    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.7k Views 2 Watching
      sdetweil @DazTypeR
      @DazTypeR well then
      so, when u run it it says
      It appears MagicMirror has not been installed on this system
      please run the installer, "raspberry.sh" first
      if so, rerun the script like this
      bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
        DazTypeR
        Hang on, I just ran this command…
        Should I have run this command…
        bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
        No idea what the bash -c does?
        Would this have made a difference?
          sdetweil @DazTypeR
          @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
          if you do the bash -c, then it executes the script (single command -c)
          watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
            DazTypeR
            OK, so its official, I am a numpty :)
            This is what I get now when I run it…
            the log will be /home/pi/MagicMirror/installers/upgrade.log
            doing test run = true
            saving custom.css
            upgrading from version 2.9.0 to 2.9.0
            fetching latest revisions
            bash: line 159: On branch master: command not found
            there are 28 local files that are different than the master repo
            .eslintrc.json
            .gitignore
            .travis.yml
            CHANGELOG.md
            LICENSE.md
            installers/raspberry.sh
            js/main.js
            modules/default/calendar/vendor/ical.js/node-ical.js
            modules/default/clock/clock.js
            modules/default/currentweather/currentweather.js
            modules/default/newsfeed/newsfeed.js
            modules/default/updatenotification/node_helper.js
            modules/default/updatenotification/updatenotification.js
            modules/default/weather/providers/darksky.js
            modules/default/weather/providers/openweathermap.js
            modules/default/weather/providers/ukmetoffice.js
            modules/default/weather/providers/weathergov.js
            modules/default/weather/weather.js
            modules/default/weather/weatherprovider.js
            modules/default/weatherforecast/weatherforecast.js
            package.json
            run-start.sh
            tests/e2e/vendor_spec.js
            translations/en.json
            translations/es.json
            translations/translations.js
            vendor/package-lock.json
            package-lock.json
            any *-lock.json files do not need to be saved
            do you want to save these files for later (Y/n)?n
            skipping restore for .eslintrc.json, doing test run
            skipping restore for .gitignore, doing test run
            skipping restore for .travis.yml, doing test run
            skipping restore for CHANGELOG.md, doing test run
            skipping restore for LICENSE.md, doing test run
            skipping restore for installers/raspberry.sh, doing test run
            skipping restore for js/main.js, doing test run
            skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
            skipping restore for modules/default/clock/clock.js, doing test run
            skipping restore for modules/default/currentweather/currentweather.js, doing test run
            skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
            skipping restore for modules/default/updatenotification/node_helper.js, doing test run
            skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
            skipping restore for modules/default/weather/providers/darksky.js, doing test run
            skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
            skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
            skipping restore for modules/default/weather/providers/weathergov.js, doing test run
            skipping restore for modules/default/weather/weather.js, doing test run
            skipping restore for modules/default/weather/weatherprovider.js, doing test run
            skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
            skipping restore for package.json, doing test run
            skipping restore for run-start.sh, doing test run
            skipping restore for tests/e2e/vendor_spec.js, doing test run
            skipping restore for translations/en.json, doing test run
            skipping restore for translations/es.json, doing test run
            skipping restore for translations/translations.js, doing test run
            skipping restore for vendor/package-lock.json, doing test run
            skipping restore for package-lock.json, doing test run
            processing for module MMM-GooglePhotos please wait
            skipped processing for MMM-GooglePhotos, doing test run
            processing complete for module MMM-GooglePhotos
            restoring custom.css
            It then put me back to the command line.
              sdetweil @DazTypeR
              @DazTypeR cool,just like it should have… altho… line 159 bothers me
              can you run it again without apply, and use the debug flag
              you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
              thx
                DazTypeR
                Hope this has everything you need…
                • echo current branch = master
                  ++ git status
                • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                  ++ git status
                  ++ grep modified
                  ++ awk -F: ‘{print $2}’
                • diffs=’ .eslintrc.json
                  .gitignore
                  .travis.yml
                  CHANGELOG.md
                  LICENSE.md
                  js/main.js
                  sdetweil @DazTypeR
                  @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
                    DazTypeR
                    Just ran it again without the extra logging and a block of the output shows this…
                    saving custom.css
                      sdetweil @DazTypeR
                      @DazTypeR can I beg one more try?
                        DazTypeR
                        saving custom.css
                        bash: line 154: [: missing `]’
                        MagicMirror git fetch failed
                          sdetweil @DazTypeR
                          @DazTypeR one last time
                            DazTypeR
                            Nearly…
                            saving custom.css
                            bash: line 161: On branch master: command not found
                              sdetweil @DazTypeR
                              @DazTypeR ok, last time… hard to see the side effects
                              $(git status 2>&1) >>$logfile
                              that means execute the git status command , and THEN execute the results of THAT , and pass THOSE results to the log
                              what I wanted was
                              git status 2>&1 >>$logfile
                              exec the git status command, and pass ITS results to the log
                                DazTypeR
                                OK nice one, that has come back with no errors or anything. :)
                                Guessing I am correct in replying N to the question regarding lock.json files needed to be saved, I have no idea if I need them or not - lol?
                                  sdetweil @DazTypeR
                                  @DazTypeR u should have seen a message
                                    DazTypeR
                                    Of course, sorry, my bad, I did read that.
                                    So am I OK to run this now with the apply option and it should update me to 2.9.0?
                                    Also, on the slim chance this mucks up, I backed up my SD card prioe to doing all this, guess I will be OK to just reflash the card with that backup image?
                                      sdetweil @DazTypeR
                                      @DazTypeR yes, go ahead… good strategy. backup… never hurts…
                                      thanks for all your help !!
                                      my main computer boot drive is starting to fail…
                                      time for a hard drive switch later today!
                                        DazTypeR
                                        OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
                                        Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
                                        Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
                                          sdetweil @DazTypeR
                                          @DazTypeR change apply to force
                                          this was in case u had some failure part way thru…and had to restart
                                            DazTypeR
                                            OK done that, it ran, threw out no errors that I could see, so rebooted the Pi using sudo reboot and it all booted back up OK but the Magic Mirror still says there is an update?
