    Cant seem to get MMM-PIR-Sensor working
    5 Posts 4 Posters 1.2k Views 4 Watching
      mkono87
      Using a rp3 and have a Dell monitor plugged in with a HDMI to DVI connector as this monitor doesnt have hdmi. I have tested that my pir sensor is pulling high on the gpio pin but MagicMirror will not start and throws an error. Even the MMM-PIR module I cant get to work. This is the error im seeing.
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node: undefined symbol: _ZN2v816FunctionTemplate3NewEPNS_7IsolateEPFvRKNS_20FunctionCallbackInfoINS_5ValueEEEENS_5LocalIS4_EENSA_INS_9SignatureEEEiNS_19ConstructorBehaviorENS_14SideEffectTypeE
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-10-22T20_34_24_379Z-debug.log
      Also my module config is super basic as I dont need extra options right now.
      			module: 'MMM-PIR-Sensor',
      Could anyone think of anything I could check with whats going on?
        sdetweil @mkono87
        @mkono87 did u do
        npm install
        in the MMM-PIR_Sensor folder?
        it is required
          mkono87 @sdetweil
          @sdetweil said in Cant seem to get MMM-PIR-Sensor working:
          @mkono87 did u do
          npm install
          it is required
          Of course just like the instructions said. I do get one warning though.
          npm WARN lifecycle Magic-Mirror-Module-PIR-Sensor@1.1.0~postinstall: cannot run in wd Magic-Mirror-Module-PIR-Sensor@1.1.0 electron-rebuild -e ../../node_modules/electron (wd=/home/pi/MagicMirror/modules/MMM-PIR-Sensor)
          • ? Offline
            A Former User
            I never got that module working reliably. Here’s what I wrote instead:
            #!/usr/bin/python3
            # Imported Modules
            from time import sleep
            import subprocess
            import RPi.GPIO as GPIO
            # initialize GPIO
            GPIO.setwarnings(False)
            GPIO.setmode(GPIO.BCM)
            GPIO.cleanup()
            GPIO.setup(22, GPIO.IN)
            PIR = 22
            display_on = True
            while True:
                if display_on and not GPIO.input(PIR):
                    subprocess.run("vcgencmd display_power 0 > /dev/null 2>&1", shell=True)
                    display_on = False
                if not display_on and GPIO.input(PIR):
                    subprocess.run("vcgencmd display_power 1 > /dev/null 2>&1", shell=True)
                    display_on = True
                    sleep(30)
                sleep(0.5)
            Save this in your home directory as pir.py . Note that you will need to change PIR=22 to whichever pin your sensor is on.
            Run: python3 pir.py and you should be up and running
            To have it run at every boot, type crontab -e and add
            @reboot python3 /home/pi/pir.py
            Hope this helps!
            • cowboysdudeC Offline
              cowboysdude Module Developer
              Been using this for over 3 years… I made it, it’s simple and directions are clear…
              https://github.com/cowboysdude/Pir-Sensor
