawberry-3-141 thanks guys got it to work!
            I used JSON.Stringify() to look at the data when I was console.loggining so that was the reason why my object were turning into strings
              sdetweil @lilpkstud
              @lilpkstud cool… if need it in strings someplace, need to convert it back object=JSON.parse(string)
