Failed at the magicmirror@2.9.0 start script
8 Posts 5 Posters 2.5k Views 6 Watching
  • F Offline
    FLOW THE NOOB
    I was trying to run the mirror but it crashes after 5 seconds. It started well and could see and hear the google assistant popping up but then the program closes itself. Any advice would be highly appreciated.
    Here you can see the log;
    pi@raspberrypi:~ $ cd MagicMirror
    > magicmirror@2.9.0 start /home/pi/MagicMirror
    > sh run-start.sh
    Starting MagicMirror: v2.9.0
    Loading config ...
    Loading module helpers ...
    Module helper loaded: MMM-Hotword
    Module helper loaded: MMM-AssistantMk2
    All module helpers loaded.
    Server started ...
    Starting module: newsfeed
    Connecting socket for: MMM-Hotword
    [HOTWORD] MMM-Hotword starts
    Connecting socket for: MMM-AssistantMk2
    Launching application.
    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
    [AMK2] Recipe is loaded: hide_and_show_all_modules.js
    [AMK2] Recipe is loaded: reboot.js
    [AMK2] Recipe is loaded: screen_onoff.js
    [AMK2] Recipe is loaded: shutdown.js
    [AMK2] Temporal storage directory is clearing.
    [HOTWORD] begins.
    [HOTWORD] Detector starts listening.
    [HOTWORD] stops.
    [HOTWORD] Final Result: { detected: false }
    [HOTWORD] begins.
    [AMK2] assistant ready
    /home/pi/MagicMirror/node_modules/electron/dist/electron js/electron.js: symbol lookup error: /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm-glibc/grpc_node.node: undefined symbol: __atomic_store_8
    npm ERR! code ELIFECYCLE
    npm ERR! syscall spawn
    npm ERR! file sh
    npm ERR! errno ENOENT
    npm ERR! magicmirror@2.9.0 start: `sh run-start.sh`
    npm ERR! spawn ENOENT
    npm ERR!
    npm ERR! Failed at the magicmirror@2.9.0 start script.
    npm ERR!     /home/pi/.npm/_logs/2019-10-24T19_30_25_417Z-debug.log
    S 1 Reply Last reply Oct 25, 2019, 2:39 AM Reply Quote 0
      sdetweil @greg_r
      @greg_r there apparently is a bad version of grpc… if you fall back to 1.23.? instead of 1.24 it will work.
        sdetweil @FLOW THE NOOB
        @FLOW-THE-NOOB
        the error indicates you need to do an electron-rebuild
        npm install electron-rebuild
        node_modules/.bin/electron-rebuild
        then restart MagicMirror
        • W Offline
          waseemghaly
          @sdetweil said in Failed at the magicmirror@2.9.0 start script:
          Followed the instructions above and still getting the same error
          npm ERR! file sh
          npm ERR! magicmirror@2.9.0 start: sh run-start.sh
          npm ERR!
          npm ERR! /home/pi/.npm/_logs/2019-10-25T07_45_43_692Z-debug.log
          please advise. thank you
            mrdenmark
            following,i’m having the same problem
              @mrdenmark @waseemghaly we will have to wait for @Sean to help… he is the module author
              • G Offline
                greg_r
                I have exactly the same problem. When triggering MK2 Assistant with hotword or with mouse click, MM crashes with the following errors:
                [HOTWORD] begins.
                [HOTWORD] stops.
                [HOTWORD] begins.
                npm ERR! file sh
                npm ERR!
                npm ERR! /home/pi/.npm/_logs/2019-10-29T22_08_07_413Z-debug.log
                S 1 Reply Last reply Oct 29, 2019, 10:57 PM Reply Quote 0
                  sdetweil @greg_r
                  • G Offline
                    greg_r
                    Thank you Sam
                    found the solution here https://github.com/eouia/MMM-AssistantMk2/issues/231
                    MM has stopped crashing.
                    Greg
