    optimize modules during days
    11 Posts 3 Posters 2.4k Views 3 Watching
    • C Offline
      chassain 0
      i have a raspberry pi4 since 2 days on replace raspberry pi3…i have a lot of modules with MMM-pages…videos, meteo,images,default modules,spotify…
      How can i optimize display without bug (slow display)? what’s the perfect size of memory split? (128 now) i’m using crontab -e to reduce default (pm2 stop and restart in half day)…thanks
      • C Offline
        chassain 0
        module: "MMM-pages",
        			disabled: false,
                        		modules:
        				[[ "MMM-EmbedYoutube" , "MMM-EyeCandy" , "newsfeed" ],
        				[ "helloworld" , "MMM-ImagesPhotos" , "MMM-ImagesPhotos2" , "newsfeed" , "helloworld2" ],
        				[ "MMM-iFrameReload" , "MMM-EyeCandy" , "newsfeed" ],
        				[ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ],
        				[ 'MMM-Lunartic' , "MMM-DarkSkyForecast" , "MMM-EARTH" , 'MMM-rfacts' ,  "MMM-NowPlayingOnSpotify" , "newsfeed" ],
        				[ "clock" , "calendar", "calendar_monthly" , "MMM-cryptocurrency" , "MMM-EyeCandy" , "newsfeed" ],
        				[ 'MMM-SoccerLiveScore' , "MMM-Cocktails" , 'MMM-MovieListings' , "newsfeed" , 'MMM-SystemStats' ],
        				[ "helloworld" , "MMM-ImagesPhotos" , "newsfeed" ]],
                			rotationTime: 15000,
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @chassain 0
          @chassain-0 sorry, I do not understand what you are asking…
          also, can you use the markdown syntax, put a code block around your config post (mark the text and press the code icon in the editor
          • C Offline
            chassain 0
            Sorry my english is bad…and school was so far 😁…for resume, you can see the differents modules used in my config.js…i have a magicmirror without mirror…the memory gpu is 128 M (with sudo raspi-config) but i have some slowly in a day…then, i use on a terminal “crontab -e” to restart mm at different moment…and it s ok !..but may be there is more parameters about raspberry pi 4 to work fine…
            • C Offline
              chassain 0
              Cpu…not gpu
                @chassain-0 hmm… 128meg memory? i don’t think so… pi 4 has 1 2 or 4 gig
                lets check for swap space enabled
                free -m
                might show something like
                              total        used        free      shared  buff/cache   available
                Mem:           1994         631          50         523        1313         785
                Swap:          2047         224        1823
                if no swap space, do , see here
                https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
                • C Offline
                  chassain 0
                  Sorry but i speak about option 7 “advanced options” / A3 " memory split" / how much memory should the gpu have : 128 choose /…is it correct to have no slowly with vidéos & photos modules ? I have raspberry pi 4 with 4G memory
                    @chassain-0
                    i don’t know when the GPU is used, but not very much if at all by MagicMirror
                    maybe video encoding/decoding…
                    • C Offline
                      chassain 0 @sdetweil
                      @sdetweil thanks
                      • ? Offline
                        A Former User @chassain 0
                        @chassain-0
                        Why do you use so many duplicated pages? I can’t understand what you want.
                        • C Offline
                          chassain 0
                          Hello sean
                          It’s just a magicmirror wit no mirror… i duplicate pages because i don’t know change the timer for only one page. this config is just to play and see the result along a day…i had some slowly displays after 10 hours. I play with crontab to refresh modules and it’s correct now…i play too with trigger cmd (and alexa echo) to start mm or stop mm…it’s really funny !!! and i just wanted to know the best configuration for my raspi 4 to work fine
