    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 15.0k Views 2 Watching
      sdetweil @DazTypeR
      @DazTypeR yes, go ahead… good strategy. backup… never hurts…
      thanks for all your help !!
      my main computer boot drive is starting to fail…
      time for a hard drive switch later today!
        DazTypeR
        OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
        Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
        Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
          sdetweil @DazTypeR
          @DazTypeR change apply to force
          this was in case u had some failure part way thru…and had to restart
            DazTypeR
            OK done that, it ran, threw out no errors that I could see, so rebooted the Pi using sudo reboot and it all booted back up OK but the Magic Mirror still says there is an update?
              sdetweil @DazTypeR
              @DazTypeR show me the ~/MagicMirror/installers/upgrade.log
              if u can’t post (please use the markdown code block) email to me, same userid as here on gmail
                DazTypeR
                Just VI it abd this is all that appeared on my screen…
                Upgrade started - Sat Nov 2 15:10:57 GMT 2019
                doing test run = true
                downloading dumpactivemodules script
                saving custom.css
                not english or locale not set, set git alias
                remote name = origin
                upgrading from version 2.9.0 to 2.9.0
                fetching latest revisions
                current branch = master
                there are 28 local files that are different than the master repo
                .eslintrc.json
                .gitignore
                .travis.yml
                CHANGELOG.md
                LICENSE.md
                installers/raspberry.sh
                js/main.js
                modules/default/calendar/vendor/ical.js/node-ical.js
                modules/default/clock/clock.js
                modules/default/currentweather/currentweather.js
                modules/default/newsfeed/newsfeed.js
                modules/default/updatenotification/node_helper.js
                modules/default/updatenotification/updatenotification.js
                modules/default/weather/providers/darksky.js
                modules/default/weather/providers/openweathermap.js
                modules/default/weather/providers/ukmetoffice.js
                modules/default/weather/providers/weathergov.js
                modules/default/weather/weather.js
                modules/default/weather/weatherprovider.js
                modules/default/weatherforecast/weatherforecast.js
                package.json
                run-start.sh
                tests/e2e/vendor_spec.js
                translations/en.json
                translations/es.json
                translations/translations.js
                vendor/package-lock.json
                package-lock.json
                save/restore files selection = n
                “upgrade.log” 3423 lines, 162303 characters
                Not sure what you mean by markdown code block, sorry, like In say, still new to this.
                  sdetweil @DazTypeR
                  @DazTypeR said in error: Pulling is not possible because you have unmerged files.:
                  nothing changes in test_run mode
                  must use apply or force parms to get changes put on
                  code block,
                  paste text, select it all (pasted), then hit the </> button above the entry box
                    DazTypeR
                    HI matey, I ran this command…
                    bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” force
                    so not sure why it said test run = Y.
                    My son has a swim gala now so got to shoot, I will get the contents of the log to you, do I just VI it or is there another way to get it to you?
                      sdetweil @DazTypeR
                      @DazTypeR email to same userid as here on gmail
                      • 4 / 4
