    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.7k Views 2 Watching
      DazTypeR
      saving custom.css
      upgrading from version 2.9.0 to 2.9.0
      fetching latest revisions
      bash: line 154: [: missing `]’
      MagicMirror git fetch failed
      restoring custom.css
        sdetweil @DazTypeR
        @DazTypeR one last time
          DazTypeR
          Nearly…
          saving custom.css
          bash: line 161: On branch master: command not found
          there are 28 local files that are different than the master repo
            sdetweil @DazTypeR
            @DazTypeR ok, last time… hard to see the side effects
            $(git status 2>&1) >>$logfile
            that means execute the git status command , and THEN execute the results of THAT , and pass THOSE results to the log
            what I wanted was
            git status 2>&1 >>$logfile
            exec the git status command, and pass ITS results to the log
              DazTypeR
              OK nice one, that has come back with no errors or anything. :)
              Guessing I am correct in replying N to the question regarding lock.json files needed to be saved, I have no idea if I need them or not - lol?
                sdetweil @DazTypeR
                @DazTypeR u should have seen a message
                	any *-lock.json files do not need to be saved
                  DazTypeR
                  Of course, sorry, my bad, I did read that.
                  So am I OK to run this now with the apply option and it should update me to 2.9.0?
                  Also, on the slim chance this mucks up, I backed up my SD card prioe to doing all this, guess I will be OK to just reflash the card with that backup image?
                    sdetweil @DazTypeR
                    @DazTypeR yes, go ahead… good strategy. backup… never hurts…
                    thanks for all your help !!
                    my main computer boot drive is starting to fail…
                    time for a hard drive switch later today!
                      DazTypeR
                      OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
                      Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
                      Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
                        sdetweil @DazTypeR
                        @DazTypeR change apply to force
                        this was in case u had some failure part way thru…and had to restart
                          DazTypeR
                          OK done that, it ran, threw out no errors that I could see, so rebooted the Pi using sudo reboot and it all booted back up OK but the Magic Mirror still says there is an update?
                            sdetweil @DazTypeR
                            @DazTypeR show me the ~/MagicMirror/installers/upgrade.log
                            if u can’t post (please use the markdown code block) email to me, same userid as here on gmail
                              DazTypeR
                              Just VI it abd this is all that appeared on my screen…
                              Upgrade started - Sat Nov 2 15:10:57 GMT 2019
                              doing test run = true
                              downloading dumpactivemodules script
                              saving custom.css
                              not english or locale not set, set git alias
                              remote name = origin
                              current branch = master
                              .eslintrc.json
                              .gitignore
                              .travis.yml
                              CHANGELOG.md
                              LICENSE.md
                              installers/raspberry.sh
                              js/main.js
                              modules/default/calendar/vendor/ical.js/node-ical.js
                              modules/default/clock/clock.js
                              modules/default/currentweather/currentweather.js
                              modules/default/newsfeed/newsfeed.js
                              modules/default/updatenotification/node_helper.js
                              modules/default/updatenotification/updatenotification.js
                              modules/default/weather/providers/darksky.js
                              modules/default/weather/providers/openweathermap.js
                              modules/default/weather/providers/ukmetoffice.js
                              modules/default/weather/providers/weathergov.js
                              modules/default/weather/weather.js
                              modules/default/weather/weatherprovider.js
                              modules/default/weatherforecast/weatherforecast.js
                              package.json
                              run-start.sh
                              tests/e2e/vendor_spec.js
                              translations/en.json
                              translations/es.json
                              translations/translations.js
                              vendor/package-lock.json
                              package-lock.json
                              save/restore files selection = n
                              “upgrade.log” 3423 lines, 162303 characters
                              Not sure what you mean by markdown code block, sorry, like In say, still new to this.
                                sdetweil @DazTypeR
                                @DazTypeR said in error: Pulling is not possible because you have unmerged files.:
                                nothing changes in test_run mode
                                must use apply or force parms to get changes put on
                                code block,
                                paste text, select it all (pasted), then hit the </> button above the entry box
                                  DazTypeR
                                  HI matey, I ran this command…
                                  bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” force
                                  so not sure why it said test run = Y.
                                  My son has a swim gala now so got to shoot, I will get the contents of the log to you, do I just VI it or is there another way to get it to you?
                                    sdetweil @DazTypeR
                                    @DazTypeR email to same userid as here on gmail
