    error: Pulling is not possible because you have unmerged files.
    39 Posts 2 Posters 17.9k Views 2 Watching
      DazTypeR
      I can’t find an upgrade.log either in home or in the MagicMirror/installers folder.
        sdetweil @DazTypeR
        @DazTypeR well then
        so, when u run it it says
        It appears MagicMirror has not been installed on this system
        please run the installer, "raspberry.sh" first
        if so, rerun the script like this
        bash -c -x  "$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)"
          DazTypeR
          Hang on, I just ran this command…
          Should I have run this command…
          bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)”
          No idea what the bash -c does?
          Would this have made a difference?
            sdetweil @DazTypeR
            @DazTypeR yes… if you do it without bash -c, then it downloads the file, and throws it away
            if you do the bash -c, then it executes the script (single command -c)
            watch out for the double quotes… sometimes those turn into MS word document quotes, which linux shells don’t like
              DazTypeR
              OK, so its official, I am a numpty :)
              This is what I get now when I run it…
              the log will be /home/pi/MagicMirror/installers/upgrade.log
              doing test run = true
              saving custom.css
              upgrading from version 2.9.0 to 2.9.0
              fetching latest revisions
              bash: line 159: On branch master: command not found
              there are 28 local files that are different than the master repo
              .eslintrc.json
              .gitignore
              .travis.yml
              CHANGELOG.md
              LICENSE.md
              installers/raspberry.sh
              js/main.js
              modules/default/calendar/vendor/ical.js/node-ical.js
              modules/default/clock/clock.js
              modules/default/currentweather/currentweather.js
              modules/default/newsfeed/newsfeed.js
              modules/default/updatenotification/node_helper.js
              modules/default/updatenotification/updatenotification.js
              modules/default/weather/providers/darksky.js
              modules/default/weather/providers/openweathermap.js
              modules/default/weather/providers/ukmetoffice.js
              modules/default/weather/providers/weathergov.js
              modules/default/weather/weather.js
              modules/default/weather/weatherprovider.js
              modules/default/weatherforecast/weatherforecast.js
              package.json
              run-start.sh
              tests/e2e/vendor_spec.js
              translations/en.json
              translations/es.json
              translations/translations.js
              vendor/package-lock.json
              package-lock.json
              any *-lock.json files do not need to be saved
              do you want to save these files for later (Y/n)?n
              skipping restore for .eslintrc.json, doing test run
              skipping restore for .gitignore, doing test run
              skipping restore for .travis.yml, doing test run
              skipping restore for CHANGELOG.md, doing test run
              skipping restore for LICENSE.md, doing test run
              skipping restore for installers/raspberry.sh, doing test run
              skipping restore for js/main.js, doing test run
              skipping restore for modules/default/calendar/vendor/ical.js/node-ical.js, doing test run
              skipping restore for modules/default/clock/clock.js, doing test run
              skipping restore for modules/default/currentweather/currentweather.js, doing test run
              skipping restore for modules/default/newsfeed/newsfeed.js, doing test run
              skipping restore for modules/default/updatenotification/node_helper.js, doing test run
              skipping restore for modules/default/updatenotification/updatenotification.js, doing test run
              skipping restore for modules/default/weather/providers/darksky.js, doing test run
              skipping restore for modules/default/weather/providers/openweathermap.js, doing test run
              skipping restore for modules/default/weather/providers/ukmetoffice.js, doing test run
              skipping restore for modules/default/weather/providers/weathergov.js, doing test run
              skipping restore for modules/default/weather/weather.js, doing test run
              skipping restore for modules/default/weather/weatherprovider.js, doing test run
              skipping restore for modules/default/weatherforecast/weatherforecast.js, doing test run
              skipping restore for package.json, doing test run
              skipping restore for run-start.sh, doing test run
              skipping restore for tests/e2e/vendor_spec.js, doing test run
              skipping restore for translations/en.json, doing test run
              skipping restore for translations/es.json, doing test run
              skipping restore for translations/translations.js, doing test run
              skipping restore for vendor/package-lock.json, doing test run
              skipping restore for package-lock.json, doing test run
              processing for module MMM-GooglePhotos please wait
              skipped processing for MMM-GooglePhotos, doing test run
              processing complete for module MMM-GooglePhotos
              restoring custom.css
              It then put me back to the command line.
                sdetweil @DazTypeR
                @DazTypeR cool,just like it should have… altho… line 159 bothers me
                can you run it again without apply, and use the debug flag
                you will have to scroll back up in the terminal window, but I’d like to see the few lines above/below the error line 159
                thx
                  DazTypeR
                  Hope this has everything you need…
                  • echo current branch = master
                    ++ git status
                  • ‘On branch master’ ‘Your branch and ‘'‘origin/master’'’ have diverged,’ ‘and have 4 and 76 different commits each, respectively.’ ’ (use “git pull” to merge the remote branch into yours)’ ‘You have unmerged paths.’ ’ (fix conflicts and run “git commit”)’ ’ (use “git merge --abort” to abort the merge)’ ‘Changes to be committed:’ ’ modified: .eslintrc.json’ ’ modified: .gitignore’ ’ modified: .travis.yml’ ’ modified: CHANGELOG.md’ ’ modified: LICENSE.md’ ’ deleted: css/custom.css’ ’ modified: installers/raspberry.sh’ ’ modified: js/main.js’ ’ modified: modules/default/calendar/vendor/ical.js/node-ical.js’ ’ modified: modules/default/clock/clock.js’ ’ modified: modules/default/currentweather/currentweather.js’ ’ modified: modules/default/newsfeed/newsfeed.js’ ’ modified: modules/default/updatenotification/node_helper.js’ ’ modified: modules/default/updatenotification/updatenotification.js’ ’ modified: modules/default/weather/providers/darksky.js’ ’ modified: modules/default/weather/providers/openweathermap.js’ ’ modified: modules/default/weather/providers/ukmetoffice.js’ ’ modified: modules/default/weather/providers/weathergov.js’ ’ modified: modules/default/weather/weather.js’ ’ modified: modules/default/weather/weatherprovider.js’ ’ modified: modules/default/weatherforecast/weatherforecast.js’ ’ modified: package.json’ ’ modified: run-start.sh’ ’ new file: tests/configs/modules/weather/currentweather_default.js’ ’ new file: tests/configs/modules/weather/currentweather_options.js’ ’ new file: tests/configs/modules/weather/currentweather_units.js’ ’ new file: tests/configs/modules/weather/forecastweather_default.js’ ’ new file: tests/configs/modules/weather/forecastweather_options.js’ ’ new file: tests/e2e/modules/mocks/index.js’ ’ new file: tests/e2e/modules/mocks/weather_current.js’ ’ new file: tests/e2e/modules/mocks/weather_forecast.js’ ’ new file: tests/e2e/modules/weather_spec.js’ ’ modified: tests/e2e/vendor_spec.js’ ’ new file: tests/node_modules/webdriverajaxstub/index.js’ ’ modified: translations/en.json’ ’ modified: translations/es.json’ ’ new file: translations/ms-my.json’ ’ modified: translations/translations.js’ ’ new file: untrack-css.sh’ ’ modified: vendor/package-lock.json’ ‘Unmerged paths:’ ’ (use “git add …” to mark resolution)’ ’ both modified: package-lock.json’ ‘Untracked files:’ ’ (use “git add …” to include in what will be committed)’ ’ css/save_custom.css’ ’ installers/dumpactivemodules.js’
                    ++ git status
                    ++ grep modified
                    ++ awk -F: ‘{print $2}’
                  • diffs=’ .eslintrc.json
                    .gitignore
                    .travis.yml
                    CHANGELOG.md
                    LICENSE.md
                    js/main.js
                    sdetweil @DazTypeR
                    @DazTypeR cool, can u try that one more time (without apply) to see if I fixed the line 159 problem
                      DazTypeR
                      Just ran it again without the extra logging and a block of the output shows this…
                      saving custom.css
                        sdetweil @DazTypeR
                        @DazTypeR can I beg one more try?
                          DazTypeR
                          saving custom.css
                          bash: line 154: [: missing `]’
                          MagicMirror git fetch failed
                            sdetweil @DazTypeR
                            @DazTypeR one last time
                              DazTypeR
                              Nearly…
                              saving custom.css
                              bash: line 161: On branch master: command not found
                                sdetweil @DazTypeR
                                @DazTypeR ok, last time… hard to see the side effects
                                $(git status 2>&1) >>$logfile
                                that means execute the git status command , and THEN execute the results of THAT , and pass THOSE results to the log
                                what I wanted was
                                git status 2>&1 >>$logfile
                                exec the git status command, and pass ITS results to the log
                                  DazTypeR
                                  OK nice one, that has come back with no errors or anything. :)
                                  Guessing I am correct in replying N to the question regarding lock.json files needed to be saved, I have no idea if I need them or not - lol?
                                    sdetweil @DazTypeR
                                    @DazTypeR u should have seen a message
                                      DazTypeR
                                      Of course, sorry, my bad, I did read that.
                                      So am I OK to run this now with the apply option and it should update me to 2.9.0?
                                      Also, on the slim chance this mucks up, I backed up my SD card prioe to doing all this, guess I will be OK to just reflash the card with that backup image?
                                        sdetweil @DazTypeR
                                        @DazTypeR yes, go ahead… good strategy. backup… never hurts…
                                        thanks for all your help !!
                                        my main computer boot drive is starting to fail…
                                        time for a hard drive switch later today!
                                          DazTypeR
                                          OK, so I ran the script with the apply option and it said something about the versions are the same and just finished.
                                          Did all the test we do earlier pull down version 2.9.0 and that is what your installer is seeing?
                                          Just rebooted the Pi in case and when the Magic Mirror booted up it still said there was an update needed.
                                            sdetweil @DazTypeR
                                            @DazTypeR change apply to force
                                            this was in case u had some failure part way thru…and had to restart
