    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 18.7k Views 2 Watching
      DazTypeR
      OK, so its official, I am a numpty :)
      This is what I get now when I run it…
      the log will be /home/pi/MagicMirror/installers/upgrade.log
      doing test run = true
      saving custom.css
      upgrading from version 2.9.0 to 2.9.0
      fetching latest revisions
      bash: line 159: On branch master: command not found
      there are 28 local files that are different than the master repo
      .eslintrc.json
      .gitignore
      .travis.yml
      CHANGELOG.md
      LICENSE.md
      installers/raspberry.sh
      js/main.js
      modules/default/calendar/vendor/ical.js/node-ical.js
      modules/default/clock/clock.js
      modules/default/currentweather/currentweather.js
      modules/default/newsfeed/newsfeed.js
      modules/default/updatenotification/node_helper.js
      modules/default/updatenotification/updatenotification.js
      modules/default/weather/providers/darksky.js
      modules/default/weather/providers/openweathermap.js
      modules/default/weather/providers/ukmetoffice.js
      modules/default/weather/providers/weathergov.js
      modules/default/weather/weather.js
      modules/default/weather/weatherprovider.js
      modules/default/weatherforecast/weatherforecast.js
      package.json
      run-start.sh
      tests/e2e/vendor_spec.js
      translations/en.json
      translations/es.json
      translations/translations.js
      vendor/package-lock.json
      package-lock.json
      any *-lock.json files do not need to be saved
      do you want to save these files for later (Y/n)?n
      skipping restore for .eslintrc.json, doing test run
      skipping restore for .gitignore, doing test run
      skipping restore for .travis.yml, doing test run
      skipping restore for CHANGELOG.md, doing test run
      skipping restore for LICENSE.md, doing test run
      skipping restore for installers/raspberry.sh, doing test run
      skipping restore for js/main.js, doing test run
      skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
      skipping restore for modules/default/clock/clock.js, doing test run
      skipping restore for modules/default/currentweather/currentweather.js, doing test run
      skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
      skipping restore for modules/default/updatenotification/node_helper.js, doing test run
      skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
      skipping restore for modules/default/weather/providers/darksky.js, doing test run
      skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
      skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
      skipping restore for modules/default/weather/providers/weathergov.js, doing test run
      skipping restore for modules/default/weather/weather.js, doing test run
      skipping restore for modules/default/weather/weatherprovider.js, doing test run
      skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
      skipping restore for package.json, doing test run
      skipping restore for run-start.sh, doing test run
      skipping restore for tests/e2e/vendor_spec.js, doing test run
      skipping restore for translations/en.json, doing test run
      skipping restore for translations/es.json, doing test run
      skipping restore for translations/translations.js, doing test run
      skipping restore for vendor/package-lock.json, doing test run
      skipping restore for package-lock.json, doing test run
      processing for module MMM-GooglePhotos please wait
      skipped processing for MMM-GooglePhotos, doing test run
      processing complete for module MMM-GooglePhotos
      restoring custom.css
      It then put me back to the command line.
        sdetweil @DazTypeR
        @DazTypeR cool,just like it should have… altho… line 159 bothers me
        can you run it again without apply, and use the debug flag
        bash -c -x "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
        you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
        thx
          DazTypeR
          Hope this has everything you need…
          • echo current branch = master
            ++ git status
          • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
            ++ git status
            ++ grep modified
            ++ awk -F: ‘{print $2}’
          • diffs=’ .eslintrc.json
            .gitignore
            .travis.yml
            CHANGELOG.md
            LICENSE.md
            js/main.js
            sdetweil @DazTypeR
            @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
              DazTypeR
              Just ran it again without the extra logging and a block of the output shows this…
              saving custom.css
                sdetweil @DazTypeR
                @DazTypeR can I beg one more try?
                  DazTypeR
                  saving custom.css
                  bash: line 154: [: missing `]’
                  MagicMirror git fetch failed
                    sdetweil @DazTypeR
                    @DazTypeR one last time
                      DazTypeR
                      Nearly…
                      saving custom.css
                      bash: line 161: On branch master: command not found
                        sdetweil @DazTypeR
                        @DazTypeR ok, last time… hard to see the side effects
                        $(git status 2>&1) >>$logfile
                        that means execute the git status command , and THEN execute the results of THAT , and pass THOSE results to the log
                        what I wanted was
                        git status 2>&1 >>$logfile
                        exec the git status command, and pass ITS results to the log
                          DazTypeR
                          OK nice one, that has come back with no errors or anything. :)
                          Guessing I am correct in replying N to the question regarding lock.json files needed to be saved, I have no idea if I need them or not - lol?
                            sdetweil @DazTypeR
                            @DazTypeR u should have seen a message
                              DazTypeR
                              Of course, sorry, my bad, I did read that.
                              So am I OK to run this now with the apply option and it should update me to 2.9.0?
                              Also, on the slim chance this mucks up, I backed up my SD card prioe to doing all this, guess I will be OK to just reflash the card with that backup image?
                                sdetweil @DazTypeR
                                @DazTypeR yes, go ahead… good strategy. backup… never hurts…
                                thanks for all your help !!
                                my main computer boot drive is starting to fail…
                                time for a hard drive switch later today!
                                  DazTypeR
                                  OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
                                  Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
                                  Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
                                    sdetweil @DazTypeR
                                    @DazTypeR change apply to force
                                    this was in case u had some failure part way thru…and had to restart
                                      DazTypeR
                                      OK done that, it ran, threw out no errors that I could see, so rebooted the Pi using sudo reboot and it all booted back up OK but the Magic Mirror still says there is an update?
                                        sdetweil @DazTypeR
                                        @DazTypeR show me the ~/MagicMirror/installers/upgrade.log
                                        if u can’t post (please use the markdown code block) email to me, same userid as here on gmail
                                          DazTypeR
                                          Just VI it abd this is all that appeared on my screen…
                                          Upgrade started - Sat Nov 2 15:10:57 GMT 2019
                                          downloading dumpactivemodules script
                                          saving custom.css
                                          not english or locale not set, set git alias
                                          remote name = origin
                                          .eslintrc.json
                                          .gitignore
                                          .travis.yml
                                          CHANGELOG.md
                                          LICENSE.md
                                          js/main.js
                                          package.json
                                          run-start.sh
                                          package-lock.json
                                          save/restore files selection = n
                                          “upgrade.log” 3423 lines, 162303 characters
                                          Not sure what you mean by markdown code block, sorry, like In say, still new to this.
                                            sdetweil @DazTypeR
                                            @DazTypeR said in error: Pulling is not possible because you have unmerged files.:
                                            nothing changes in test_run mode
                                            must use apply or force parms to get changes put on
                                            code block,
                                            paste text, select it all (pasted), then hit the </> button above the entry box
