    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.7k Views 2 Watching
      sdetweil @DazTypeR
      @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
      if you do the bash -c, then it executes the script (single command -c)
      watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
        DazTypeR
        OK, so its official, I am a numpty :)
        This is what I get now when I run it…
        the log will be /home/pi/MagicMirror/installers/upgrade.log
        doing test run = true
        saving custom.css
        upgrading from version 2.9.0 to 2.9.0
        fetching latest revisions
        bash: line 159: On branch master: command not found
        there are 28 local files that are different than the master repo
        .eslintrc.json
        .gitignore
        .travis.yml
        CHANGELOG.md
        LICENSE.md
        installers/raspberry.sh
        js/main.js
        modules/default/calendar/vendor/ical.js/node-ical.js
        modules/default/clock/clock.js
        modules/default/currentweather/currentweather.js
        modules/default/newsfeed/newsfeed.js
        modules/default/updatenotification/node_helper.js
        modules/default/updatenotification/updatenotification.js
        modules/default/weather/providers/darksky.js
        modules/default/weather/providers/openweathermap.js
        modules/default/weather/providers/ukmetoffice.js
        modules/default/weather/providers/weathergov.js
        modules/default/weather/weather.js
        modules/default/weather/weatherprovider.js
        modules/default/weatherforecast/weatherforecast.js
        package.json
        run-start.sh
        tests/e2e/vendor_spec.js
        translations/en.json
        translations/es.json
        translations/translations.js
        vendor/package-lock.json
        package-lock.json
        any *-lock.json files do not need to be saved
        do you want to save these files for later (Y/n)?n
        skipping restore for .eslintrc.json, doing test run
        skipping restore for .gitignore, doing test run
        skipping restore for .travis.yml, doing test run
        skipping restore for CHANGELOG.md, doing test run
        skipping restore for LICENSE.md, doing test run
        skipping restore for installers/raspberry.sh, doing test run
        skipping restore for js/main.js, doing test run
        skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
        skipping restore for modules/default/clock/clock.js, doing test run
        skipping restore for modules/default/currentweather/currentweather.js, doing test run
        skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
        skipping restore for modules/default/updatenotification/node_helper.js, doing test run
        skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
        skipping restore for modules/default/weather/providers/darksky.js, doing test run
        skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
        skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
        skipping restore for modules/default/weather/providers/weathergov.js, doing test run
        skipping restore for modules/default/weather/weather.js, doing test run
        skipping restore for modules/default/weather/weatherprovider.js, doing test run
        skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
        skipping restore for package.json, doing test run
        skipping restore for run-start.sh, doing test run
        skipping restore for tests/e2e/vendor_spec.js, doing test run
        skipping restore for translations/en.json, doing test run
        skipping restore for translations/es.json, doing test run
        skipping restore for translations/translations.js, doing test run
        skipping restore for vendor/package-lock.json, doing test run
        skipping restore for package-lock.json, doing test run
        processing for module MMM-GooglePhotos please wait
        skipped processing for MMM-GooglePhotos, doing test run
        processing complete for module MMM-GooglePhotos
        restoring custom.css
        It then put me back to the command line.
          sdetweil @DazTypeR
          @DazTypeR cool,just like it should have… altho… line 159 bothers me
          can you run it again without apply, and use the debug flag
          bash -c -x "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
          you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
          thx
            DazTypeR
            Hope this has everything you need…
            • echo current branch = master
              ++ git status
            • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
              ++ git status
              ++ grep modified
              ++ awk -F: ‘{print $2}’
            • diffs=’ .eslintrc.json
              .gitignore
              .travis.yml
              CHANGELOG.md
              LICENSE.md
              js/main.js
              sdetweil @DazTypeR
              @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
                DazTypeR
                Just ran it again without the extra logging and a block of the output shows this…
                saving custom.css
                  sdetweil @DazTypeR
                  @DazTypeR can I beg one more try?
                    DazTypeR
                    saving custom.css
                    bash: line 154: [: missing `]’
                    MagicMirror git fetch failed
                      sdetweil @DazTypeR
                      @DazTypeR one last time
                        DazTypeR
                        Nearly…
                        saving custom.css
                        bash: line 161: On branch master: command not found
                          sdetweil @DazTypeR
                          @DazTypeR ok, last time… hard to see the side effects
                          $(git status 2>&1) >>$logfile
                          that means execute the git status command , and THEN execute the results of THAT , and pass THOSE results to the log
                          what I wanted was
                          git status 2>&1 >>$logfile
                          exec the git status command, and pass ITS results to the log
                            DazTypeR
                            OK nice one, that has come back with no errors or anything. :)
                            Guessing I am correct in replying N to the question regarding lock.json files needed to be saved, I have no idea if I need them or not - lol?
                              sdetweil @DazTypeR
                              @DazTypeR u should have seen a message
                                DazTypeR
                                Of course, sorry, my bad, I did read that.
                                So am I OK to run this now with the apply option and it should update me to 2.9.0?
                                Also, on the slim chance this mucks up, I backed up my SD card prioe to doing all this, guess I will be OK to just reflash the card with that backup image?
                                  sdetweil @DazTypeR
                                  @DazTypeR yes, go ahead… good strategy. backup… never hurts…
                                  thanks for all your help !!
                                  my main computer boot drive is starting to fail…
                                  time for a hard drive switch later today!
                                    DazTypeR
                                    OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
                                    Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
                                    Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
                                      sdetweil @DazTypeR
                                      @DazTypeR change apply to force
                                      this was in case u had some failure part way thru…and had to restart
                                        DazTypeR
                                        OK done that, it ran, threw out no errors that I could see, so rebooted the Pi using sudo reboot and it all booted back up OK but the Magic Mirror still says there is an update?
                                          sdetweil @DazTypeR
                                          @DazTypeR show me the ~/MagicMirror/installers/upgrade.log
                                          if u can’t post (please use the markdown code block) email to me, same userid as here on gmail
                                            DazTypeR
                                            Just VI it abd this is all that appeared on my screen…
                                            Upgrade started - Sat Nov 2 15:10:57 GMT 2019
                                            downloading dumpactivemodules script
                                            saving custom.css
                                            not english or locale not set, set git alias
                                            remote name = origin
                                            .eslintrc.json
                                            .gitignore
                                            .travis.yml
                                            CHANGELOG.md
                                            LICENSE.md
                                            js/main.js
                                            package.json
                                            run-start.sh
                                            package-lock.json
                                            save/restore files selection = n
                                            “upgrade.log” 3423 lines, 162303 characters
                                            Not sure what you mean by markdown code block, sorry, like In say, still new to this.
