    Failed at the magicmirror@2.9.0 start script
    8 Posts 5 Posters 3.4k Views 6 Watching
    • FLOW THE NOOBF Offline
      FLOW THE NOOB
      I was trying to run the mirror but it crashes after 5 seconds. It started well and could see and hear the google assistant popping up but then the program closes itself. Any advice would be highly appreciated.
      Here you can see the log;
      pi@raspberrypi:~ $ cd MagicMirror
      > magicmirror@2.9.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.9.0
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-AssistantMk2
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-AssistantMk2
      Launching application.
      Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [AMK2] Recipe is loaded: hide_and_show_all_modules.js
      [AMK2] Recipe is loaded: reboot.js
      [AMK2] Recipe is loaded: screen_onoff.js
      [AMK2] Recipe is loaded: shutdown.js
      [AMK2] Temporal storage directory is clearing.
      [HOTWORD] begins.
      [HOTWORD] Detector starts listening.
      [HOTWORD] stops.
      [HOTWORD] Final Result: { detected: false }
      [HOTWORD] begins.
      [AMK2] assistant ready
      /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.9.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2019-10-24T19_30_25_417Z-debug.log
        sdetweil @greg_r
        @greg_r there apparently is a bad version of grpc… if you fall back to 1.23.? instead of 1.24 it will work.
          sdetweil @FLOW THE NOOB
          @FLOW-THE-NOOB
          the error indicates you need to do an electron-rebuild
          cd ~/MagicMirror
          npm install electron-rebuild
          node_modules/.bin/electron-rebuild
          then restart MagicMirror
          • W Offline
            waseemghaly
            @sdetweil said in Failed at the magicmirror@2.9.0 start script:
            Followed the instructions above and still getting the same error
            npm ERR! file sh
            npm ERR! magicmirror@2.9.0 start: sh run-start.sh
            npm ERR!
            npm ERR! /home/pi/.npm/_logs/2019-10-25T07_45_43_692Z-debug.log
            please advise. thank you
              mrdenmark
              following,i’m having the same problem
                sdetweil
                @mrdenmark @waseemghaly we will have to wait for @Sean to help… he is the module author
                • G Offline
                  greg_r
                  I have exactly the same problem. When triggering MK2 Assistant with hotword or with mouse click, MM crashes with the following errors:
                  [HOTWORD] begins.
                  [HOTWORD] stops.
                  [HOTWORD] begins.
                  npm ERR! file sh
                  npm ERR!
                  npm ERR! /home/pi/.npm/_logs/2019-10-29T22_08_07_413Z-debug.log
                    sdetweil @greg_r
                    • G Offline
                      greg_r
                      Thank you Sam
                      found the solution here https://github.com/eouia/MMM-AssistantMk2/issues/231
                      MM has stopped crashing.
                      Greg
