    MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion
    50 Posts 5 Posters 18.4k Views 5 Watching
      MichaelKrems
      ello forum
      I’ve been trying MMM-Assistant Mk2 and MMM-Hotword on a RaspberryPi 3 with Raspian Buster,for a week ,without success.
      Everything starts so far OK “Brief today” is played.
      But does not respond to “Smart Mirror” hotword.
      Test in the console with Arecord and Aplay function OK
      Infos :
      arecord -l
      **** Liste der Hardware-Geräte (CAPTURE) ****
      Karte 1: Device [USB PnP Sound Device], Gerät 0: USB Audio [USB Audio]
        Sub-Geräte: 0/1
        Sub-Gerät #0: subdevice #0
      Config.js
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "10.0.0.15",
      		              //"localhost", // Address to listen on, can be:
      	port: 8080,
      	ipWhitelist: //["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses
                           [], // Set [] to allow all IP addresses
      	language: "de",
        	timeFormat: "24",
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      	//	    module: "MMM-GoogleAssistant",
      	//	    position: "top_right",
      	//	    config: {
      	//	        maxWidth: "100%",
      	//	        header: "",
      	//	    publishKey: "pub-c-9ce2adff-cdc9-497e-a81b-a0f2f64b3fc1",
      	//	    subscribeKey: " sub-c-a337d0f8-e9ea-11e9-914e-0a6be83abca1",
      	//	    updateDelay: 500
      			header: "kommende Termine",
      						symbol: "calendar-check",
      					//	url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                                     url: "webcal://mail.bruedergros.at/owa/calendar/e27e09b9651248a8870f91463c14603d@bruedergros.at/993da715237941099626d16d0da2631f3462472444406405802/S-1-8-2874105991-1718106435-1479008544-2259784499/reachcalendar.ics" ,
      					//	url: "https://calendar.google.com/calendar/ical/salzer.michael2164%40gmail.com/public/basic.ics" ,
      //			module: "compliments",
      //			position: "lower_third",
      //			config: {
      //			 remoteFile:	"https://raw.githubusercontent.com/michadenheijer/MagicMirrorCompliments/master/de.json"
      			module: "currentweather",
      			position: "top_center",
      				locationID: "7871800",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "8a19f8f173506892e56e500859f045ba"
      			module: "weatherforecast",
      			header: "Weather Forecast",
        module: "MMM-News",
        position: "bottom_bar",
          apiKey : "663c4ed685354fa7a0c432bb25ed5e53",
          type: "horizontal",
          query : [
              sources: "bild,abc-news, cnn",
              country: "at",
              className: "redTitle",
              country: "at",
              category: "sports",
              q : ""
      			module: "newsfeed",
      				feeds: [
      						//title: "New York times",
      					       //url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      						title:"OE3",
      					        url:"https://rss.orf.at/news.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
      Did I miss something? Thankful for any tip or hint.
      Translated by Google in English
        MichaelKrems
        Sorry posted Wrong config.js
        This is for MMM -Assistant
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "de",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			position: "top_bar"
        			module: "clock",
        		//	module: "calendar",
        		//	header: "US Holidays",
        		//	position: "top_left",
        		//	config: {
        		//		calendars: [
        		//				symbol: "calendar-check",
        		//				url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
        		//	module: "currentweather",
        		//	config: {
        		//		location: "New York",
        		//		locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        		//		appid: "YOUR_OPENWEATHER_API_KEY"
        		//	module: "weatherforecast",
        		//	header: "Weather Forecast",
        		//	config: {
        		//		locationID: "5128581",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        		//	module: "newsfeed",
        		//	position: "bottom_bar",
        		//	config: {
        		//		feeds: [
        		//				title: "New York Times",
        		//				url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
        		//		showSourceTitle: true,
        		//		showPublishDate: true,
        		//		broadcastNewsFeeds: true,
        		//		broadcastNewsUpdates: true
        	module: "MMM-Hotword",
        		// chimeOnFinish: null,
        		detectorAudioGain: 2.0,
        		detectorApplyFrontend: false, // When you are using `.pmdl`, set this to `false`.
        		// For `.umdl`, When you use only`snowboy` and `smart_mirror`, `false` is better. But with other models, `true` is better.
        		mic: {
          recordProgram : "arecord", //record prgram, `rec`, `arecord`, `sox`, `parec` is available
          device        : "plughw:1",
          sampleRate    : 16000,  // audio sample rate
          channels      : 1,      // number of channels
          threshold     : 0.5,
          thresholdStart: null,
          thresholdEnd  : null,
          silence       : 1.0, // detect end of your hotword or afterRecord.
          verbose       : false,  // log info to the console
        recipes: [],
        models: [],
        commands: {},
        defaultCommand: {
          notificationExec: {
            notification: "HOTWORD_DETECTED",
            payload: (detected, afterRecord) => {
              return {hotword:detected, file:afterRecord}
        chimeOnFinish: "resources/ding.wav", // If you don't want to use chime, set this to null.
        useDisplay: true,
        iconify: "https://code.iconify.design/1/1.0.2/iconify.min.js",
        //iconify: null,
        //When you use this module with `MMM-CalendarExt2`, `MMM-Spotify` or any other `iconify` used modules together, Set this to null.
        icons: { //https://iconify.design/icon-sets/
          waiting: "uil-comment-message",
          detected: "uil-comment-exclamation",
          finished: "uil-comment-dots",
        // customizable notification trigger
        notifications: {
          PAUSE: "HOTWORD_PAUSE",
          RESUME: "HOTWORD_RESUME",
          LISTENING : "HOTWORD_LISTENING",
          SLEEPING : "HOTWORD_SLEEPING",
          ERROR : "HOTWORD_ERROR",
          DETECTED: "HOTWORD_DETECTED"
        		//mic: {
        		//	recordProgram: "arecord",
        		//		device: "default"
        		models: [
        				hotwords    : "smart_mirror",
        				file        : "smart_mirror.umdl",
        				sensitivity : "0.5",
        		commands: {
        			"smart_mirror": {
        				notificationExec: {
        					notification: "ASSISTANT_ACTIVATE",
        						return {profile:"default"}
        		models: [
            hotwords    : "Magic_Mirror",
            file        : "Magic_Mirror.pmdl",
        commands: {
          "volume_up" : {
            notificationExec: {
              notification: "VOLUME_UP"
        				restart:false,
        				afterRecordLimit:0
        	module: "MMM-AssistantMk2",
        		deviceLocation: {
        			coordinates: {
        				latitude: 37.5650168, // -90.0 - +90.0
        				longitude: 126.8491231, // -180.0 - +180.0
        		record: {
        		notifications: {
        			ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
        			ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
        		useWelcomeMessage: "brief today",
        		profiles: {
        			"default" : {
        				lang: "de-DE"
        • ? Offline
          A Former User @MichaelKrems
          @MichaelKrems
          You don’t need to use all of the fields of configuration sample.
          Just try from here;
          https://github.com/eouia/MMM-AssistantMk2/wiki/Configuration#with-mmm-hotwordv2 (with MMM-Hotword(v2) section)
          • G Offline
            guongthongminh @Guest
            @Sean You can help me with the command exec section, calling the browser with the parameter as well as the command line in mmm-hotword
            • ? Offline
              A Former User @guongthongminh
              @guongthongminh Sorry, I can’t catch your intention. What exactly do you want to do?
              G 2 Replies Last reply Reply Quote 0
              • G Offline
                @Sean Can you help me with the website part shown on the mirror?
                • G Offline
                  @Sean using MMM-NotificationTrigger to invoke the voice search browser
                  • ? Offline
                    @guongthongminh
                    Do you mean, you want to show specific web page when you say hotword?
                    In that case, which module are you using to show web page?
                    • G Offline
                      @Sean Can I use the default browser, Chromium?
                      MMM-PageReader is also possible.
                      Sorry for not good at english!
                      • ? Offline
                        @guongthongminh
                        First, using default Browser(Chromium) is not so good idea. You could lose control.
                        I’m reading MMM-PageReader(https://github.com/dgburr/MMM-PageReader) now, it seems possible to use.
                        models: [
                          // You can add more models here.
                        commands: {
                          "smart_mirror": {
                            notificationExec: {
                              notification: "PAGE_READER_LOAD",
                              payload: "https://forum.magicmirror.builders/topic...."
                        // You can add more commands here
                        In this example, you can activate MMM-PageReader with hotword “smart mirror”. Not tested, but ideally working like this.
                        G S 3 Replies Last reply Reply Quote 0
                        • G Offline
                          @Sean Thank you very much!
                          Let me try and see how I hope it will look perfect
                          • G Offline
                            @Sean Is my config file ok?
                            I think it’s almost not working, please help me!
                            alt text
                              sdetweil @Guest
                              @Sean said in MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion:
                              on the armv6 processors (pi 0, 1 and some 3), the electron browser is no longer available at the newer node versions (>8) we are running on 10, so they have to use some other browser and serveronly split mode
                              • G Offline
                                guongthongminh @sdetweil
                                @sdetweil Can you be more specific? Can you help me finish my project because I’m interested in it !!!
                                  sdetweil @guongthongminh
                                  @guongthongminh I dont think this is your problem
                                  you have two models: [] sections above
                                  one that says the hotword is smart_mirror
                                  and one that says “tin_tuc”
                                  I don’t know which became active…
                                  just take the
                                      hotwords: "tin tuc",
                                      file:   ..,
                                      sensitivity: "0.5"
                                  and put it into the the models array above
                                  • G Offline
                                    @sdetweil The hot word is “hotword” for using mmm-asisstantMK2
                                    hot word “tun tuc” to call mmm-pagereader
                                    The result I want it like this https://www.youtube.com/watch?v=xdLz0bdxO58
                                    Can you help me because I don’t know much about this!
                                      @guongthongminh sorry, I cannot help…
                                      • G Offline
                                        guongthongminh
                                        @Sean
                                        I really need your support !!! Please
                                        • ? Offline
                                          @guongthongminh
                                          You did define models twice, so previous one (“smart_mirror”) is ignored.
                                          do like this; (I wrote You can add more models here but you might not see.)
                                          models: [
                                              hotwords: "smart_mirror",
                                              hotwords: "tin_tuc",
                                          • G Offline
                                            @Sean I fixed this but still could not get the MMM-PageReader module to appear on the screen. Could the cause be from the MMM-PageReader modules?
                                            alt text
                                            • 1 / 3
